04-06-2021, 12:26 AM
#331
Real Name: Devan
Real Name: Devan
Originally Posted by spartacus
Ah I see the difference now comparing them on ECGS, that's major bummer. Thanks for the reply. Really don't wanna spend the money for a regearing
04-06-2021, 12:34 PM
#332
Not the news I wanted
Hello folks!
Well, got some shitty news today. I took my truck in to replace lower ball joints and diagnose a P0300 code. Just got a call from the shop, sounds like there's an issue with my cylinder heads. I wrote down everything he shared with me so you can get the whole picture.
-Temp gauge went to the red when he pulled the truck in (Never done that before)
-Heat wasn't blowing in the cab
-Radiator was super hot and low on coolant (hasn't found any coolant leaks yet)
-Did a block test and it came back positive. Oil or exhaust somewhere in the system
His diagnosis is that we'll need to teardown the engine and send the cylinder heads off to a machine shop and then rebuild the engine. He said roughly 4-6 weeks for the job and a rough estimate of $2000. If you've seen my posts before, you know that this is my first car I've ever purchased and I'm really a beginner.
Can anyone provide some insight on this? Trying to figure out what the best course of action is and also trying to tell myself all will be okay. Thank you in advance!
04-06-2021, 01:29 PM
#333
Originally Posted by PeteCain
Hello folks!
Theré is a possibility that engine head is cracked or it could also be just a bad head gasket. $2000 all in is not too bad. Cheapest option would be swapping out the motor with used one from a salvage yard or someone parting out a wrecked 4runner on Craigslist , facebook market place etc, cost would be motor around $500 and labor around $500 to drop it in. Jpm import out of a Toyota van from Japan another option but are getting a little expensive. Your mechanic should be able to tell you after tear down if the heads are warpped, cracked or it is a blown head gasket. Labor cost is what makes the bill expensive. Good luck.
04-06-2021, 05:20 PM
#334
Hello folks!
Is it a mechanic that you trust? P0300 marks a misfire which could be caused by many many small things. If you haven't had any drivability issues and never experienced the symptoms he is describing, it's hard not to be skeptical... Just seems weird that you could drive it to the shop with the temp gauge in spec but it would spike when he pulled it in?
04-06-2021, 07:08 PM
#335
I did think about that. However after a little research through the forums, I've been experiencing the other telltale signs. Rough idle on startup, white smoke for ~ 1 minute after starting, and misfire code. Is there anything else that those could be?
04-07-2021, 12:07 AM
#336
Real Name: Leif
Real Name: Leif
hey man. sorry to hear of your troubles. white smoke often is a HG issue. i was having that with a 3.slo in my truck, and that precipitated a swap to a 5vz-fe eight years ago this summer. we had a look after extracting the old engine, and we had caught it in time, but it was indeed a blown head gasket. we were able to get some salvage $$ for it.
we later replaced that used 5vz-fe for a reman when the first swapper threw a rod. the dead old one came out and the new short block went in, in ten hours. it was a long day but two of us made it happen.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
04-07-2021, 09:53 AM
#337
Real Name: Patrick
Real Name: Patrick
Originally Posted by Devbot
I was thinking of doing an elocker on a budget. You should be able to use just the 4.11 3rd member off a Tacoma right? Tim mentioned taking the whole rear axle but I don't see why not just take the diff
You'll need to either modify your current housing, find a 4Runner elocker rear axle housing, or remove the spring perches and add all the 4Runner brackets to the Tacoma axle housing
04-08-2021, 01:21 PM
#338
RIP Head Gasket
Just as I suspected, I've got a blown head gasket. Good news is that the bottom is still in good shape.
My mechanic just called and gave all the work that needs to be done:
-Send the heads off to machine shop to get them planed and flattened
-Fix leaking valves
-Replace head bolts
-Replace knock sensor wire
-PCV valve
-Coolant
- He suggested cleaning the fuel injectors (extra $180)
All in, he quoted me $3080.12.
Do the fuel injectors really need to be done? Like what is the benefit of doing those? If possible, I'd rather spend the money on my LBJs but I don't want to overlook the fuel injectors if that's vital.
Thanks for any advice you guys can provide!
04-08-2021, 02:10 PM
#339
-Fix leaking valves
-Replace head bolts
-PCV valve
-Coolant
Consider just getting an entirely new Longblock from Yota1 performance
5VZ 3.4L Rebuilt Toyota Engine (Complete) - Yota1 Performance, Inc.
You're just $1000 away from this with your current $3080 quote, and you get a whole new engine, not only new heads.
This is only my opinion-- might as well go all in while the engine is out-- doing this would be a lot easier than removing your heads, shipping them off, etc.
It would be a matter of ordering this engine, taking your accessories off and putting them on this, and dropping it in.
If you can scrape up the extra $1k, this is 100% what i'd suggest
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
04-08-2021, 02:18 PM
#340
That $3080 quote shocked me!
So, Yes I concur, if you're willing to drop +$3K for only the top, just keep going.
04-08-2021, 04:05 PM
#341
Real Name: Patrick
Real Name: Patrick
-Fix leaking valves
-Replace head bolts
-PCV valve
-Coolant
Personally I would skip the injector cleaning. If they become a problem later they are pretty easy to access and replace.
The original $3000 quote he had probably includes labor and the engine is probably still in the truck with the heads off. The labor to pull that engine and replace with a new one will add pretty considerably to the extra $1000 for a new engine. Just something for PeteCain to consider.
04-08-2021, 06:12 PM
#342
Real Name: Leif
Real Name: Leif
i got my dressed reman 5vz-fe long block for my truck from yotashop. appears you can still get either a short block or a long block from them. so far (~30 months) it runs properly and has had no issues. but that price will probably make you
Code:
https://www.yotashop.com/toyota-engine-toyota-v6-3-4l-5vz-fe-engine-dressed-long-block-4runner-t100-tacoma-tundra-1995-2004-5vz-dlb-9504/
04-08-2021, 07:18 PM
#343
Real Name: Blair
Real Name: Blair
4 7 0 0
04-08-2021, 09:26 PM
#344
Real Name: Leif
Real Name: Leif
Originally Posted by Endlessblockades
yah, i know. i liked the short block price but didn't want them coming back to me (after a hypothetical failure) saying i didn't do this, didn't install the TB right, let us talk to your installer, blah blah woof woof. also didn't know the extent of the thrown rod damage, and upon tearing into it, turned out that the thing really did get trashed.
04-08-2021, 09:51 PM
#345
Real Name: Blair
Real Name: Blair
Oh for sure, I wasn't really tripping on the price - just goofing around. If you had the money on hand, I'm all for it. Money comes and goes but a good Toyota motor is forever (almost).
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
