08-17-2022, 02:40 PM
#1366
Real Name: Patrick
Real Name: Patrick
Originally Posted by Devbot
Isn't our master already bigger than the Tundra one, too?
I think so, but I'm not entirely sure. I know 1st gen Sequoia is 15/16" bore.
08-17-2022, 08:24 PM
#1367
Real Name: Devan
Real Name: Devan
I'm almost positive it is, just from seeing this conversation come up so many times. If I'm not wrong the bigger difference is in the booster but I'm also speaking from my ass
Cant remember who but there was some lad on Instagram that did a complete TBU swap including the master and booster and that SOB stopped like he flipped on a Jake brake, even with +500lbs of gear
08-18-2022, 03:03 PM
#1369
Real Name: Patrick
Real Name: Patrick
Originally Posted by dragondrogo
Make sure there is nothing keeping the gas pedal pressed down. If that is clear then remove the intake tube to the throttle body and check if it is closed 98ish percent. If it's not try to rotate the throttle closed by hand.
08-18-2022, 03:25 PM
#1370
Real Name: C8H18 Mike
Check the Throttle Position Sensor and connection at the same time. Clean your MAF sensor and air filter while the intake tube is off
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
08-18-2022, 03:41 PM
#1371
Real Name: Patrick
Real Name: Patrick
I'm not the one that needs quoted. If mis-quotes were friendly fire you'd have killed me by now
08-19-2022, 11:41 AM
#1372
I'm a doofus and stuffed the drivers side floor mat right on top of the pedal...I thought it was something more complicated but you got it right away. Thanks guys
08-19-2022, 12:01 PM
#1373
Real Name: Patrick
Real Name: Patrick
At least it was an easy fix lol
08-19-2022, 09:51 PM
#1374
Hello! I am trying to upgrade my struts and shocks. I have a 1998 sr5 2wd 4runnner and I'd like to keep the original ride height but it's pretty bumpy original leaky struts. I would like a nice smooth ride quality, I have heard the kyb is a good oem brand for 4runners i want the best bang for the buck performance struts. Also considering pairing it with the durobump bump stops. Preferably a complete strut assembly so I can just slap it on myself. Having a hard time finding a complete strut assembly at a reasonable price, allot of them say 4wd not sure if that would be compatible with my application. Thanks for any info!
Sent from my SM-A536U using Tapatalk
08-20-2022, 02:17 AM
#1375
Real Name: Devan
Real Name: Devan
I've done this a few times... actually just did it maybe a week ago It's really funny how you immediately jump to mechanical problems, then feel an wave immediate relief when you look down
08-20-2022, 02:23 AM
#1376
Real Name: Devan
Real Name: Devan
4WD coils are (or should be) stiffer to accommodate for the extra weight of the front diff and driveline, just so you know. They'd probably work but wouldn't be as comfortable as they can be
If you want the best bang for your buck, you should check out hydraulic bump stops
08-20-2022, 11:13 AM
#1377
The hydraulic bump stops look pretty cool! Would that work on a stock ride height truck though?
08-20-2022, 08:04 PM
#1378
Solid post.
I'll just stick to updating my stupid build thread and leave the helping people to others.
08-20-2022, 08:10 PM
#1379
Real Name: Patrick
Real Name: Patrick
Solid post.
I’m bringing to your attention that you keep quoting me even though I’m not the one you are responding to. Don’t let me stop you from helping others just please stop quoting me when it’s not meant for me. This is about the 5th or 6th time you’ve done it. I don’t want the person the information is intended for to miss out on something that could potentially be important to them.
08-20-2022, 10:34 PM
#1380
Limited or SR5/Sport? What t-case you have matters immensely
I have a sr5
