Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 04-02-2024, 01:17 PM #2926
highmilage4runner highmilage4runner is offline
highmilage4runner is on a distinguished road
Thumbs down 2002 4 Runner can barely accelerate, no codes, dealer is clueless
I am new here but a long time lurker. I cannot start a new thread so I thought Id take a shot asking here. Recently purchased a '02 4 runner 4wd limited with 328k on the clock. Started to have a slight hesitation at highway speeds from 2-3k rpm. This progressed and got way way worse to the point it cannot go up hills anymore. Cannot rev past 3500 anymore unless the A/F sensor is unplugged. Idles fine, and is recently taking a longer time to crank.
Things that have been replaced or swapped with no change
Plugs
coils
wires
MAF
A/F and rear O2 sensor (both OEM)
Entire throttle assembly (TPS, throttle motor, etc.)
Crank sensor
According to first dealer Compression and fuel pressure are perfect.
No vaccum leaks
CAT allegedly is good but I may check again.
Timing belt water pump and all tensioners were done in last 25k miles.
ECU swap with programmed unit from flagship one.
Of note: it does not hesistate in limp mode. When in regular mode it smells like straight fuel out of the exhaust. Running extremely rich. Out of limp mode it will rev and then drop 300-500 revs like someone took their foot off the throttle.
The issue progressively got worse.
Im down to about 40 hp or less these days. Shop and dealer have no idea what is happening and have never seen anything similar.
Does anyone know something else I should try/test/check that could cause this? Dealer said car is mechanically perfect and they're quite confused.
Thanks,
Wyatt
highmilage4runner is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 01:39 AM #2927
isaakc004 isaakc004 is offline
Real Name: Isaak
isaakc004 is on a distinguished road
Real Name: Isaak
'01 Marker Light Screw Threads?
Does anyone know the thread size for part #90168-40122 ? The screws for my corner/marker lights disappeared and I need some new ones
The 3rd Gen All Questions Allowed Thread-diagram-png
isaakc004 is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 06:26 PM #2928
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Plugs
coils
wires
MAF
Crank sensor
No vaccum leaks
Thanks,
Wyatt
How long you've been using that ECU? I would highly suspect it over anything else if it hasn't been long.
Old 04-03-2024, 07:54 PM #2929
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
What he said @Devbot . Where does ecu fit into timing of fubar?
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 04-03-2024, 10:57 PM #2930
AldoDector AldoDector is offline
AldoDector is on a distinguished road
No Crank No Power
I have a 1998 4runner SR5 3.4. As the title states it has no crank no start, as soon as I click the key onto on everything dims except for some lights on the dash. This has been an issue for a couple months now I just never was able to get to work on it/ didn’t know where to start I did have a crankshaft position sensor or camshaft position sensor code but I cleared it and was able to start up. I had a mechanic looking at it for like 1-2 months, however Iknow he wasn’t putting in the amount of effort I required because he gave up. Anyways, I decided to take a look and plugged in my obd scanner to see if anything came up and noticed that I got full power and it started right up, it did die as soon as I turned my lights on, signals made it bog down but went back up to idle. I read someone say they had a loose pcm (this is ecu right?) ground cable and it fixed it, according to the diagrams below the ground I checked was fine and I even checked it in another location, which was on the left side intake manifold. I decided to look at fuses and noticed my power 30A was missing, interior driver side fuse box, i think the guy looking at it must’ve took it out and never replaced it because he did say he was messing with them but never specified what he did. What do you guys think the issue could be? Bad ground + the power fuse? My ECU? This all happened when I was going over a bunch of dirt bumps and it just died on me so I could suspect something came loose.
AldoDector is offline   Reply With QuoteReply With Quote
Old 04-08-2024, 07:10 PM #2931
Boom_ROASTED Boom_ROASTED is offline
Boom_ROASTED is on a distinguished road
hoping for some battery/starter related direction before I start poking around
My 2000 sat for nearly 2 months if not more, during which I crank it up a few times besides the last 2 or 3 weeks and then I got in it yesterday and it won't start. Not a peep. I charged the battery ~18 hours (LED shows green "charged") and everything seems normal inside, lights on etc, but nothing happens when I turn the key. I was able to jump it off of my girlfriend's car and let it run for ~10 minutes, turned it off and notice a lack-of-sound where I expected a sound (starter?) immediately after turning off the ignition. I immediately try to crank it bank up and again, not a peep.
The battery is maybe a year old, definitely less than 2, so I'm thinking starter but I am not good with electrical stuff. Like I said it sat for a while so I'm also thinking a bad connection to the starter could also be a possibility.
I just wanted to see what you folks thought about it before I get in there.
Thanks!
Boom_ROASTED is offline   Reply With QuoteReply With Quote
Old 04-08-2024, 07:26 PM #2932
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Thanks!
I would say not your starter or jumping it wouldn't work, more likely a bad battery connection and or bad ground connection
2004 Limited V8
Old 04-08-2024, 07:28 PM #2933
Real Name: Skip
Real Name: Skip
Thanks!
I would say not your starter or jumping it wouldn't work, more likely a bad battery and or connection and or bad ground connection, just looking to see if the "charged" light is on doesn't tell you the condition of the battery, you need to check the voltage with a multimeter, should be at least 12.3 or more volts.
2004 Limited V8
Old 04-08-2024, 07:46 PM #2934
Jumping it did work though. I really doubt the battery is bad but I guess anything is possible. I'll go check it with a multimeter asap tonight
Old 04-09-2024, 01:36 PM #2935
Well shit I tested it and it read ~5.5V
I called batteries plus who confirmed I bought it in 2021, older than I realized but still within the warranty period I guess. They said I had to bring it in to test it and confirm whether or not it's defective or wasn't properly maintained. Any idea how they test it and know the difference?
Old 04-09-2024, 02:01 PM #2936
They want you in there to sell you a new battery...
And for future reference, running the engine for 10 minutes (idling) is NOT GOOD for it. Put it on a battery tender (plug in or solar if not near a plug) and leave it alone or take it for a real drive (10+ miles).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-09-2024, 05:38 PM #2937
Had the rear axles out so I was trying to do the best, (I thought), I could. Thank you for that info though.
So it's possible the defect vs owner's fault "test" is bs?
Old 04-12-2024, 08:56 PM #2938
Humboldt4 Humboldt4 is offline
Humboldt4 is on a distinguished road
Please help!
2001 4runner trd supercharged 350k miles. Trans out of lkq installed 30k ago and now when I come to a stop it just stalls out. It seems like the tc is staying locked up or the trans isn't shifting out of 3rd. Runs great while on the road just when you stop it stalls.
Humboldt4 is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 03:30 PM #2939
Thatgoodfellow Thatgoodfellow is offline
Thatgoodfellow is on a distinguished road
Ome trim packer
I’ve got some 906’s on the way for 4Runner and I was wondering if anyone knows the part number for the trim packer. I see the have a 10mm and a 5 mm. Thanks
Thatgoodfellow is offline   Reply With QuoteReply With Quote
Old 04-25-2024, 01:24 PM #2940
Crich1 Crich1 is offline
Crich1 is on a distinguished road
Hello everyone, I'm having a rough time with an electrical issue and hoping someone can give some advice. A little background on the 4runner, it is a 97 4cyl and we had an issue last year when the solenoid on the starter was stuck open and killed the battery, after replacing that it ran fine for a couple months and then died again on the highway.
Now it will start but the instrument panel doesn't work and I cannot shift out of park. I thought it might have something to do with the ecm because there was exposed wires in the wiring harness and the engine coolant sensor was fried, I patched up the harness, replaced the sensor and had the ecm tested but after all that I have the same issue. Has anyone seen anything this strange? I'm ready to role it off a cliff at this point.
Crich1 is offline   Reply With QuoteReply With Quote
extended , front , lift , rear , rear axle , rear axle housing , shocks
Another possible "cheap fix" fix for codes P0441 , P0455 , P0456. rickst29 4th Gen T4Rs 13 04-16-2022 07:29 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
"dust off" cans contain r134a, cheap a/c recharge? NTORACN 3rd gen T4Rs 1 08-10-2011 01:03 AM
17" toyota gunmetal rims "cheap" 4daRUNNER 3rd gen T4Rs 3 06-01-2009 05:52 PM
