Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 08-03-2021, 03:57 PM #556
jsluse jsluse is offline
jsluse is on a distinguished road
Originally Posted by Devbot View Post
I would check your oil immediately if you havent. Do you notice any smoke from the exhaust? The intake manifold gasket could've corroded away between the coolant passage and intake port
No smoke at all. Oil is clean and looks good.
jsluse is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 05:17 PM #557
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by jsluse View Post
Engine oil is clean, transmission fluid is clean. No smoke.
What color is your engine oil and transmission fluid? Does the transmission fluid smell burnt?
Old 08-04-2021, 01:33 AM #558
Fluid smells fine, looks a little dark but doesn’t smell burnt at all.
Old 08-04-2021, 09:38 AM #559
Real Name: Patrick
Real Name: Patrick
This is like pulling teeth here... If you had to pick a color from a color wheel or paint chips at your local Lowes/Home Depot, what color would the engine oil and transmission fluid be?
Old 08-04-2021, 11:42 AM #560
HiLife HiLife is offline
I started working on different issues but noticed the coolant reservoir was empty. I put coolant in and it ran better. Next day it was empty again (not sure how low it was, there wasn’t a puddle under the truck) I added fluid (truck was cold this time) but noticed the VSC/TRACTION light was on as well as check engine. I know there is a small leak from radiator to transmission coolant, working on getting it fixed.
It is from a shit job of being installed. The clamp is too big and loose. Replacing it tonight. I assumed Firestone installed it correctly but clearly they didn’t and don’t feel comfortable with them doing it again.
Maybe Firestone didn't properly burp the cooling system and that is where your coolant went? Before you begin your day, remove the rad cap and top off the radiator, and fill the rad reservoir to the cold fill line. Then continue to monitor for coolant loss.
If you want to pressure test the system, you could find coolant dribbling from loose clamps through this. Pressure tool could be rented from Autozone (sku-449951, 940427T). Or Orielly (67085).
Old 08-04-2021, 12:46 PM #561
I’m sorry to be a pain or make this hard. It is something I haven’t worked on before and have limited knowledge. It is a pink color, Maybe fuchsia describes it best. Not light but not dark pink.
Old 08-04-2021, 12:47 PM #562
I have given up on working the system and taken to Firestone since the installed and warranty it. I hope that fixed the idle and will continue to troubleshoot from there if it doesn’t.
Old 08-04-2021, 10:01 PM #563
gHo5tRider gHo5tRider is offline
gHo5tRider is on a distinguished road
Thumbs up
yeah good call
gHo5tRider is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 03:48 PM #564
fathousecat_ fathousecat_ is offline
fathousecat_ is on a distinguished road
What's the part number for the crush washer when doing a drain and fill on the transmission? (5spd).
fathousecat_ is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 04:45 PM #565
CoCoCo4Runner CoCoCo4Runner is offline
CoCoCo4Runner is on a distinguished road
I’m shopping for replacement engines via car-part.com, I’ve got a 1998 4wd, I can swap anything in from 1998-2002 right? Is the only difference between motors going to be with the throttle body?
CoCoCo4Runner is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 05:44 PM #566
Real Name: Patrick
Real Name: Patrick
Don't quote me on this, but I'm pretty sure fuel injectors changed in 99. I would plan on reusing your original harness and injectors/throttle body
Old 08-05-2021, 08:35 PM #567
According to Toyota part numbers, heads are the same for 96-02.
But, for some reason the block is broken down to 5/97-1/99. And 1 /99-...
I don't know what are the differences between the two.
Old 08-06-2021, 02:48 AM #568
xXKILLAWHALEXx xXKILLAWHALEXx is offline
xXKILLAWHALEXx is on a distinguished road
Snorkel brand options
Ive been looking up snorkels for 98 my 4runner but all i keep seeing is safari and helix or however its spelled. Anyone know what other brands have snorkels for a 3rd gen? I was hoping to find something more boxed shaped rather than rounded out like that safari one. That one alpha equipt snorkel for the 5th gen looks sick! You guys think it'd be possible to find a way to fit it on a 3rd?
xXKILLAWHALEXx is offline   Reply With QuoteReply With Quote
Old 08-06-2021, 10:39 AM #569
Real Name: Patrick
Real Name: Patrick
Have you seen this snorkel yet? https://www.toyota-4runner.org/3rd-g...4-snorkel.html
Old 08-06-2021, 11:05 AM #570
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
The 3rd Gen All Questions Allowed Thread
I know you’re asking for a snorkel other than a Hilux, but this video will likely be helpful no matter which snorkel you end up with:
Hilux 167 Snorkel Install on a 3rd Gen Toyota 4Runner - YouTube
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
