Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 09-22-2021, 11:11 AM #601
spartacus's Avatar
spartacus's Avatar
Originally Posted by tpelletier View Post
Thanks !
Also are LBJ only in the front or also in the rear ?
Are the front ones the only ones of concern ?
Front lbj's failing can lead to significant failure if not worse. There are control arms in the rear.
you will be well served reading the following thread.
3rd Gen 4Runner Buyer's Guide
Old 09-23-2021, 09:30 AM #602
tpelletier tpelletier is offline
tpelletier is on a distinguished road
thanks
tpelletier is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 10:41 PM #603
chapolito's Avatar
chapolito chapolito is offline
chapolito will become famous soon enough chapolito will become famous soon enough
chapolito's Avatar
burnt oil on valve cover
I'm doing a valve check on my 3rz and there is burnt oil around the top of cylinder #4 on the valve cover. How can I diagnose this? any help troubleshooting this is appreciated!
The 3rd Gen All Questions Allowed Thread-img_0171-1-jpg
chapolito is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 10:26 AM #604
spartacus's Avatar
spartacus's Avatar
Some one with a 3rz might have a better idea.( @JZiggy ) but my guess wood be valve not closing fully. also a valve guide leaking. A valve adjustment should help.
Old 10-02-2021, 02:19 PM #605
chapolito's Avatar
chapolito's Avatar
Probably a good place to start...the clearance was only .0025 on one of the exhaust valves. Thanks!
Old 10-05-2021, 12:04 PM #606
jcmb45678 jcmb45678 is offline
jcmb45678 is on a distinguished road
Does anyone know of the quality of this lift kit? I am not looking to heavily off-road.
Could not get the link to post but it is the Rough Country 3" Toyota Suspension Lift Kit with N3 Shocks - 77131
jcmb45678 is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 08:10 PM #607
spartacus's Avatar
spartacus's Avatar
Rough country has come a long ways. The value for money is good. I prefer the bilstein 5100 with appropriate height, weight springs which would be little more expensive. lot of pickup guys run rough country fit bigger tires.
Old 10-06-2021, 08:40 AM #608
What set up should I get with the Bilstein. Im wanting a 3 inch lift.
Old 10-06-2021, 08:54 AM #609
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
3" from which version (year) of 3rd gen? There was nearly 2" difference from the lowest to the highest of these. WAY easier to get 3" of lift on a 2001 than a 1999. Whole lot less stress/wear on parts to lift an '01 3" than a '99 too.
As for lifting from where you are right now, 3rd Gen 4Runner Lift Information and FAQ's
Oh, in case you didn't gather, lift is a function of spring length.
Brian. is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 10:18 AM #610
I have an 01 sr5 4wd
Old 10-06-2021, 10:41 AM #611
spartacus's Avatar
spartacus's Avatar
There are a lot of threads on 3inch lift. 2inch lift will be cheaper and you wont have to dIf drop. If you are dead set on 3 inch lifts. Here are two options
toytec 3inch lift kit about a grand.
eibach 3inch lift kit about $900
Old 10-06-2021, 11:04 AM #612
How much cheaper is a 2 inch lift
Old 10-06-2021, 11:14 AM #613
spartacus's Avatar
spartacus's Avatar
probably a couple hundred.
Old 10-06-2021, 11:33 AM #614
any good recommendations for a 2inch
Old 10-06-2021, 12:05 PM #615
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
The uninspired, semi-uniformed setup for a medium-weight 2" lift when I did this online with Wheeler's Off Road in May 2020 was:
"Set to bottom perch"
Bilstein 5100 Ride Height Adjustable Front Shock Set for 96-02 Toyota 4Runner (BE5-D558-T0 or 24-248730)
SKU: WOR-307421
Shocks
BE5-D558-T0
Assembly
Fully Assembled Strut (See Item Description)
Front Coils
OME 2881 Coils (500 lb/in)
1 $452.89
5100 Rear Shock Set for 1996-2002 4Runner (0"-2" Lift)
SKU: BIL-24-249966-X2
1 $180.00
4Runner 96-02 Rear Old Man Emu 2906 Medium Load Springs (Sold in Pairs)
SKU: ARB-2906
1 $163.25
Subtotal $796.14
Shipping & Handling $16.52
Discount (WORM35CV) -$79.61
Grand Total (Excl.Tax) $733.05
Tax $0.00
Grand Total (Incl.Tax) $733.05
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
