04-09-2021, 09:54 AM
#346
Real Name: Leif
Real Name: Leif
Originally Posted by Endlessblockades
Oh for sure, I wasn't really tripping on the price - just goofing around. If you had the money on hand, I'm all for it. Money comes and goes but a good Toyota motor is forever (almost).
's all good man. that did prompt a bit of contemplation on what exactly we wanted out of that truck, and fortunately too in an odd way, that cratered engine prompted the purchase of the 4R, which -- shhhh -- is now my favorite vehicle. don't tell the truck.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
04-12-2021, 03:56 AM
#347
Mystery leak
Hey guys i got a bit of a problem. I flushed out my radiator and put new coolant. Then the next day i notice a puddle under my front end. Took a quick look and it seems to look like its coming from behind one of the pulleys near the alternator. Oh sorry. I have a 98 2wd 3rz 4runner. Then again i really didnt have the time to actually do some digging in there. Since i have a new born kid. Anything helps guys. Let me know what if could be. I was thinking water pump. But i could be wrong.
04-12-2021, 10:45 AM
#348
I don't have the 4 cylinder but it does sound like the water pump took a crap. How did you flush it? Just a drain and fill?
2000 4Runner Limited 4x4 V6
04-12-2021, 11:55 AM
#349
Could be a bad thermostat gasket also.
04-12-2021, 03:27 PM
#350
I drained the coolant then flushed it with distilled water untill clear water Compass out. Then filled up the radiator with coolant. Ill also take a look at the thermostat
04-12-2021, 04:53 PM
#351
Real Name: Patrick
Real Name: Patrick
How were you draining the coolant?
04-12-2021, 06:53 PM
#352
Came out*
04-14-2021, 09:12 PM
#353
Real Name: Devan
Real Name: Devan
Longer wheel studs aren't required for 1/4in spacers, right?
What if I don't need the 1/4in, what's stopping me from using washers? (I like my backspacing as is and am trying to change it as little as I can)
I'll explain quickly below but very long story short, my wheels brush against my calipers but instead of grinding them down more I'm trying to add just the slightest gap.
Brief tl;dr - Bought new wheels a while back and they didn't fit despite being told by the store they would. I didn't notice it at first and tried to drive, and rubbed the shit out of my brakes. So I took off the wheels, sanded the backs of the spokes (to clean them up; left a big burr visible from the outside) and ground down my calipers quite a bit to get them to fit. Worked great. But now I've rotated my tires and since the clean wheels are up front now and the back of the spokes never had metal rubbed off, they brush against the calipers whenever I brake hard like on a steep decline. Instead of grinding on the wheels and potentially messing with the balance, or grinding on the brakes more than I already have, I'm looking for a way to add maybe 2-3mm of space just to help things clear.
04-15-2021, 08:41 AM
#354
Real Name: Patrick
Real Name: Patrick
Washers will be of varying thickness enough to make your wheel wobble. Some washers will compress more than others when you torque the lug nuts down further causing more wheel wobble. Also with washers you may or may not have the wheel bore centered by the hub bore if the washer spacer difference is enough. Safe bet is using machined spacers.
04-15-2021, 10:17 AM
#355
Lift kit
I currently have a 01 4runner and I'm looking to lift in 1-2 inches whats the best kit to go with with a lower budget.
04-24-2021, 01:36 PM
#356
Does anyone's shifter produce a "click" sound when applying the brake? 01' SR5 4WD. I don't remember it always doing this, maybe it's a new sound?
Edit: it only does this sometimes
04-26-2021, 10:34 AM
#357
Real Name: Patrick
Real Name: Patrick
That's the shifter interlock unlocking so you can shift out of park.
04-26-2021, 07:51 PM
#358
Hey All,
Been searching the forums using multiple keywords to expand my search.
I bout 4xinnovation rock sliders and during the prep (measuring etc.) We made sure that at full lock the front of the slider was clear from the wheels.
However, when we moved the sliders back to clear the rear lower portion of the fender flares were in the way.
Have others ran into this, and what has been your solution? I have been looking for pics so I can get an idea of what to do there and how it looks.
All the help is much appreciated.
99' SR5 3.4 V6
Front Plate LED Bar || 285/75/16 || Interior/Exterior LED's || Kenwood HU || Rockford Fosgate P300 - 12T || 2" Lift || AVS Hood and Window Deflectors
04-27-2021, 06:17 AM
#359
Even while driving?
04-27-2021, 08:46 AM
#360
Real Name: Patrick
Real Name: Patrick
Even while driving?
Well that changes things. Does the shifter have a lot of slack in it?
