07-03-2022, 05:49 PM
#1186
Originally Posted by Devbot
If you think you don't need one, then you 100% definitely do not need one. You can argue it looks cool, to which I'd respond with: how often are you really sitting there parked, hood up, with your engine on display for others to see?
Agreed. With that said, do you run one?
07-03-2022, 08:15 PM
#1187
Real Name: Devan
Real Name: Devan
Not at all. If I wasn't naturally aspirated I might consider it
07-03-2022, 09:57 PM
#1188
Originally Posted by Bad Luck
It’s coming from above the head gasket so it’s most likely the lower intake manifold gaskets leaking which are time consuming to get to. Here’s another thread that you might find helpful: Lower intake manifold gasket replacement
Edit: to answer your question it should be addressed sooner than later as it will start leaking worse and could start leaking into the combustion chamber as well.
Thanks for the advice, I really appreciate it. I took a drive up the canyon this morning with the A/C on and noticed after my drive it did not drip at all. However, once the heat was on, it dripped a little. Found that there is some seepage from my Heater Control Valve/ the hose to it. I’ll end up replacing the valve + the hose most likely and see if that solves my issue. Thank you for the help!
07-03-2022, 10:05 PM
#1189
Real Name: Patrick
Real Name: Patrick
Good catch! I didn’t consider those coolant lines for the heater core. Might want to replace the heater core flow control valve while you are there, but lots of people report having problems with aftermarket valves.
07-03-2022, 11:38 PM
#1190
Real Name: Mark KN6TZI
I noticed a light coating of what appears to be oil in the intake tube today.
PCV & grommet were done with VCGs 6 months ago. Seems like if it was coming from PCV it would also be around that hole.
There's a tear at the top of the tube where it connects to the TB which I think is pretty common. Haven't been willing to spend $110 to replace it.
I don't recall seeing this before. Is it possibly "normal" at 250k+?
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
07-05-2022, 10:04 AM
#1191
Real Name: C8H18 Mike
Pretty normal, and you can get that piece off of eBay or Amazon for about 20 bucks. Just reuse your band clamps.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
07-05-2022, 10:05 AM
#1192
Clutch started slipping on my four-wheel drive, so I started researching the process as well as replacement parts.
Aside from ordering all factory, if I went aftermarket is there a preferred brand or performance level recommended for off-road use?
Factory replacement?
Stage 2 upgrade?
I already ordered a Timken throw out bearing since every kit that I've seen the main complaint is that the bearings are cheap crap
07-05-2022, 11:17 AM
#1193
Real Name: Patrick
Real Name: Patrick
Cross posting from my build thread to hopefully get some additional views/answers.
-My engine rpm’s remaining high while coasting in neutral is not normal (or at least this one didn’t do it).
Following up on this with (hopefully) a youtube video showing my coasting idle issue. I apologize for the terrible and shaky video quality. Audio isn't needed unless you enjoy listening to wind noise. Video shows coasting in neutral from 60 mph to a full stop. AC is on during the coast, but the only difference I've noticed between ac on and off during coasting is the rpm difference once stopped. AC on stopped idle rpm is 100-150 higher than ac off stopped idle rpm. No dtc's set or pending and it's done this since the day 1 of my ownership.
Any insight or help would be greatly appreciated.
2000 Toyota 4Runner 5spd/5VZ neutral coast from 60mph to stopped - YouTube
07-05-2022, 11:50 AM
#1194
Did you take.it out of gear while coasting and use your brake to slow down
680 rpm at idle.isnt terrible...
07-05-2022, 12:14 PM
#1195
Real Name: Patrick
Real Name: Patrick
It's in neutral (out of gear) coasting. If you watch the video you will see that the coasting idle is much higher than stopped idle. Stays around 1300 rpm while coasting until I am stopped for a second or two.
07-05-2022, 02:00 PM
#1196
I saw that, I will recreate in my truck tonight and report back but when I take it out of gear it returns to ideal RPM - I know this because I coast often and have to bring my RPM up to shift back into gear
07-05-2022, 03:25 PM
#1197
is there anyone whose added the 99+ headrest holders into an earlier year? I got the holders but don't see anyone on the forum who has, do you just measure and drill into the seat?
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
07-05-2022, 04:05 PM
#1198
official vendor
official vendor
I got a couple of '99+ rear seat backs to make this work. I would not try to drill into the seat back.
07-05-2022, 04:09 PM
#1199
official vendor
official vendor
I found some remnants of oil under the hub cap, when doing my axles this weekend. I'm assuming that's from the front bearings, which means that the bearings are now losing oil?
07-05-2022, 04:10 PM
#1200
Yeah I was thinking the same thing unfortunately the seat backs at the junkyard were destroyed hence me only grabbing the plastic parts, we'll see, worst case I'll disassemble the seat at the PNP next time they have a 99+ and just buy the bottom part of the seats.
281k Miles
Build Thread
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
