Old 08-02-2021, 01:18 AM #541
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light
Devbot's Avatar
Real Name: Devan
1) anybody know what this part of the power steering is? It's the culprit of my leak and I'm curious what involves fixing it. I assume there to be a gasket of sorts that's gone
2) if that's not feasible without replacing the rack, could I potentially use ATF with stop leak to hold off for the time being?
The 3rd Gen All Questions Allowed Thread-screenshot_20210801-221724_gallery-jpg
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 08-02-2021, 01:58 AM #542
Skulking Skulking is offline
Skulking has a spectacular aura about Skulking has a spectacular aura about
Where exactly do you think it is leaking from? How sure are you that leak is coming from the power steering? From what I can see, it looks like you have fluid above the high point of the rack.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 08:41 AM #543
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Right where the shiny spot stops at that bolt/flange. Pretty certain its coming from there, I have a valve cover leak too that was making the rack dirty but I also noticed a constant, slow loss of PS fluid (ATF) too - so I cleaned and dried everything, and after a day or two I found a drip leading back up to the flange pictured. Color is hard to tell since it gets dirty but seems to be reddish.
Old 08-02-2021, 10:02 AM #544
No fluid runs up that high. I'd be looking for something above that point dripping down.
Old 08-02-2021, 11:27 AM #545
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
Looked like this when my driver side valve cover was leaking. Check bolt torque
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 04:05 PM #546
JUICE222 JUICE222 is offline
JUICE222 is on a distinguished road
I had a leak that look similar to that on my 4runner. I found the leak was coming from the rubber piece area with yellow paint mark below the flange. Its part of the rack and pinion. I was not able to find any repair kits for it at the time. I ended up replacing the rack and pinion. I never tried adding any type of stop leak. Hope this helps.
JUICE222 is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 07:47 PM #547
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Thanks, I'm thinking I'll start with my valve covers and see if anything changes. I can see directly above the flange is some oil and how it could technically drip down. Probably better to eliminate one thing at a time anyways
Old 08-03-2021, 01:09 PM #548
jsluse jsluse is offline
jsluse is on a distinguished road
Please help. My truck has been idling real rough. I started working on different issues but noticed the coolant reservoir was empty. I put coolant in and it ran better. Next day it was empty again (not sure how low it was, there wasnít a puddle under the truck) and it was again running poorly, especially in reverse. Tach didnít vary, it was pretty consistent but it was a very rough idle, I added fluid (truck was cold this time) but noticed the VSC/TRACTION light was on as well as check engine. I know there is a small leak from radiator to transmission coolant, working on getting it fixed.
Would this cause the issue? Iím getting ready to do the timing belt and water pump.
2001 Limited with 252k miles.
Any help or recommendations would be great.
jsluse is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 01:24 PM #549
Endlessblockades's Avatar
Endlessblockades is just really nice Endlessblockades is just really nice Endlessblockades is just really nice Endlessblockades is just really nice
I'd stop driving and pause all other work until you investigate this further:
Y2K/E - SLOW AND LOW
Old 08-03-2021, 01:48 PM #550
It is from a shit job of being installed. The clamp is too big and loose. Replacing it tonight. I assumed Firestone installed it correctly but clearly they didnít and donít feel comfortable with them doing it again.
Old 08-03-2021, 02:09 PM #551
Oh, OK - I read that to possibly mean that engine coolant was leaking into the transmission cooling tank at the bottom of the radiator.
Old 08-03-2021, 02:10 PM #552
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Please help. My truck has been idling real rough. I started working on different issues but noticed the coolant reservoir was empty. I put coolant in and it ran better. Next day it was empty again (not sure how low it was, there wasn’t a puddle under the truck) and it was again running poorly, especially in reverse. Tach didn’t vary, it was pretty consistent but it was a very rough idle, I added fluid (truck was cold this time) but noticed the VSC/TRACTION light was on as well as check engine. I know there is a small leak from radiator to transmission coolant, working on getting it fixed.
Would this cause the issue? I’m getting ready to do the timing belt and water pump.
I would check your oil immediately if you havent. Do you notice any smoke from the exhaust? The intake manifold gasket could've corroded away between the coolant passage and intake port
Old 08-03-2021, 02:53 PM #553
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
What does your transmission fluid and engine oil look like?
2000 Limited V6 Auto E-Locker
Old 08-03-2021, 03:05 PM #554
Engine oil is clean, transmission fluid is clean. No smoke.
Old 08-03-2021, 03:06 PM #555
Also, when I put more fluid it, it runs smooth and the idle clears up.
extended , front , lift , rear , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 10 12-27-2019 08:02 AM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
