01-31-2023, 03:03 PM
#1981
Does anyone use any kind of rubber conditioner or some other substance on their cv boots to make sure they stay healthy for a longer time?
01-31-2023, 03:25 PM
#1982
Real Name: Mark
Real Name: Mark
Originally Posted by DJRodriguez88
yeah i thought the same thing, but 2 youtube how-to's in a row pulled the mounting bolts
I'll try the stud first, thanks!
For what it worth I've been doing BJ's since before YouTube and net was invented. I'm old.
01-31-2023, 03:50 PM
#1983
Let's call it "experienced" =]
01-31-2023, 05:42 PM
#1984
Real Name: Mark
Real Name: Mark
Haven't heard of it being done.
01 bought @ 198k mi original boots/shafts. Did 2.5-3" lift with diff drop 10k mi give or take one of the four broke.
02-01-2023, 02:00 PM
#1985
so I'm rebooting my steering rack. Driver side boot was torn but no issues with the steering at all.
I can tell my inner tie rod on the driver side seems a little more stiff than the passenger side. Can I just slop some more grease on and reboot? Is there anything I can look for that would indicate things will go south quick? There's no roughness or looseness at all, just slightly harder to move around compared to the passenger side.
also, because the boot was torn there's a bit of a mess in the driver side end. Any reason I can't spray the crud out with some brakeleen?
02-01-2023, 05:41 PM
#1986
IMO if I was doing all this work I'd just replace all my tie rods, unless they have just been done, if they have an unknown or a known high miles why waste all ur time and effort...
02-01-2023, 05:47 PM
#1987
Real Name: C8H18 Mike
If the boot(a) are torn, replace them. You don't want debris getting into the rack.
If the inner tie rods are bad, replace them. Loose doesn't mean bad, check for play and replace if out of spec. I usually replace them in pairs vs each if one is bad.
JM2C
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
02-02-2023, 01:00 AM
#1988
Real Name: Evan
Real Name: Evan
The good tie rod is tight so the one with more play is the suspect one, if anything. If you get your hands on a new inner or outer, that’s the first thing you’ll notice. They almost don’t move without significant pressure being applied.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
02-02-2023, 07:12 PM
#1989
Real Name: Chuck
Real Name: Chuck
Protune rear arms
Has anyone used protune rear adjustable upper and lower arms with adjustable panhard bar? About to lift it after putting it off for last 5 years and now since I need to replace a lot of bushings anyways figured might as well
02-04-2023, 12:19 PM
#1990
Real Name: Patrick
Real Name: Patrick
If you are talking about these: Upper & Lower & Track Bar Arm For 2-4" Lift Kit 4-Runner FJ Cruiser 03-09 I would be very skeptical about the fitment as they don't list what years of 4Runner they fit.
02-04-2023, 04:26 PM
#1991
Don't change the trailing arms for adjustable ones, there really isn't much adjustment possible given the clearances of everything back there.
I went with Rokman lower trailing arms, personally, beefy with new bushings. The upgraded, fixed length arms Sonoran Steel sells are nice too. The stock uppers are also pretty good, replacing the bushings is a chore.
I've always favored the eimkeith PCK over adjustable panhard bars, personally - weld it one and done. One less thing to come loose or unadjusted.
JM2C
02-05-2023, 08:51 AM
#1992
JM2C
But what about an adjustable panhard bar with the PCK?
Sent from my SM-T220 using Tapatalk
02-05-2023, 08:27 PM
#1993
Real Name: Chuck
Real Name: Chuck
JM2C
The uppers are both bent and all bushings about shot figured adjustable even threaded all the way in would be more solid than OEM.
also wanted to retain the original pinion angle for rear diff when I drop it 4inches, also the reason for the adjustable panhard.
If could find a beefy set of 4 arms and the adj panhard would likely go that route since it is also my DD and budget is a concern the set I was looking at made good sense but havent heard of the brand before.
02-05-2023, 08:42 PM
#1994
Real Name: Chuck
Real Name: Chuck
Originally Posted by Bad Luck
similiar but the ones I saw were a different part number and did list 96-02. dont matter though since they went from 6 in stock to sold out the day I posted the question.
02-05-2023, 10:41 PM
#1995
Real Name: Patrick
Real Name: Patrick
Strange. That’s the only part number they show on their website for 4Runners.
