08-02-2021, 01:18 AM
#541
Real Name: Devan
Real Name: Devan
1) anybody know what this part of the power steering is? It's the culprit of my leak and I'm curious what involves fixing it. I assume there to be a gasket of sorts that's gone
2) if that's not feasible without replacing the rack, could I potentially use ATF with stop leak to hold off for the time being?
08-02-2021, 01:58 AM
#542
Where exactly do you think it is leaking from? How sure are you that leak is coming from the power steering? From what I can see, it looks like you have fluid above the high point of the rack.
08-02-2021, 08:41 AM
#543
Real Name: Devan
Real Name: Devan
Right where the shiny spot stops at that bolt/flange. Pretty certain its coming from there, I have a valve cover leak too that was making the rack dirty but I also noticed a constant, slow loss of PS fluid (ATF) too - so I cleaned and dried everything, and after a day or two I found a drip leading back up to the flange pictured. Color is hard to tell since it gets dirty but seems to be reddish.
08-02-2021, 10:02 AM
#544
No fluid runs up that high. I'd be looking for something above that point dripping down.
08-02-2021, 11:27 AM
#545
Looked like this when my driver side valve cover was leaking. Check bolt torque
1998 4runner SR5
08-02-2021, 04:05 PM
#546
I had a leak that look similar to that on my 4runner. I found the leak was coming from the rubber piece area with yellow paint mark below the flange. Its part of the rack and pinion. I was not able to find any repair kits for it at the time. I ended up replacing the rack and pinion. I never tried adding any type of stop leak. Hope this helps.
08-02-2021, 07:47 PM
#547
Real Name: Devan
Real Name: Devan
Thanks, I'm thinking I'll start with my valve covers and see if anything changes. I can see directly above the flange is some oil and how it could technically drip down. Probably better to eliminate one thing at a time anyways
08-03-2021, 01:09 PM
#548
Please help. My truck has been idling real rough. I started working on different issues but noticed the coolant reservoir was empty. I put coolant in and it ran better. Next day it was empty again (not sure how low it was, there wasn’t a puddle under the truck) and it was again running poorly, especially in reverse. Tach didn’t vary, it was pretty consistent but it was a very rough idle, I added fluid (truck was cold this time) but noticed the VSC/TRACTION light was on as well as check engine. I know there is a small leak from radiator to transmission coolant, working on getting it fixed.
Would this cause the issue? I’m getting ready to do the timing belt and water pump.
2001 Limited with 252k miles.
Any help or recommendations would be great.
08-03-2021, 01:24 PM
#549
Real Name: Blair
Real Name: Blair
I'd stop driving and pause all other work until you investigate this further:
08-03-2021, 01:48 PM
#550
It is from a shit job of being installed. The clamp is too big and loose. Replacing it tonight. I assumed Firestone installed it correctly but clearly they didn’t and don’t feel comfortable with them doing it again.
08-03-2021, 02:09 PM
#551
Real Name: Blair
Real Name: Blair
Oh, OK - I read that to possibly mean that engine coolant was leaking into the transmission cooling tank at the bottom of the radiator.
08-03-2021, 02:10 PM
#552
Real Name: Devan
Real Name: Devan
I would check your oil immediately if you havent. Do you notice any smoke from the exhaust? The intake manifold gasket could've corroded away between the coolant passage and intake port
08-03-2021, 02:53 PM
#553
Real Name: Patrick
Real Name: Patrick
What does your transmission fluid and engine oil look like?
08-03-2021, 03:05 PM
#554
Engine oil is clean, transmission fluid is clean. No smoke.
08-03-2021, 03:06 PM
#555
Also, when I put more fluid it, it runs smooth and the idle clears up.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
