Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 05-21-2022, 08:48 PM #1036
benamaro benamaro is offline
benamaro is on a distinguished road
Originally Posted by spartacus View Post
p0171 system too lean too much air not enough fuel. Check for vacuum leaks. dry, cracked hoses. Spray carb cleaner on the intake to see if there is a leak.
edit. pcv valve and hose are good.
Ill check that again. Any recommendations? I don't wanna take it in but I also don't have a propane torch. Will soapy water work?
benamaro is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 08:51 PM #1037
Originally Posted by RandyBobandy View Post
Replace your primary oxygen sensor if you haven’t already, it’s a maintenance item anyway so even if it doesn’t fix the issue it isn’t expensive and can only help
I haven't done that but I was leaning towards doing that and all around a general Tune-up.
Old 05-21-2022, 10:52 PM #1038
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Spray it with carb cleaner. Vacuum hoses won’t make any bubbles if you spray them with soapy water because they aren’t pressurized.
Old 05-22-2022, 01:12 PM #1039
spartacus's Avatar
spartacus's Avatar
What @Bad Luck said. you can buy cheap smoke machine of off Amazon etc or make one, there are you tube videos.
Old 05-28-2022, 10:21 PM #1040
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Going to be installing the Fumoto F-133 at my next oil change. I want to know from actual users with 3rd gens if they kept the gasket that came with it or replaced it with an OEM one?
Research shows that many stick with the supplied gasket, but I have a bunch of OEM ones stocked up. Thoughts?
Old 05-29-2022, 08:33 AM #1041
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Doesn't matter which you use, just that you use one. Pick whichever lets you forget about it/be content.
Gotta say that I really like having a fumoto. If only the oil filter wasn't an absolute nightmare that drips everywhere... seems to be a theme as my ford is the same way. Had a Mazda that was straight up and down, immediately next to the oil drain, which is the best setup if still slightly messy. And a VW with a top-side oil filter that was the least messy of them all (simple to lift straight up and slide a catch tray or bag under ~ plus I did top-side oil extraction so never a need to get under the car).
Brian. is offline   Reply With QuoteReply With Quote
Old 05-29-2022, 10:42 PM #1042
JOW01 JOW01 is offline
JOW01 is on a distinguished road
Misfire on cylinder 4
Hey everyone,
I recently got a misfire on cylinder 4 that came up. Replaced the fuel injector and the spark plug.. put it back together and it coded the same thing.. any suggestions on what to try next?
Did a compression test on that cylinder and it was good. Not sure what the next move is.
JOW01 is offline   Reply With QuoteReply With Quote
Old 05-30-2022, 12:35 PM #1043
Real Name: Patrick
Real Name: Patrick
Originally Posted by JOW01 View Post
Hey everyone,
What year and engine is your 4Runner?
Old 05-31-2022, 10:09 AM #1044
Year- 2000
Engine 3.4
Old 05-31-2022, 10:23 AM #1045
Real Name: Patrick
Real Name: Patrick
Year- 2000
Engine 3.4
Swap coil packs and replace spark plug wires. See if the misfire follows the coil pack or the spark plug wires cures the misfire.
Old 05-31-2022, 03:23 PM #1046
Thank you! I'll give this a try and see if it resolves the issue.
Old 05-31-2022, 07:07 PM #1047
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Looking to validate torque settings for steering column/rag joint connections.
Does anyone have quick access to an FSM?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-31-2022, 08:29 PM #1048
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
This might be what you're looking for. It's from a '98 FSM.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 12:54 AM #1049
Yes, that validates what I was able to search and find, 26 pounds feet, also here by @Doc2012
https://www.toyota-4runner.org/2051447-post2.html
But what about the 2 bolts and nuts connecting both halves of the rag joint itself?
Highlighted in this pic
Thanks @fatherohenry !
Old 06-01-2022, 01:18 AM #1050
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Maybe this?
I mean, that would be the ‘control valve shaft’, the the other is ‘intermediate shaft #2’. The 3rd Gen All Questions Allowed Thread
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
