05-21-2022, 08:48 PM
#1036
Originally Posted by spartacus
p0171 system too lean too much air not enough fuel. Check for vacuum leaks. dry, cracked hoses. Spray carb cleaner on the intake to see if there is a leak.
edit. pcv valve and hose are good.
Ill check that again. Any recommendations? I don't wanna take it in but I also don't have a propane torch. Will soapy water work?
05-21-2022, 08:51 PM
#1037
Originally Posted by RandyBobandy
Replace your primary oxygen sensor if you haven’t already, it’s a maintenance item anyway so even if it doesn’t fix the issue it isn’t expensive and can only help
I haven't done that but I was leaning towards doing that and all around a general Tune-up.
05-21-2022, 10:52 PM
#1038
Real Name: Patrick
Real Name: Patrick
Spray it with carb cleaner. Vacuum hoses won’t make any bubbles if you spray them with soapy water because they aren’t pressurized.
05-22-2022, 01:12 PM
#1039
What
@ Bad Luck
said. you can buy cheap smoke machine of off Amazon etc or make one, there are you tube videos.
05-28-2022, 10:21 PM
#1040
Going to be installing the Fumoto F-133 at my next oil change. I want to know from actual users with 3rd gens if they kept the gasket that came with it or replaced it with an OEM one?
Research shows that many stick with the supplied gasket, but I have a bunch of OEM ones stocked up. Thoughts?
05-29-2022, 08:33 AM
#1041
Doesn't matter which you use, just that you use one. Pick whichever lets you forget about it/be content.
Gotta say that I really like having a fumoto. If only the oil filter wasn't an absolute nightmare that drips everywhere... seems to be a theme as my ford is the same way. Had a Mazda that was straight up and down, immediately next to the oil drain, which is the best setup if still slightly messy. And a VW with a top-side oil filter that was the least messy of them all (simple to lift straight up and slide a catch tray or bag under ~ plus I did top-side oil extraction so never a need to get under the car).
05-29-2022, 10:42 PM
#1042
Misfire on cylinder 4
Hey everyone,
I recently got a misfire on cylinder 4 that came up. Replaced the fuel injector and the spark plug.. put it back together and it coded the same thing.. any suggestions on what to try next?
Did a compression test on that cylinder and it was good. Not sure what the next move is.
05-30-2022, 12:35 PM
#1043
Real Name: Patrick
Real Name: Patrick
Originally Posted by JOW01
Hey everyone,
What year and engine is your 4Runner?
05-31-2022, 10:09 AM
#1044
Year- 2000
Engine 3.4
05-31-2022, 10:23 AM
#1045
Real Name: Patrick
Real Name: Patrick
Year- 2000
Engine 3.4
Swap coil packs and replace spark plug wires. See if the misfire follows the coil pack or the spark plug wires cures the misfire.
05-31-2022, 03:23 PM
#1046
Thank you! I'll give this a try and see if it resolves the issue.
05-31-2022, 07:07 PM
#1047
Real Name: C8H18 Mike
Looking to validate torque settings for steering column/rag joint connections.
Does anyone have quick access to an FSM?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
05-31-2022, 08:29 PM
#1048
Real Name: Mark KN6TZI
This might be what you're looking for. It's from a '98 FSM.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
06-01-2022, 12:54 AM
#1049
Yes, that validates what I was able to search and find, 26 pounds feet, also here by
@ Doc2012
https://www.toyota-4runner.org/2051447-post2.html
But what about the 2 bolts and nuts connecting both halves of the rag joint itself?
Highlighted in this pic
Thanks
@ fatherohenry
06-01-2022, 01:18 AM
#1050
Location: Stationed in Camp LeJeune, home is Conover, NC
Maybe this?
I mean, that would be the ‘control valve shaft’, the the other is ‘intermediate shaft #2’.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
