Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 01-21-2022, 07:33 PM #796
Alstyn's Avatar
Alstyn Alstyn is offline
Alstyn is on a distinguished road
Alstyn's Avatar
Originally Posted by Brian. View Post
My gut instinct is that you have a clogged heater core and need a coolant flush (probably a power flush). Next thought is that if you need that, you're probably on borrowed time with the radiator and transmission. Radiator is #1 killer of the transmissions and one of the top 2 reasons why 4runners die (lower ball joints failing being the other reason).
All sorts of videos out there on how to flush your cooling system yourself, and this is what I'm talking about for a power flush ~ Amazon.com: OTC 6043 Blast-Vac Multipurpose Cleaning Gun : Automotive
But it could be that the seller simply disconnected the heater core because it was clogged or leaking and they didn't want to bother with fixing it for a sale. So you'd need to check that too.... Good luck!
He did mention that the radiator was just replaced, is it possible it didn't get reconnected? car runs and drives fine.
1999 Toyota 4Runner Limited - 367k miles and counting -
Alstyn is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 07:34 PM #797
Alstyn's Avatar
Alstyn's Avatar
Originally Posted by Spiker Engineering View Post
Did you confirm that the heater valve opens when set to heat? No hot water => no heat.
I have not. How can I find that out?
Old 01-21-2022, 09:43 PM #798
Alstyn's Avatar
Alstyn's Avatar
you've solved it! Heater valve is stuck or non functioning. Moved the arm myself and heat came!
Old 01-22-2022, 10:57 AM #799
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Awesome!
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 06:01 AM #800
MelodyRad's Avatar
MelodyRad MelodyRad is offline
Real Name: GundamDeathscythe
MelodyRad is on a distinguished road
MelodyRad's Avatar
Originally Posted by spartacus View Post
O'Reilly' s can check your charging system and tell you if the alternator is good also if the battery is being discharged which triggers the light on the dash. They can also tell you if you have a bleed off on the charging line.
I already did this and told me that both the battery and alternator are healthy. they are new. but didnt mention anything about bleeding of charge line.
MelodyRad is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 06:02 AM #801
MelodyRad's Avatar
MelodyRad's Avatar
With the motor running the battery terminals should be at 14-15V. With motor off Check battery to see if it is going down--should be 12V-12.5+V with engine off. Also check alternator fusible link in engine junction box.
its at 14.7 running. new battery and alternator.
Old 01-23-2022, 06:04 AM #802
MelodyRad's Avatar
MelodyRad's Avatar
Originally Posted by Skulking View Post
The bulb is part of the charging circuit, and if the bulb has been swapped to an LED that can cause the light to stay on at all times.
The entire vehicle is unmodified. It is very unlikely that light was modified or replaced.
Old 01-23-2022, 06:06 AM #803
MelodyRad's Avatar
MelodyRad's Avatar
The battery light also indicates low brake fluid in the reservoir.Check your brake fluid level.
Edit: If the brake light is also on . The brake light on also indicates alternator charging issues.
That is crazy...
But brake fluid is at healthy level. I verified ALL fluids when purchasing and monthly.
Old 01-23-2022, 06:10 AM #804
MelodyRad's Avatar
MelodyRad's Avatar
Originally Posted by Bad Luck View Post
What is your battery voltage while engine running cold and hot? What is your battery voltage before you start the engine? What did you replace the alternator with (brand)?
alternator level running is 14.7v.
i didnt record it not running/cold/hot.
i dont think it is relevant for brand. The light was always ON prior to replacing alternator and battery. It was ON during the entire ownership of previous owner which he has zero knowledge as to why or how the light has been always ON.
current alternator part number R110936A 70amp oreilys. Installed Turkey day 2021.
Old 01-23-2022, 10:48 AM #805
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Aftermarket starters and alternators are known to be junk for these vehicles. I’d recommend buying a used oem one off eBay and trying that. Should be around $60 or so. Cold start voltage and engine warm voltage would be helpful to help you.
Old 01-23-2022, 06:43 PM #806
tpdietz tpdietz is offline
tpdietz is on a distinguished road
Soooo I'm doing my valve cover gaskets, etc. I got everything off, and I'm about to deep clean the plenum and valve covers. This hose is giving me trouble on the upper plenum. It also doesn't look quite like the other hoses, so I'm hesitant to yank harder in an attempt to remove it. It appears to have a plastic fitting in the hose or something (see second image).
Question: How do I remove this? Yank harder?
1995 4Runner SR5 4spd
2000 4Runner SR5 5spd
2022 4Runner Special Trail Edition
tpdietz is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 06:43 PM #807
MelodyRad's Avatar
MelodyRad's Avatar
I have a local parts store alternator that is new that works and is producing a healthy 14.7 volts. And you are saying buy a used product that is oem to fix this concern?
That sounds like waste.
The light has always been on with the current and previous alternator.
Old 01-23-2022, 07:15 PM #808
MelodyRad's Avatar
MelodyRad's Avatar
its at 14.7 running running. new battery and alternator.
its sunday now, haven't driven since friday noon.
Engine off cold 12.5 volts
Engine on cold 14.37 volts
Engine on warm 14.61 volts
Note. Warm = engine temp at operating temp.
Old 01-24-2022, 12:01 AM #809
Real Name: Patrick
Real Name: Patrick
You already wasted money on an aftermarket alternator and the light is still on so ya I’m suggesting buying a used OME component that has a much higher likelihood of working than the new aftermarket one.
Old 01-24-2022, 10:20 AM #810
MelodyRad's Avatar
MelodyRad's Avatar
That’s all opinion.
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
