05-06-2021, 07:29 PM
#391
Real Name: Devan
Real Name: Devan
Originally Posted by spartacus
Because if animals or kids ingest it BAD!
That'll teach the neighbor kids to mess around in my yard
05-06-2021, 10:32 PM
#392
Any ideas on where to find part # 0043S-35968?
This is the "toyota" script on the right rear of the liftgate on a 1998.
McGeorge says it's discontinued. Thanks.
05-07-2021, 01:29 PM
#393
The 3rd Gen All Questions Allowed Thread
Maybe try Toyota Part Number 7544216530 ? It's not the same year/model but it might work.
The PN you listed doesn't yield any results for me either. In fact, the 1998 4Runner emblem diagram doesn't even show a "Toyota" name plate (see screenshot).
There are also many matches on eBay. Of course they're knock-offs, but that might be OK for an emblem. For Toyota Logo emblem badge sticker CAMRY COLLORA 4RUNNER Chrome Plated | eBay
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
05-07-2021, 06:17 PM
#394
Sooo any thoughts on a mild non lifted diff drop? Would it hurt anything?
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
05-07-2021, 10:52 PM
#395
Real Name: Mark KN6TZI
Originally Posted by photoleif
i couldn't find anywhere willing to take the coolant...
I loaded up all those jugs along with 12 quarts of used oil and took it all to the household hazardous waste dropoff a few miles from the house. Guy made me roll up my window before he'd talk to me but he took everything right out of the back of the Runner, including the old radiator and the cardboard box it came in. And it was free.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
05-08-2021, 10:19 PM
#396
Yet another tire question, hated to start a whole new thread but looking for some opinions and to see if I figured the size correctly.
I have a 2000 Limited, picked it up with 265/75/16 garbage tires that are loud and bumpy as hell. It's not so much a daily driver (fly for work out of town mainly) so normal errands in town and then camping/exploring/kayaking will be its main use. Figured an All-Terrain tire would be best for now, I plan to add some lift down the road but that's gonna be a bit, will then move this wheel/tire combo to a 93 yoda pickup.
It appears to have a bit of a spacer for leveling added as well as some wheel spacers. I picked up some used TRD PRO rims in grey (17x7 4.5 backspace Offset 4 - specs from previous owner)
The Falken Wildpeak A/T3W's seem to be a favorite but I have always been a fan of Yokohama tires for sport cars so I've been looking at the GEOLANDAR X-AT's as well...no idea if they are any good though.
So finally the questions lol!! Does anybody have any experience with the Geolandar X-AT's? Lots of rain here so need to perform well wet and plan to see some snow as well. Going up to 17x7 was thinking 265/70/17 would be about the same size. Not sure if I can go any larger without having issues, current setup does not rub.
Any advice on tires and sizes would be appreciated, and here are some pointless pics!
05-08-2021, 10:23 PM
#397
Real Name: Leif
Real Name: Leif
that's great. elsewhere in colorado there's proper / awesome support for hazardous-waste disposal; where we are now, if it's not oil or lead, support is scant if at all. crazy...
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
05-09-2021, 12:24 AM
#398
Yokohama geolanders are great tire. I've had G015 and they are great tire. The mts are all so good so the xat might be a good option.
05-09-2021, 12:27 AM
#399
Sounds about right!
05-09-2021, 09:25 AM
#400
Thanks for the help!
05-09-2021, 10:00 AM
#401
Real Name: Devan
Real Name: Devan
These are what I'm buying next. Have yet to hear a single bad thing about Geolandars and the X-A/Ts are supposedly between a normal A/T and M/T. I forgot who but some user here has been dealing tires for almost 2 decades and highly recommended them along with many others people, especially over Widepeaks (I'm also currently using some like you) which apparently have a problem staying round.
05-09-2021, 10:06 AM
#402
Are you asking about doing a 1” front differential drop on a stock-height 4Runner?
I don’t know that it would hurt anything, but I also don’t know what you’d gain. AFAIK, you only need a diff drop once a lift gets high enough to make your CV angles too extreme, leading to at best reduced droop, at worst premature wear or failure.
At stock height, the CV angles are as-designed (ideal).
I have about a 1”-1.5” lift in the front and I don’t need a diff drop. But it seems like the consensus on this forum is once your lift gets higher than 2”-3” or so, you’ll want a diff drop.
Is there a problem you’re trying to solve or just curious?
Maybe someone with more info will chime in.
@Y2K_4X4
05-09-2021, 11:01 AM
#404
Real Name: Devan
Real Name: Devan
Indeed the one. Maybe he has more to say on them.
I've enjoyed my Falkens so far, but I've had them for less than a year and they're already significantly worn down. Come to find out this a common complaint. Very eager to try Geolandars, hopefully they last longer. I have a feeling I'll be in need by new years at this rate.
05-09-2021, 03:55 PM
#405
I love yokohama , the really are a great tire in all variants. The age old question of which tire to choose always comes down to goals and priorities. There is no perfect Tire. You just have to realistically evaluate what you truly need in a tire.
The Xat is a great option if you land somewhere in between the realms. Remember the phrase jack of all trades master for none. Tires are subject to this concept. Feel free to ask if you have specific questions.
If needed I'll post pictures of both sets of geolander Mts and mileages
2000 highlander millennium silver, 214k elocker , 4:30 grey interior, ICON #700 coilovers , ICON delta joint UCA,LC 8.25 wraps, toytec diff drop(placebo mod), 295/70-17 yokohama MT, black rhino rumble wheels 17x8.5 -22,
Coastal high clearance front bumper, 4xinnovations sliders. More to come bought it 3 months ago bone stock.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
