Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 01-22-2021, 08:49 PM #226
Cycleandsurf Cycleandsurf is offline
Cycleandsurf is on a distinguished road
Bought a ‘96 4Runner 4x4 SR5, glad to be in the community.
It has some oil leaks which I’m figuring out tomorrow with oil dye. However I can’t figure out where the car’s squealing is coming from.
The squeal happens when these factors are met:
(1) I’m going 25+ MPH
(2) I let off of the pedal OR
(3) I’m barely on the pedal
It squeals like crazy! Is it belts/bearings or could it be something else??
Cycleandsurf is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 09:22 PM #227
spartacus's Avatar
spartacus's Avatar
The drive belts specially the AC belt has been known to squeal. Make sure they are in good shape and tight.
Here is a video courtesy of @mtbtim https://www.youtube.com/watch?v=Zi1XfFUOjKc&feature=youtu.be
Old 01-25-2021, 07:35 PM #228
cas5259 cas5259 is offline
cas5259 is on a distinguished road
I’m pretty sure I have a rear main leak. Just did valve covers and resealed the oil pan. The top end is dry now, but there is still a slow drip from the bell housing.
Does the whole trans have to be taken out, or is there room to slide it back a bit to access the RMS?
cas5259 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 07:51 PM #229
spartacus's Avatar
spartacus's Avatar
You'll have to remove the flex plate so yeah.
Old 01-25-2021, 08:53 PM #230
Smog-guy707's Avatar
Smog-guy707 Smog-guy707 is offline
Smog-guy707 has a spectacular aura about Smog-guy707 has a spectacular aura about Smog-guy707 has a spectacular aura about
Yeah the trans has to come out.
Loading....
Smog-guy707 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 09:50 AM #231
Rhino85VT Rhino85VT is offline
Rhino85VT is on a distinguished road
"If it’s going to be your daily, then buy something that’s in good running shape and only needs work like listed above that can be tackled on weekends when funds allow.
Make a list in order of importance and spend a car payment each month buying the parts and working through the list."
I can relate to all of this. I also do all my own work. The way I see it, Buying a specialty tool that costs as much as paying to have the work done just adds to my knowledge and tools arsenal.
Rhino85VT is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 10:00 AM #232
I have a 2002 t4r. I currently working on the rear wheel bearings/seels. I am baffled by a strange problem. I can't get one of my axles to slide BACK INTO THE SPLINES! Please Help!
I have the 3rd member out because I wanted eyes on the spline when trying to slide it in.
The other axle slides on both sides without issue.
The problematic axle is the one that came out and has not been dropped/damaged. There is NO visible damage.
Old 01-26-2021, 11:30 AM #233
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The axles slide into the 3rd member. You have to have the rear differential fully installed before installing the rear axle shafts.
Old 01-26-2021, 11:44 AM #234
I fully understand this. I'm trying to diagnose why the axle won't slide in.
Old 01-26-2021, 12:18 PM #235
Real Name: Patrick
Real Name: Patrick
You said you have the differential out while trying to slide the axle in correct?
Old 01-26-2021, 12:32 PM #236
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Sounds like there is some sort of damage to the axle shaft end. If it came out of the 3rd member and then you did bearings and retainers and no longer fits the splines, than the splines on the axle must be damaged, maybe you can clean it up with a small set of files. Maybe when you did the work you deformed the end some how.
What was your method to do the bearings, abs rotor and retainer's?.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 12:34 PM #237
Yes because I wanted to eliminate the possibility of the abs/retaining ring be in the way and to confirm it is the splines not sliding. Everything I searched suggested the ring was not seated properly. I already have the entire housing on the bench so it didn't take much to remove the 3rd and have a look.
Old 01-26-2021, 12:37 PM #238
Originally Posted by Malcolm99 View Post
Sounds like there is some sort of damage to the axle shaft end. If it came out of the 3rd member and then you did bearings and retainers and no longer fits the splines, than the splines on the axle must be damaged, maybe you can clean it up with a small set of files. Maybe when you did the work you deformed the end somehow.
What was your method to do the bearings, abs rotor, and retainer's?.
I think you must be correct about this. I was very careful not to damage the splines but I did not cover them with anything while I was using the press.
Old 01-26-2021, 12:40 PM #239
I did use a file and that didn't work. I cleaned it very thoroughly with a wire brush on an angle grinder.
Old 01-26-2021, 01:15 PM #240
Real Name: Patrick
Real Name: Patrick
Post a picture of your abs ring and retainers of that axle
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
