Old 05-26-2020, 01:58 PM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
How long do piston rings last?
My runner runs fine. However I feel that it could be more powerful than it is. Iíve had the oil changed regularly. However it looses quite a bit of oil between oil changes. There are no leaks nor is there white smoke coming out of the tailpipe. I read that over time piston rings wear out like most things. Iím thinking about having a dyno and compression test done on my runner.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 02:01 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light
T4R2014's Avatar
Too many variables to give an exact number. Why bother checking if it runs good? Just creates more unnecessary worries. A JDM engine is 900 if you want all your power back.
Old 05-26-2020, 02:13 PM #3
Satter's Avatar
Satter's Avatar
Curiosity. I mean I would really like to have more power. And I understand that things wear down. I think thatís why Iíve been starting to think about getting a newer used 4Runner. But damn theyíre expensive.
Old 05-26-2020, 02:23 PM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Do a compression test and a leak down test.
Could be burning oil from a few different places like valve stem seals and piston rings.
PCV valve could be clogged.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 03:16 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is online now
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
Run a 1/4 of a quart of Marvel Mystery Oil in it for 200 to 300 miles before the next oil change. Change the PCV valve at the same time.
If that doesn’t help, it may indeed be the valve stem seals. Any blue smoke on start up?
LittleCaesar is online now   Reply With QuoteReply With Quote
Old 05-26-2020, 03:44 PM #6
alumarine alumarine is offline
alumarine will become famous soon enough
How much oil does it use between changes?
At how many miles are the changes done?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 05:30 PM #7
Satter's Avatar
Satter's Avatar
I wanna say the oil dip stick shows 1/4th full by the time itís time for an oil change. I change the oil every 5,000 miles.
As far as I can tell thereís no smoke at all when I start it up in the morning. However the exhaust smells like gasoline when itís cold.
Old 05-26-2020, 06:50 PM #8
JLTD JLTD is offline
JLTD will become famous soon enough
So it goes from "full" to 1/4 of the way above "low" in 5000 miles?
If so you're good. Most engines use a little. Agree with checking items listed above especially pcv.
What oil viscosity are you using, and how many miles on the vehicle?
2015 SR5, 65,000 miles
"Works good, lasts long time."
JLTD is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 07:31 PM #9
On a 23 year old engine, that isn’t bad. Some new engines burn more oil than that right off the lot today.
As far as the smell goes, is there any idle or stalling problems, especially at start up? It usually indicates a rich condition. An off the cuff suggestion is an injector that is running rich at start up but isn’t failing enough to throw a code on a particular cylinder. Also pull the vacuum line off the fuel pressure regulator to see if it smells like fuel or drips any gas.
Old 05-26-2020, 09:47 PM #10
FunBobby's Avatar
FunBobby FunBobby is offline
FunBobby is on a distinguished road
FunBobby's Avatar
If that doesnít help, it may indeed be the valve stem seals. Any blue smoke on start up?
Marvel Mystery Oil actually recommends 1qt in the crankcase and to run it a full oil change interval, that's what I find when I first bought mine; it's a very low strength detergent.
FunBobby is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 09:58 PM #11
pauldub pauldub is offline
pauldub is on a distinguished road
Marvel Snake Oil. Looking at the MSDS it's mostly Naptha and Stodard Solvent.
But back to the OP's question, these 3rd gen 4Runners don't really have any power in stock form.
pauldub is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 10:41 PM #12
Satter's Avatar
Satter's Avatar
Iím using Toyota brand SAE 5w-30. It has 174,000 miles. However the vast majority of those miles are inner city miles. Short trips. Start and stop driving.
Old 05-26-2020, 10:43 PM #13
I thought MMO was snake oil but have seen it firsthand slow and stop oil burning, as well as clean out a crankcase that aided in slowing down a rod knock.
But should be used IMHO as a last resort...
Old 05-26-2020, 11:26 PM #14
shadow247 shadow247 is offline
shadow247 will become famous soon enough shadow247 will become famous soon enough
GM stated it's fine to burn 1 qt of oil every 2,000 miles in a brand new truck!
If you are losing a quart in 5,000 miles on a 23 year old truck, stop worrying about it.
If you can't stop worrying, do a compression and leak-down test.
Send out an oil sample to Blackstone Labs. blackstone-labs.com/tests/standard-analysis/ - 30 Bucks for the kit and analysis.
Send out your next 3 oil changes and compare the levels of metal in the test. You can tell pretty easily based on the levels if you have a major wear issue.
2001 LIMITED 4X4 - Fresh as a Daisy at 196k! - Bone stock and staying that way! (not likely)
99 SR5 Sport - 387k and rolling! Front - Toytec 3/4 Spacer/Tundra Shocks. Rear - Daystar 1.5" Spacer/LC Shocks - FOR SALE - PM ME
shadow247 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 11:56 PM #15
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
White smoke is caused by a head gasket leak blue smoke is oil burning. The amount of oil burned is not a problem. Check your air cleaner have the spark plugs been changed during scheduled maintenance ? A compression test will tell you a bunch I do a compression test dry and wet. This is much easier and will tell you all you need to know. Cars 101: How to Do a Compression Test
Don't worry about the amount of oil I use a squirt can and put in two squirts
something like this Amazon.com: GOLDENROD (625) Pistol Pump Oiler with Straight Spout - 10 oz. Capacity: Automotive
plcfcng is offline   Reply With QuoteReply With Quote
coming , oil , piston , rings , runner
AC System O-Rings dixie_boysles 4th Gen T4Rs 5 05-17-2016 04:45 PM
D Rings mounts Jhacker1 Classic T4Rs 5 09-18-2012 05:28 PM
Hub Centric Rings krmccour 3rd gen T4Rs 4 08-29-2012 03:55 PM
What are Halo rings? KidVermicious Classic T4Rs 15 12-07-2011 09:10 AM
