Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 07-05-2022, 04:30 PM #1201
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Spiker Engineering View Post
I found some remnants of oil under the hub cap, when doing my axles this weekend. I'm assuming that's from the front bearings, which means that the bearings are now losing oil?
Probably just excess bearing grease getting warm enough to flow out. I'd clean it up and not worry about it
Old 07-06-2022, 09:57 AM #1202
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Sounds good, thanks .
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 09:58 AM #1203
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by octanejunkie View Post
Clutch started slipping on my four-wheel drive, so I started researching the process as well as replacement parts.
Aside from ordering all factory, if I went aftermarket is there a preferred brand or performance level recommended for off-road use?
Factory replacement?
Stage 2 upgrade?
I already ordered a Timken throw out bearing since every kit that I've seen the main complaint is that the bearings are cheap crap
Sent from my Pixel 4 XL using Tapatalk
Decided to go Aisin
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 01:22 PM #1204
EDIT: ordered Toyota RMS from dealer
PN: 90311-A0027
Old 07-06-2022, 01:49 PM #1205
chunkie chunkie is offline
chunkie is on a distinguished road
Small spacers?
I own a 2wd 3rd gen and I recently swapped the 28.9s with 30.6s I'm getting some light intermittent rubbing on the UCAs when I turn and the suspension is depressed. Could I put on 10mm or 5mm wheel spacers to fix this issue?
chunkie is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 10:28 PM #1206
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Not that thick, no. The highest you really wanna go is about 1/8" (~3mm), which you can actually find hub-centric and in our lug pattern. I got some off ebay a while back that I think ran $10 a pop or so, but they're really more intended to fix rubbing on the brake calipers instead of the UCA. For the price I'd consider it worth a shot though - they're sometimes called "shims" instead of spacers at that size, which might help in your search
If an alignment doesn't help either (which I think would be a stretch but you never know) then your best option would be Spidertrax spacers or new wheels with different offset - assuming you didn't already get some with the new tires
Devbot is online now   Reply With QuoteReply With Quote
Old 07-06-2022, 10:36 PM #1207
What tire size did you install, exactly, and on which wheel?
Diameter is only one part of the equation
There is no way to give you accurate, conclusive advice with the info provided
Old 07-07-2022, 12:31 AM #1208
Real Name: Patrick
Real Name: Patrick
Decided to go Aisin
Since you’re doing the slave cylinder I would highly recommend replacing the master cylinder too while you have the system open. Just my $0.02
Old 07-07-2022, 02:02 AM #1209
Aisin CMT-093 ordered
Old 07-09-2022, 01:54 PM #1210
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Might be dumb to ask but is there any reason the OEM diff lock switch wouldn't work with an ARB?
Old 07-09-2022, 02:58 PM #1211
Real Name: Patrick
Real Name: Patrick
I can’t remember for the life of me if the oem switch is a two position switch or a momentary switch. (An example of a two position switch is the power/normal etc button for autos.) If it’s a two position switch then it should work. If it’s a momentary switch then I’m not sure how you would be able to make that work.
Old 07-09-2022, 03:38 PM #1212
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
I run the OEM switch for the ARBs but I also picked up a cluster that has the AWD pic in said so that when I push the OEM locker switch/es the lights on the
front or rear of the display shows which lock is on. U just run the OEM switch too a relay.
clearock is offline   Reply With QuoteReply With Quote
Old 07-09-2022, 04:16 PM #1213
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Yeah I plan to use a relay so I can get the factory dash light to come on as well, I figured it should work fine but I've been screwed by electronics more than once so better ask instead of order a switch unnecessarily. A dash swap would be a nice touch, I do like that little center display 01-02 got...
Old 07-09-2022, 05:33 PM #1214
Real Name: Patrick
Real Name: Patrick
99/00 Limiteds have the same 4wd display as 01/02’s by the way in case you didn’t know
Old 07-09-2022, 06:47 PM #1215
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I did not, very tempting.. Does the odometer stay correct? I don't wanna lose my high score!
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
