03-25-2023, 08:51 AM
#2146
Real Name: Mark
Real Name: Mark
Originally Posted by Storm01
The only way I can see of getting it out is removing the passanger side axle and hammering/tapping it out from the inside. Does anyone have any other methods for me? Thanks.
Two things, from the outside try a slide hammer drill a pilot hole.
From the inside, a turnbuckle with washer covering sensor worked for me on a stuck sensor without damaging it.
03-26-2023, 01:23 PM
#2147
Thoughts and experiences with the Wagner ThermoQuiet brake pads?
Same with Hawk LTS pads?
Which do you prefer and why?
Sent from my SM-T220 using Tapatalk
03-27-2023, 09:45 AM
#2148
official vendor
official vendor
I'm trying to figure out where the brake pedal return spring hooks to on the fixed side. This is the best I could come up with (circled in red), but can someone confirm? I'd hate to end up with a spring that flies off while I'm driving!
03-27-2023, 11:25 AM
#2149
Frame Rust
Hey all, new member here in the market for a 3rd Gen. I've found one that looks solid other than a bit of frame rust, which is to be expected for a 20+ yr old vehicle in Northern VA. I don't mind immediately putting a little money in to take care of it, but I'm wondering if this is likely to be a sand+repaint job or a welding job. I'm particularly worried about the lateral control rod mount on the left side. Any thoughts?
Higher res photos here: Imgur: The magic of the Internet
Reason: more photos
03-27-2023, 12:10 PM
#2150
Real Name: Patrick
Real Name: Patrick
It's difficult to say based on pictures. I would hit the mount with a decent sized hammer to test the integrity
03-27-2023, 08:15 PM
#2151
Real Name: Devan
Real Name: Devan
Originally Posted by Spiker Engineering
I ended up contacting Osidetiger , and got the definitive explanation. Here is what they said:
"The factory injectors use that lower seal to seal off a cavity that is part of the intake manifold. That part of the manifold has a port that introduces air at certain rpms. That air enters the injector tip in an effort to improve with fuel atomization. The factory injectors have small air ports molded in to allow the air to mix with fuel during operation. This was an attempt to get decent atomization out of a single hole (at the very tip) of the injector. The injector tip on the factory injector you can see is just a two way diverter and does nothing for atomization. The new modern injectors do away with all of this by using 12 atomizing holes instead. The additional air that enters the cavity in the intake bypasses the injector tips so the engine and sensors don’t see a change."
Looking at the injector mounting pocket in the manifold, the vacuum sealing surface is near the top, and is sealed by that large seal that both injectors have. Below that is that aux air passage that they mentioned, from which air comes out at certain RPM and tries to push fuel through the injector to better atomize it.
That lower o-ring on the original injector is therefore only used to prevent this auxiliary air from going around the injector tip, forcing the air to go through the injector. So the o-ring has nothing to do with maintaining a vacuum seal, which is why it's not needed in the upgraded injector.
Very interesting, and also very loopy design from Toyota. I wonder how/if fuel efficiency would increase with these...
03-28-2023, 01:03 AM
#2152
Real Name: Mark KN6TZI
That's where I connected mine over a year ago and it hasn't flown off.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
03-28-2023, 06:34 AM
#2153
Attachment 403631
Attachment 403633
Bonjour. Fellow NOVA owner here. I will say this does look pretty rough, but I agree with Bad Luck. See what happens when you hit it. My truck didn't spend most of it's life up here, but I've been up here the past couple of years. You know they salt these roads when it gets cold and the idea of a single drop of snow.
03-28-2023, 06:59 AM
#2154
Real Name: Mark
Real Name: Mark
Can take pic if needed that's where mine is hooked.
03-28-2023, 07:38 AM
#2155
official vendor
official vendor
I'll certainly report back if I see any improvement in mpg (14.5 that I'm getting now is a pretty low bar!).
Then again, I am changing not just the injectors, but also the TPS, all air/vacuum hoses, and tons of other parts, so if I do see any change in mpg (hopefully for the better), I won't necessarily know what to attribute it to.
#2156
official vendor
official vendor
Thanks Mark
03-28-2023, 08:52 AM
#2157
Gen 3 4runner broken rear seat clip
There's a plastic clip underneath my rear fold down seat thats broken. Which is concerning because my kids car seat sits on top of the rear seat. I can't find this plastic clip anywhere. I'm not even sure if I'm using the correct terminology buts it's not in the operators manual, its not in the maintenance manual and I can't find it on rock auto please help
03-28-2023, 08:57 AM
#2158
Are you referring to the plastic caps that go over the metal bracket where the seat actually bolts into the body?
#2159
official vendor
official vendor
Can you post a photo of the broken part?
03-28-2023, 10:23 AM
#2160
Real Name: Mark
Real Name: Mark
I'm going to replace my original fuel injectors with the Osidetiger injectors.
Hadn't seen that name in a while, think my turn is near. I like the difference
be interested in results as things progress.
