12-03-2021, 09:33 AM
#677
I have a dent in my front right chrome bumper on my 01.I tried to hammer it out in various ways but it would not budge. Any ideas on how to fix this?
12-03-2021, 09:59 AM
#678
Alright, I’ve been running my SS 1.2 (classic system) for almost 95K miles, an have 5100’s in the front & rear. Getting curious about the Tokico’s p/n 48531-69417. Is now a good time to swap them out? Not wheeling my rig anymore these days, mainly daily driving and have the family in it more often. Lots of long distance driving as well. Is it worth the time/investment/effort? Will I notice any difference In overall ride quality? Opinions, please, especially those with the SS 1.2! Thanks in advance
12-04-2021, 01:27 PM
#679
99 runner blinker issue
Just bought a 99 4Runner and all the lights worked perfectly. I pulled out and returned a couple fuses to check for a burned one due to the radio not working. Couple days later my left turn signal activates solid when the brake is pressed and the lights blink when the left blinker is activated. They are tied together in a sense. Any ideas?
12-04-2021, 03:23 PM
#680
First thought is the wiring bundle that goes into the hatch is a known weak spot. Check there for broken/damaged wires.
12-04-2021, 05:36 PM
#681
Real Name: Devan
Real Name: Devan
Probably a dumb question but is it alright to go through an automated car wash with a tire carrier in the back? Really need a wash but it's 40 degrees and raining for the next month or three
12-04-2021, 06:38 PM
#682
Real Name: Evan
Real Name: Evan
I do almost weekly and have a swing out bumper with spare tire and full length rack. The automated washes haven’t done any damage but I guess there’s always a small risk something on the machinery will get hung up on a vehicle’s aftermarket parts and tweak something. I wouldn’t worry about it.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
12-04-2021, 07:18 PM
#683
Real Name: Devan
Real Name: Devan
Thanks, I couldn't find anything about saying otherwise so I assumed this was the case
12-06-2021, 01:36 AM
#684
Long time lurker second time commenting. Well first off a huge thank you to all of the great contributors to this site for the amazing amount of detailed and informative content that was been a lifesaver, for both myself and my wallet over the last few years. I’m so glad this site is around!
Alright onto business. So I had a bad bearing in the drivers rear a few weeks back, and after weighing my options I realized it was much more cost friendly to my student budget to not replace the bearing and instead to just buy a used left axle shaft with all the bits still on and just do a quick direct swap. Unfortunately I had zero time to do this myself so I had to take it to the shop to get it installed, which reportedly was quick and a painless. Well it has been about a month since with no prior problems, but when I was lubing the driveshaft and having a poke around the other day I noticed that my left tire has 12–6 o’clock play similar to what a bad bearing would exhibit, however there is no current signs of a bad bearing and I gave the part a very close inspection when I bought it and it seemed mint to me.
My question then is; if it is indeed not a bad bearing again what could this vertical north—south play in the wheel be caused by? TIA!
Reason: Typo
12-06-2021, 11:43 AM
#685
2000 Limited thoughts on value ? Found a one owner Limited with 99,000 on the clock, allegedly unmolested and no accidents. From photos, very good condition. Leather drivers seat normal cracks and normal nicks in front end from driving much like any car will get. White in color not that it makes a world of difference. Used car prices in general are ridiculous and I am not in a rush but if something comes up at a good price, I'd buy. Southern car, no rust.
What do you feel is a realistic price ?
12-06-2021, 11:51 AM
#686
Take the tire off and check the wheel studs and lugs, the hub assembly, also the surface on the inside of the wheel. It'could be the its'not sitting right on the hub ring.
12-06-2021, 11:54 AM
#687
Depending on your market. I would guess 10k plus.
12-06-2021, 02:45 PM
#688
I bought mine before the wu-flu insanity, a bit less than double the miles but otherwise the same for $6500. Not sure why people think less miles is better (to a point), just means it wasn't driven as much so there's more potential for plastic/rubber part failure. I've seen low mile motorcycles with engine gaskets that leaked because they dry-rotted... talking 40 year old engines with a thousand or two miles. But if the seller is one of those who thinks low miles always means more money, it'll be listed too high for an economical daily driver (you're still going to have to replace all the parts as a 200, 300 or 400k vehicle, actually probably more as the higher mileage units will likely have had some replacements).
Todays market, a "needs everything maintenance/consumable" is probably a good deal at $7k, gives you the ~$3k needed to buy the parts and do the work yourself, landing at a $10k vehicle that *MIGHT* sell for $10k. If you're willing to eat some money on the deal, decide how much and rise the initial price from there. A 4r with 100k miles has a little more room for that BaT magic, but those are the oddball exceptions and I wouldn't bet my next months mortgage on it.
12-13-2021, 04:48 PM
#689
Real Name: Mark KN6TZI
I can't find a number or any specs for the bolt that attaches the fuel return line bracket to the plenum. I'm guessing it's the same as the ground strap bolt but I can't find that either. I've previously tried an 8x1.25 so I know it's not that. It's currently raining too hard to go outside and check the ground strap bolt for markings.
Can anyone enlighten me?
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
12-13-2021, 07:02 PM
#690
It's one of these part numbers
91611-60614
91611-60616 superseded by 91611-B0616
or 91651-40610
