Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 11-16-2021, 09:51 PM #661
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Originally Posted by DenverAirport View Post
It's for my '99 -- this is super helpful. So basically the stock amp has a harness built in that runs to the factory stereo, outputs for the speakers, and the antennae? I'd definitely take you up on that -- will PM you.
Mine is a 2000 limited, so I'm not positive about what it may look like on others, but for the 2000 limited, there are two round single pin plugs that connect to the head unit for the two antennas. Then there is a single white multipin connector which plugs in to the back of the head unit, and it comes from the stock amp. The wiring running between the stock amp and the stock head unit is integral to the stock amp. I have attached a couple of pictures of what I have. They may not show exactly what you need to see, so let me know if you want to see any other angles.
Skulking is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 10:17 PM #662
DenverAirport's Avatar
DenverAirport DenverAirport is offline
DenverAirport will become famous soon enough
What about the other plug on the back of the OE stereo? Which harness is attached there?
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
DenverAirport is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 11:03 PM #663
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Originally Posted by 97RottenRunner View Post
First question: Does anyone have a part number for the wire harness that goes to the rear hatch? My wires are frayed and the defrost won't work. I'd rather get a new harness from the dealer than a used one but I can't find a part number.
Not available anymore. What I did to fix mine was to remove the entire harness from the truck and soldered all cracked areas with new wire from Home Depot (can also splice wire too if you want) and alls been good ever since. Use the correct gauge wire.
The 3rd Gen All Questions Allowed Thread-screen-shot-2021-11-16-9-58-09-pm-jpg
2000 4Runner Limited 4x4 V6
Old 11-16-2021, 11:52 PM #664
I don't actually remember disconnecting anything from that spot, but it's been a couple of years. Before I posted I looked at other pictures online and walk-throughs of replacing the stock head unit, and I couldn't find anything addressing if there was something plugged in there. Maybe someone else who has replaced there head unit more recently, or who still has the stock setup installed can answer that question.
Old 11-16-2021, 11:57 PM #665
Just figured out that it may be for an expansion to add a 6 disc CD changer (an option only on '98+ stereos)
Old 11-25-2021, 08:35 PM #666
jcmb45678 jcmb45678 is offline
jcmb45678 is on a distinguished road
Hey guys quick question, I fitted my 01 with a 3-inch ome lift. I then proceeded to put 255/85/r16 cooper all-terrain tires on my car. I want to do tire spacers now. Any recommendations on size and brand?
jcmb45678 is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 03:01 AM #667
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
If you use spacers to move stock wheels out for clearance and stance reasons and you don't want to buy a set of aftermarket wheels that will natively compensate for this, this is one area NOT to skimp. Buy a set of hub-centric Made in the USA spacers. Don't trust Chinese eBay junk. I only know of 2 US brands (Spidertrax and Bora) but there may be others. The spacer size most people use is 1.25". Bora does make wider spacers but you should probably get some aftermarket wheels with the correct backspacing and offset at that point.
These are cheaper on many 4X4 resale sites but you can read up on the specs:
Toyota Hub Centric Wheel Spacer Kit
Old 11-26-2021, 02:37 PM #668
Do you Know if that size 1.25 will cause tire rub?
Old 11-26-2021, 02:47 PM #669
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Depends on your fender flares, and other factors. 1.25” spacers gave my 1.5” lifted front end with 265/75/16 tires some rub at lock and compression. I trimmed just an inch or so off the front bottom inside plastic lip of my oversized fender flares. Can’t see it unless you’re up in the wheel well.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 09:21 PM #670
2chains 2chains is offline
2chains will become famous soon enough
1996 t4r antenna
Hey guys
I've got a question about the limited antenna. My ornament and chrome bolt are missing.
Can I buy those two pieces separately or do I need to buy the whole assembly? Of course mine has fallen down in the fender well.....I'm still getting good range with the radio and looking for the quickest fix.
edit ok so i found this vid on youtube, basically answered my question for powered antenna.
Antenna Mast Replacement 1998 4Runner - YouTube
I believe there is the Tacoma antenna whip mod..going to look into that next. Looking to hopefully thread a new manual mast on there
The 3rd Gen All Questions Allowed Thread-current-antenna-jpg  The 3rd Gen All Questions Allowed Thread-manual-antenna-base-kit-genuine-toyota-86300-35090-jpg
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
2chains is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 05:21 PM #671
Anyone know where I can buy the skid plate on the 2002 sr5 sport edition?
Old 11-29-2021, 06:11 PM #672
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
No Longer Available, so it's used market only.
pz327-35010
That's the part number for the 4runner version (brackets that fit the fatlip bumper). There's a Tacoma version too but the mountain brackets are shorter.
Brian. is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 06:45 PM #673
pz327-35010
Any suggestions where to look for used?
Old 12-01-2021, 05:10 AM #674
Garandman Garandman is offline
Garandman is on a distinguished road
Which model Bilstein shocks for stock height 2001?
Garandman is offline   Reply With QuoteReply With Quote
Old 12-01-2021, 09:21 AM #675
What are you using for a tool bag that will fit in the passenger side rear cubby?
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
