Old 01-10-2021, 05:59 PM #211
Smog-guy707's Avatar
Smog-guy707 Smog-guy707 is offline
Smog-guy707 will become famous soon enough Smog-guy707 will become famous soon enough
Originally Posted by BigDummy View Post
Has anyone on these forums ran the LC Engineering Valve Train upgrade for the 3.4L?
High Performance Pro Valve Train Kit 5VZ
any real benefits? Does this allow the motor to safely hit higher RPMs?
I have been wondering the same thing. Cuz I have a spare set of heads, that kits looks tempting
Loading....
Smog-guy707 is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 06:32 PM #212
spartacus's Avatar
spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all
spartacus's Avatar
Originally Posted by thatoneguy View Post
Toyota 4Runner Wheel Specs: Lug Nut Torque, Hub Bore, Bolt Pattern & More | Sparky Express – Sparky Express Roadside Assistance
This chart, unless it is overly-simplified, makes me think I can use my (acorn style?) lug nuts putting 2020 TRD Offroad wheels on my 1999 Limited, and that everything else is the same. Anyone know definitively?
5th gen and the 3rd Gen lugs are identical. sorry about holding my tablet upside down but I put the lugs back on so it will have to do. Hope it helps.
The 3rd Gen All Questions Allowed Thread-20210110_150321-jpg
Old 01-11-2021, 09:32 PM #213
Bcaskey Bcaskey is offline
Bcaskey is on a distinguished road
I had my radio antenna ripped off in a car wash, now every time I turn on or off the car the motor to raise the antenna (which is no longer there) runs for about 25 seconds. Is there a fuse I can pull to stop that from happening?
Bcaskey is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:34 PM #214
That same car wash also ripped my 4Runner emblem off the back of the truck. I recovered the actual emblem from the car wash, the emblem got split in half and I'm trying to figure out the best way to stick that thing back on. Is there a good product for reattaching emblems to the paint?
Old 01-11-2021, 09:36 PM #215
Skulking Skulking is offline
Skulking will become famous soon enough
There isn't a fuse which is isolated to only controlling the antenna motor. The best thing I can think of is disconnecting the power cable which is one of the plugs on the back of the radio.
Skulking is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:42 PM #216
That sounds like a possible solution. I've also heard you can unplug the motor itself by going into the fender but there's a bunch of those black one-time-use clips to get through so I don't know if there's a trick to working with those or not.
Old 01-12-2021, 12:47 AM #217
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Endlessblockades has a spectacular aura about Endlessblockades has a spectacular aura about
Mine stopped working - about a month after I bought the truck. After reading that it was a common problem here on this forum, I watched it each time and I watched it die. My poor motor cycled 23-25 times trying to extend the antenna and continued to do so after I pulled the antenna out with a yank. Long story short - I went through the rear of the fender / door jamb and unclipped the motor's power connector and left everything zip tied up in there. I undid those fender liner clips to get at a couple of fender bolts (the whole fender needn't come off, of course) and there were 2-3 in the door jamb/hinge area. It's not bad. I had a box of like 200 clips/fasteners I got off Amazon - google them, they are super cheap and come with an extraction tool. Like this: Amazon.com: GOOACC 240PCS Bumper Retainer Clips Car Plastic Rivets Fasteners Push Retainer Kit Most Popular Sizes Auto Push Pin Rivets Set -Door Trim Panel Fender Clips for GM Ford Toyota Honda Chrysler: Automotive There are better kits, I wasn't real picky.
I even used one to plug the hole in the collar where the antenna was. Getting to the back of the radio looked like more work to me and I read that the faux wood plastic on the Limited is easily damaged.
2000 E
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 01-12-2021, 12:59 AM #218
98snowrunner 98snowrunner is offline
98snowrunner is on a distinguished road
Lookin to lift my third gen i know there is endless options but I'm curious if anyone has used a monroe quick strut for a 1st gen tundra on the front of the 3rd gen? Will it lift it 2 inches or so or does a guy have to get a actual oem tundra coil with a bilstein 5100. Tight budget
98snowrunner is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 01:20 PM #219
4skeeter's Avatar
4skeeter 4skeeter is offline
4skeeter is on a distinguished road
4skeeter's Avatar
I’m getting ready to replace my inner and outer tie rod ends. I know that the outer tie rod ends are different and specific to each side, but are the inner tie rod ends the same? Like i can just order two of the same inner tie rods and they can go on either side? Thanks to anyone that can answer this.
4skeeter is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 01:46 PM #220
spartacus's Avatar
spartacus's Avatar
Yes.same part number for both sides.
Old 01-14-2021, 03:51 PM #221
Dragon_EX Dragon_EX is offline
Dragon_EX is on a distinguished road
Wish I could start a new thread for this but I'm a new member so I'll try to keep it short here. Getting code P0136 after getting a new front cat and rear O2 sensor. Long story short, had to get a new catalytic converter after getting P0420, replaced the O2 sensor as well, then was getting P0171 which is system too lean, turned out to be old crusty vacuum lines but before it got fixed we guess the engine was dumping unburnt gas into the new cat, which had to be replaced again (under warranty, thankfully!). Now getting this O2 sensor code. Is the O2 sensor fried too?
Dragon_EX is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 12:57 PM #222
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Hate to start a new thread for such a simple question:
If I am swapping rear axles (which entails removing rear brake line fittings), am I OK to just bleed the rear brakes when I re-assemble?
Or do I have to bleed all 4 corners
2000 SR5 4x4, Auto | Millennium Silver and Moon Mist | Geared and Locked | Jeep JK springs, Bilstiens/ BTF Fab | Shrockworks skids | Onboard Air | Manual Hubs | Alpine Audio
WeakSauz is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 01:20 PM #223
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light
Real Name: Patrick
You can bleed just the rears as long as the master didn't go empty. I use silicon plugs to cap the brake lines off whenever I have to remove brake lines. Amazon.com: 40 Pc 1/16" to 3/4" High Temp Silicone Rubber Tapered Plug Kit - Powder Coating Custom Painting Supplies: Automotive
2000 Limited V6 Auto E-Locker
Old 01-19-2021, 02:25 PM #224
bmwahba46 bmwahba46 is offline
bmwahba46 is on a distinguished road
Guys, I'd like to start a new thread but unable currently.
I am aware that my valve covers are leaking. They have been for about the past month, but I've never seen oil under the truck to this degree. I plan to repair the valve cover gaskets and all the associated parts first. But is it normal for this amount of oil from a VCG leak?
I first noticed it on my skid plate. I have taken some photos. But can anyone give some input what might be the common causes for this?
Leak - Album on Imgur
bmwahba46 is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 02:34 PM #225
Yes, it's possible that all of that is from your valve covers, over an extended period of time leaking. It's rare that these oil pans leak, so Im betting that once you do your VCGs and clean everything up well, you'll notice that it stays clean under there. Start with the VCGs
extended , front , lift , rear , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 10 12-27-2019 08:02 AM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
