Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 06-08-2021, 03:31 PM #466
jmh139 jmh139 is offline
jmh139 is on a distinguished road
Originally Posted by Bad Luck View Post
In case you didn't know you will need to swap the rear upper control arms and front/rear driveshafts as well.
I knew about the driveshafts (I have them) but not the rear upper control arms. What is different about them?
jmh139 is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 04:18 PM #467
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The 2wd upper control arms are longer than the 4wd upper control arms. This causes the rear pinion angle to be different. Because the 2wd and 4wd rear driveshafts use a different design (and amount of u joints) the 2wd driveshaft requires the rear pinion to point further up compared to what the 4wd driveshaft pinion angle is. If you don't change the rear upper control arms you will have a vibration.
Edit: I thought you were doing a 2wd to 4wd conversion as well. Oops no need to change rear upper control arms.
Old 06-08-2021, 04:19 PM #468
Ah, that makes sense but both of my 4runners are 4x4 so I should be good. Thanks
Old 06-08-2021, 04:21 PM #469
Real Name: Patrick
Real Name: Patrick
Oh that's my bad. I got you confused with the other guy doing a 2wd to 4wd conversion. Oops lol
Old 06-08-2021, 04:22 PM #470
No worries, I really appreciate the help.
Old 06-12-2021, 05:12 PM #471
wsteele8974 wsteele8974 is offline
wsteele8974 is on a distinguished road
How's it going guys! Finally redid my lift and I'm really happy with the results!
2000 4runner 2WD w/3RZ 2.7l
Bilstein 5100's front and back, OME 880 front, 906 rear, 3rd gen front sway bar links in the back and 2nd gen rear sway bar links in the front.
The 3rd Gen All Questions Allowed Thread-fb_img_1623531958016-jpg
wsteele8974 is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 11:23 PM #472
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Who's the go to for fuel tank skids these days? Debating between lil skip, coastal, or shrockworks
Old 06-21-2021, 08:12 PM #473
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
I enjoy my lil' skip skid.
No problems, and I'm pretty sure its the best fitting of the three.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 08:30 PM #474
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
oh sh*t I forgot I posted that here, just made a thread on this literally a minute or two ago lmao
Old 06-22-2021, 01:56 PM #475
KiheiTheT4R's Avatar
KiheiTheT4R KiheiTheT4R is offline
Real Name: Andrew
KiheiTheT4R is on a distinguished road
Real Name: Andrew
2002 Climate Control Unit Malfunctioning
I've been searching around but haven't found any threads on the automatic climate control units newer than 2016. The unit in my 2002 4Runner is having the typical malfunctioning issues. I am in British Columbia and trying to figure out my best option for replacement or sending it away to have it fixed. Would love some up to date help on this.
IG: @the.hollidays @andrewhollidayphoto
02' Golden Pearl T4R Limited
KiheiTheT4R is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 04:43 PM #476
Real Name: Patrick
Real Name: Patrick
I don't know if you can ship it to the US but this guy does the repairs: Auto Climate Control Repair Services He repaired mine shortly after I bought my 4Runner.
If you can't ship it to get repaired there then you might try reading through these two threads to see if they are relevant to your problem and within your skill set:
Fix for the Limited Climate Control
DIY Climate Controller Repair -How to
Old 06-22-2021, 09:31 PM #477
BootsyCollins BootsyCollins is offline
BootsyCollins is on a distinguished road
Mystery Bushing
Hey All,
I have a 1997 4runner 4x4 with a bushing that I can't identify. It's the rear most bushing connecting the front diff to the crossmember on the frame. Any idea what a part number for it would be?
Mystery Bushing - Album on Imgur
Thanks!
Edit: I figured it out if anyone else needs it!
Descriptionifferential Housing Support (Front)
Part Number: 5238035010
Quantity:1
Price:$72.83
BootsyCollins is offline   Reply With QuoteReply With Quote
Old 06-23-2021, 07:21 PM #478
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by BootsyCollins View Post
Hey All,
Thanks!
Quantity:1
Price:$72.83
Very interesting, Toyota never made replacement bushings for the front two supports so it's very strange they made one for the rear. Good to know though, I wasn't even aware there WAS a third bushing but that might be the soft clunking I've had for the past year, that seemed to get better/worse as I messed with the diff drop. Do report back with how easy the install was!
Old 06-24-2021, 07:57 AM #479
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Very interesting, Toyota never made replacement bushings for the front two supports so it's very strange they made one for the rear....
They didn't, you get metal and all they're molded together 1 piece same as front.
edit: that one wore the f**k out
Old 06-24-2021, 10:09 PM #480
Gwf1963 Gwf1963 is offline
Gwf1963 is on a distinguished road
Transfer Case Issues
‘99 Limited. Shifted into 4WD, would not shift out. Tried all suggestions, no luck. Finally tapped on what I think to be actuator and it popped out. This is what I tapped on but it does not look like any actuator on net photos. Any thoughts on a maintenance plan before the next CO winter?
The 3rd Gen All Questions Allowed Thread-6effcb7c-2cab-48d7-b212-64788d1a8f23-jpeg
Gwf1963 is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
