07-21-2020, 03:34 PM
#91
Shaking after 60
Hey, i bought my 01 2wd 4runner about 2 months ago, 330,000 and the engine still kicks ass. But he was having problems with it shaking slightly around 60mph. About 3 days after buying it, my lower ball joint failed, luckily i was only doing 10. Tire got sucked under the car and had to replace both joints and the tie rod on passenger side. Mother shook horribly I went and had the alignment done, and the tires rebalanced. It helped alot, but it is still shaking at around 60, and drifts hard to the right. U joints are good and i have very little play in my out put shaft. Im at a loss. Steering stabilizer, shocks? Any idea guys?
07-21-2020, 03:41 PM
#92
Question hear its quite the problem. Replaced my VSC computer module since the speedometer/odometer stopped work P0500 code. It fixed that code but since then i have not been able to drive the car due to the VSC kicking in and killing power to the car. It thinks it is skidding at all times (can't even leave my driveway). Tried to do a ZP calibration but it doesn't seem to want to calibrate, even tried getting a Toyota dealership to do it but no luck. Currently it has the C1336 code since i am unable to do a ZP calibration.
What i have replaced:
VSC computer module - tried 3 different ones from the junkyard
ABS wheel sensors (only the rear ones)
yaw sensor + deceleration sensor
Any help would be great! Thank you!
07-22-2020, 07:49 PM
#93
Could the pinouts be different? Seems like its not seeing the speedo signal
07-22-2020, 08:10 PM
#94
Woah, you got really lucky! Whew, glad to hear it.
Have you checked your sway bar end links? Mine was acting similarly until I realized that one of them had snapped. If those are good, check your bushings all around.
1998 SR5
07-22-2020, 09:07 PM
#95
Here is a link that was in my archives not sure if it would help nevertheless here you go.
https://www.google.com/url?sa=t&sour...S3le33wbxKnMbm
07-22-2020, 09:35 PM
#96
Oh the speedo works with the replaced VSC computer modules. It's just that i am unable to drive at all since i've replaced the VSC computer module. The original is actually dead in terms of the speedo/odo.
07-22-2020, 09:38 PM
#97
Originally Posted by spartacus
Thanks! Any thoughts if it would be the black box on the brake master cylinder?
07-22-2020, 10:38 PM
#98
Real Name: Keith
Real Name: Keith
Have you ruled out the wheel being bent?
07-22-2020, 11:32 PM
#99
Real Name: Keith
Real Name: Keith
[QUOTE=da_crew10;3500401
Also finished the valve covers last night.
Question from this pic how good or bad does it look?
253k miles
[/QUOTE]
The valve area looks perfect...exactly as it should look. Similar to my '97 at 120K.
07-23-2020, 10:03 AM
#100
Real Name: Mark
Real Name: Mark
yaw sensor + deceleration sensor...
What year Runner 01 02 ? if it is this applies:
There are two VSC modules available, both for 2 or 4 wheel drive. The kicker is one is for 15" wheels, one for 16" wheels.
Purchased 01 with bad VSC module, There's a reason (don't know why) 15" 16" makes a difference or the effects.
Use module your VIN specifies for OE wheel size.
You may have lucked out with a mix up, all I can think of, Good Luck.
07-23-2020, 10:43 AM
#101
Real Name: Patrick
Real Name: Patrick
Originally Posted by eddielasvegas
I did the TTTM special a few weeks ago. Drained 4.5 qts. from the pan and added about the same. It seemed to be shifting differently so I checked the fluid when hot and cold and it was way over filled. I suspect it was that way before I did a thing and shame on me for not checking the fluid level first.
I pumped out almost 2 qts. using the fill tube and it seems to be shifting normally. The fluid level is now just slightly above the top cold full mark when cold.
Getting an accurate dipstick reading when at operating temp (and engine idling) seems to be a challenge for me and a real PITA.
Anyhoo, here's my question: Can I use the cold fill mark to indicate the correct transmission fluid level?
Thanks,
Eddie
Cold fill level is to make sure you have enough fluid to operate the transmission in order for the transmission fluid to reach operating temperature for you to perform a hot level check. Make sure the vehicle is parked on level ground, transmission is at operating temp, engine is running, and transmission is in park for a hot level check.
Cold level check should be done on level ground, engine running, and transmission in park after spending 5-10 seconds in each gear selector position.
07-23-2020, 12:18 PM
#102
Real Name: Eddie
Real Name: Eddie
Thanks Bad Luck.
I was just checking it cold (like after sitting overnight) and not following those specific steps. I will do hot and cold check later today.
The main problem with a hot check for me was getting an accurate read on the dipstick. The fluid mark is not clearly delineated.
Thanks again,
Eddie
2001 T4R SR5 - 180k miles and counting.
07-23-2020, 04:02 PM
#103
Mines an 02 and I ended up getting the same part number as the original one. #89540-35270. Just don't know what to do anymore for it.
07-25-2020, 03:19 PM
#105
I ended up doing Andy MOD 2.0 which fixes the VSC problem of killing my engine power, but my abs still kicks in when i brake every time. Do you know where the ABS computer is located or is it the same part that i replaced?
