Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 09-17-2021, 10:56 PM #586
5th4runner 5th4runner is offline
5th4runner is on a distinguished road
Originally Posted by Bad Luck View Post
The rear bump stops are located on the rear frame as seen in this picture: https://www.toyota-4runner.org/1286499-post1.html The cone bumper in the spring is a softer rubber than the frame bumpstop and meant to act as a cushion to slow the axle down some before contacting the stiffer/harder frame bumpstop. The cone bumper in the spring isn't entirely necessary and can be removed or trimmed as needed, but should not cause a problem if the spacer is placed between the spring and the cone.
Hmmm, that is interesting. The external bump stop you show should work then. The spacers are installed by pulling the cone out of the spring, inserting the cone into the spacers, then inserting the remaining cone into the spring. This adds a couple inches to the length of the spring, lifting the rear.
and no
5th4runner doesn't mean 5th gen.
5th4runner is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 02:03 AM #587
2002goldie 2002goldie is offline
2002goldie is on a distinguished road
Originally Posted by Endlessblockades View Post
I'm no expert but roughly calculated, the bigger size is about +1.5" in diameter and about .5" narrower, so you could visually add about .75" to the current tire where it comes closest to the fender/well while cycling lock-to-lock to get an idea of fit. Shouldn't have any UCA/spring clearance issues as you said. I'm not sure how to pre-calculate rubbing under suspension compression, however, but you say you don't expect to flex much. Not sure how you be able to resist hitting some trails though.......
Easily!! Closest legal/public land trails are 3hrs from home
Thanks for the reply!
2002goldie is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 10:15 PM #588
ehnat36 ehnat36 is offline
ehnat36 is on a distinguished road
3rd gen exhaust issue
Alright. This is my first post on here so be easy on me. I have a 3rd gen 99 4runner 2.7 liter. My tailpipe has now been “removed” from the main exhaust system for the 4th time now after owning it for 7 years. It’s been welded and rewelded on, and I think it’s time for a new base exhaust system. Has anyone had to do this? Did you DIY? Brought it into a muffler place? Avg cost? Trying to figure out what the avg cost could be (I am not a rich person) and how long I can go with the tailpipe secured w/ wire onto the frame 😅 (I know there are issues w idling/CO issues!) TIA!
ehnat36 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:50 AM #589
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
A good resource is the Search function. Scroll down the results a bit and you'll find lots of threads on the forum about cost-effective exhaust. Sounds like you should probably replace everything behind your Cat if it's original.
For example:
Best cost option for new cat-back exhaust system?
Old 09-20-2021, 09:09 AM #590
jcmb45678 jcmb45678 is offline
jcmb45678 is on a distinguished road
I am looking to lift my third-gen 4runner 3in. Does anyone know an estimate of the cost of labor for this typically?
jcmb45678 is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 10:26 AM #591
spartacus's Avatar
spartacus's Avatar
About $800 around here. More if you get the uca and diff drop.
Or $0.00 dollars if you do it your self.
ToyTec Boss Complete Suspension Lift Installation - YouTube
Old 09-21-2021, 08:29 PM #592
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Alright, after extensive reading through threads I’ve come to a certain idea for a conclusion but would also like to get other input.
My 01 with 305K on the clock exhibits this sort of “jumping” or “skipping” when around 50 mph, going up hill or just after driving for an extended period of time, like road trips especially. The info I’ve gathered is that it’s either related to plugs or coil packs. I replaced my plugs less than 30K ago, and I’ve got Denso plugs with Denso wires in there, so I’d like to think that isn’t my issue. But I’m curious about my coil packs. Still on the original Toyota/Denso ones. $150 for 3 new ones, not horrible but I’d rather not spend that if it isn’t needed. Any ideas?
Old 09-21-2021, 09:14 PM #593
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
You know those are supposed to be replaced with spark plugs, right? You're well overdue
Old 09-21-2021, 10:36 PM #594
tpelletier tpelletier is offline
tpelletier is on a distinguished road
2002 4R limited.
whats the low down with lower ball joints ?
Are you supposed to change them asap like a recall or after a certain number of miles ? is rockauto the place to go for this ?
also anyone know what kind of computer you need to read the engine light codes ?
tpelletier is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 11:12 PM #595
spartacus's Avatar
spartacus's Avatar
Take the plugs out and check their condition. Are tips worn covered in carbon etc. the gaps are good. Check the coil boots they might be worn causing a short at the block check the coil pack resistance Resistance
primary cold 0.67 - 1.05 Ω
Hot 0.85 - 1.23 Ω
seccndary cold.9.3 -16.0 kΩ
Hot 11.7 - 18.8 kΩ
Old 09-21-2021, 11:36 PM #596
spartacus's Avatar
spartacus's Avatar
Originally Posted by tpelletier View Post
2002 4R limited.
LBJ replacement every 100k or so miles or so, sooner if you off road. I've gone longer but I check for play every so often.
Oem from a dealer. lot of fake oems out there on ebay etc. There are dealers online that you can get two for around $200 but they don't come with a new Castle nut or cotter pin. If you buy them individually they come with castle nut and cotter pin but are little more money. Also order the right bolts for your year.
If you don't have the rubber dust cover, 8 flange head bolts torque 59ft lbs
If you do have the dust covers, 8 bolts with washers torque 37ft lbs.
Buy any decent Obd-II scanner then download Torque app on your phone or tablet and connect it via blue tooth.
Old 09-22-2021, 12:37 AM #597
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Would upgraded injectors help with leaning out at higher rpms, or is the only solutions adding a 7th?
Old 09-22-2021, 08:16 AM #598
Thanks everybody for the help. Results are in:
Used this spacer:
kt09107bk | Rear Leveling Kit -1-1/2 in | 4Runner 96-02| Daystar $42/set new.
Using these instructions:
https://www.daystarsuspensionparts.c...tar/p10503.pdf
Added the step of unbolting the parking brake cable bracket.
Forgot to unbolt the pan-hard bar on the driver's side. That made life difficult.
In addition to the floor jack it took the stock screw jack and a (small) bottle jack to adjust the axle up and or down on each side to jockey the springs.
The jack stand on the fuel tank side was a bit iffy (no room to straddle the frame, had to turn 90 deg.) so left the floor jack on the hitch beam at all times. It took a 4X6 on edge on the floor jack to lift the wheels off the ground from back there.
Took less than 3 hours including finding all the tools. What really helped was squirting penetrant into all threads a few days before, then loosening the bolts the day before without jacking up the vehicle. Took an impact wrench as things are rusty.
Everything went back in with a lot of waterproof moly grease.
Gave a bit less than the advertised 1.5" lift, didn't measure exactly.
and no
Old 09-22-2021, 09:11 AM #599
Thanks !
Also are LBJ only in the front or also in the rear ?
Are the front ones the only ones of concern ?
Old 09-22-2021, 10:56 AM #600
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Thanks !
Just the front .
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
