Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 06-06-2020, 12:03 PM #61
da_crew10's Avatar
da_crew10 da_crew10 is offline
da_crew10 is on a distinguished road
da_crew10's Avatar
Was not able to get my 3rd gen aligned with 2.5 inchlift up front. They said the camber was at +1 . Is that typical out of a 4runner? My 1st gen tacoma with factory uca and 2.5 inch lift aligned just fine.
da_crew10 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 12:12 PM #62
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
I'd check the before and after and c if they even touched ur camber bolts... if they legitimately can't, id check that ur control arm bushing aren't shot... the only issue u should be having (assuming ur not running aftermarket UCAs for said) is caster. who did the alignment?
clearock is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 01:39 PM #63
Venka93's Avatar
Venka93 Venka93 is offline
Real Name: Veniamin
Venka93 is on a distinguished road
Venka93's Avatar
Real Name: Veniamin
This can happen when the chamber adjusting sleeves get frozen inside the lower control arm bushings. I’m in the middle of changing my LCA bushings and one of my sleeves was a pain to get out.
Venka93 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 03:46 PM #64
da_crew10's Avatar
da_crew10's Avatar
Will check those out. They said they were checking the lca bushings to see if they were shot and they said they appeared good. Im going to check that next to make sure its not stuck.
Anyway never ending story with this new rig. Was taking a drive with the family to go hike. About halfway the 4runner started overheating (90 degree weather and pretty hilly road, not that it should matter). I stopped to let it cool down, upon opening the hood i hear the overflow bubling hot with coolant.
Once cool went back on the road. Started over heating again so i stop to let it cool down. This time I turned the ac off once I got back on the road and it did not overheat at all. I tested to see if this was the reason it was overheating once I got 5 miles close to home I turned the ac back on and behold it overheated again but started to cool down once I turned it back off.
Got home pulled the cap and it had no retention and no visible spring, also looks to be the oem cap and radiator if that info matters. I checked my 1st gen tacoma cap and it has a spring that compresses when closing the cap on the radiator.
What could be causing this? Thermostat is my guess, maybe radiator fins clogged? Radiator cap?
Old 06-07-2020, 12:19 PM #65
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Too many details left out.
How much coolant was in the radiator?
Was the fan spinning properly (fast)?
It sounds to me like your coolant level is most likely low. Or less likely your fan clutch failed.
Low coolant could be caused by many different issues.
In the future if your rig runs hot and you need to limp home. Turn the AC off, turn both the front and rear heat on high, roll the windows down if needed, put the tranny in D, turn overdrive off. The idea is to maximize cooling capacity and to reduce heating capacity to help the rig get you home.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 12:23 PM #66
Radiator could be clogged. Should be able to drain till you can see the tops of the channels in the cap.
And don’t try to overheat your rig. That’s not a good testing method.
Old 06-07-2020, 02:42 PM #67
da_crew10's Avatar
da_crew10's Avatar
Thanks for your insite. It was fairly low somehow on coolant. The radiator cap was not in working order. Filled it up, took some air out, put the new cap and hasnt overheated since. Wish me luck that it stays like that.
Old 06-07-2020, 10:17 PM #68
When the rig is cold and radiator completely filled, fill your expansion tank up to exactly the line.
Then every morning when the rig is cold check the expansion tank.
If the level keeps dropping your consuming (loosing) coolant.
You can limp it along like that by keeping the expansion tank filled. The radiator will suck in coolant as it cools.
Assuming your rig isn’t losing coolant to fast.
Then you need to find the issue. Common issues are leaking water pump, leaking head gasket, leaking heater controll valve, rusted and leaking rear heater core lines, hoses, ect....
Old 06-08-2020, 02:54 PM #69
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like your radiator cap failed and wouldn't hold pressure. Coolant boils at a higher temp under pressure. Without a working radiator cap to allow it to build pressure your coolant will boil a lot sooner. When's the last time the radiator was replaced?
Old 06-08-2020, 04:35 PM #70
da_crew10's Avatar
da_crew10's Avatar
That explains the boiling sounds. As far as the radiator looks like the factory unit to me. Why do you ask?
Old 06-08-2020, 07:22 PM #71
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
when was the last time timing belt, waterpump and thermostat replaced. Same with radiator. Some say replace radiator every 10 years...esp if an automatic to help avoid oink milkshake and trashing your tranny.
Lots of debates on all this..like only use Asin h20pump and factory thermostat and radiator cap. And many say only use denso or factory radiator.
And radiator jiggle valve needs to be at 6am.
Super low on fluids...might need to burp it...youve got lines higher than the radiator cap and when burping have rear heater on. However some dont burp and just keep adding fluid till it burps on its own.
Old 06-08-2020, 10:32 PM #72
da_crew10's Avatar
da_crew10's Avatar
Guy I bought it from showed me proof of new belt water pump and tensioner pullie about 8k miles ago. Pretty sure they were not oem components though. Oem all the way from here on out on my 1st gen tacoma and 3rd gen 4runner. Learned my lesson.
Old 06-09-2020, 09:52 AM #73
Real Name: Patrick
Real Name: Patrick
If the transmission cooler in the radiator fails then coolant and transmission fluid mix causing the dreaded "pink milkshake" in the transmission. 99.9999 percent of the time it leads to total transmission failure and replacement. A good rule of thumb is replace the radiator every 10 years or 100k miles if you decide not to bypass the in radiator transmission cooler and use an external cooler. Keep in mind that the radiator can visually look good on the outside but you have no way to inspect the transmission cooler components in the radiator. They are subject to a lot of vibration which seems to be the main culprit.
Old 06-13-2020, 02:30 AM #74
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
wheel backspacing?
Still rocking stock suspension for the moment, and currently looking into new wheels after recently buying some Goodrich A/Ts, but know nothing about sizing let alone fitment. I'm thinking about swapping the stock rim size for some 16x8 wheels - but how do I know to chose between 4.25in and 4in of BS? Do either require trimming, spacers, etc, or will it clear alright as-is? Anybody have comparison pics? Believe the tires I'm buying are 275s, if memory serves me right.
FYI I do plan to buy a 3in OME kit, just got a really good deal on these and would preferably like to do it asap (desperately need an alignment)
Old 06-15-2020, 12:29 PM #75
da_crew10's Avatar
da_crew10's Avatar
To run on a factory suspension you will need to hammer pinch welds, now what height is the tire? 275 is just the width, and with that width you will need spacers to not rub the uca.
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
