Old 05-26-2020, 11:35 PM #1
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Timing Belt
2001 To-Yoda 4runner SR5 204K miles
The previous owner has no idea if he did a timing belt. Is there a way to check if the belt is good for another so miles? I'm still in the process of buying the parts for it. I have the Belt and the Pump so far. I heard from one of my pals that I could remove the top portion of the belt cover to inspect if it's still in good condition. You would think at 204K miles that maybe he did do a belt job when it was at 100k or so right? Well just to be sure I want to inspect the belt. So is there a way? Has anyone had this situation before? Thanks in advance.
cashflow50 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 11:44 PM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Just do it you will feel better afterwards
plcfcng is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 11:55 PM #3
spartacus's Avatar
spartacus's Avatar
you can slide the compression clip off of the top radiator hose take the spark plug wire clips of the timing cover loosen the 12mm bolts slide the timing cover forward and check the belt you can also rotate the crank pulley bolt clockwise and check the belt.
Old 05-26-2020, 11:58 PM #4
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
This is what I would do. You can easily inspect the timing belt this way. Make sure the seal on the top part of the timing cover is good.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 12:33 AM #5
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Alot of us would just change the belt along with other maintenance that way we have a clean record of everything and can insure it was done correctly. Changing all fluids including the transfer case and diffs and checking the LBJ to verify that it s solid would be a decent start.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 05:08 AM #6
cashflow50's Avatar
cashflow50's Avatar
Sounds good Spartacus. I will inspect using this method, since it’s my daily driver, I want to ensure the belt is good for another 5k miles til I get the rest of the parts. On a budget so it’ll take sometime yikes. Thanks again
Old 05-27-2020, 11:14 AM #7
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
If you are looking to do it in the near future don't worry about checking it just get the parts together and do it in a timely manor.
Old 05-27-2020, 01:08 PM #8
The engine is non-interference, so the worst case is getting stranded. Have your AAA membership topped up. Well, that's a good idea with a 20 year old vehicle anyway.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-27-2020, 02:01 PM #9
cashflow50's Avatar
cashflow50's Avatar
Yup I have AAA and its a must. I got stuck just recently after my fuel pump went out after doing errands. Good to have AAA
another good thing is that the engine is non-interference, although it'll be messy trying to get the old wound up and binded belt off
Old 05-27-2020, 02:26 PM #10
cashflow50's Avatar
cashflow50's Avatar
belt , good , inspect , miles , timing
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
Timing belt? or Timing chain? MNguns General Discussions 3 06-24-2013 12:06 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
