Old 05-28-2020, 05:31 PM #16
Originally Posted by TonyB66 View Post
Patrick, thanks for chiming-in. I did no hand calculations or as noted above, I never configured the UG beyond the initial set-up... I never did so before the AFR sensor replacement too, or after. I wouldn't think I'd need to do so now when I didn't before, but I might be mistaken; and why I ask here... Thanks again.
You definitely need to adjust it with hand-calculated data. My scangauge has a 7-8% correction factor, even with near 0 long term fuel trims.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-28-2020, 05:59 PM #17
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Will read-up on the procedure, thanks Charlie. I guess changing the AFR sensor screws it up to this degree... As I recall with my SC2, on my MINI Cooper S, I was able to tweak or fudge some settings like vehicle weight, displacement, something else, such that on fill-ups, adjustments were really not needed. It took some playing, but I was able to get it very close to where it became set it and forget it... Hoping to refine the UG to the 4Runner like that, at some point.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 08:48 AM #18
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I get 15.7 in mixed driving, less now that I don't drive to work 12 highway miles away..
Even the little lady's 5.7L sequoia beats it! It gets 16.5 in mixed driving, plus 200 more HPs and torque, arrrrrrr.....
Old 05-29-2020, 10:16 AM #19
Mr.Doug Mr.Doug is offline
Mr.Doug is on a distinguished road
I have a 98 T4R with just shy of 500,000kms original everything, and I seem to get around 550km to a full tank with about 75% highway and 25% city driving. Pretty happy with it so far im sure lift and tires will change that drastically haha
Mr.Doug is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 10:43 AM #20
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is online now
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Watch your tire pressures too. My mileage had gone from bad to worse (~14 down to ~11/12ish) and finally realized I had only aired back up to around 25lbs last time.
Did ~120 miles of forest and logging roads this past weekend, mix of 4hi and 4lo, running `17lbs, carrying way more crap than needed. Got just over 9mpg.
Hopeless Diamond is online now   Reply With QuoteReply With Quote
Old 05-30-2020, 04:53 PM #21
Nicknasty's Avatar
Nicknasty Nicknasty is offline
Real Name: Nick Pasquale
Nicknasty is on a distinguished road
Nicknasty's Avatar
Usually if you replace your fuel air sensor and your 02 sensor and clean the mass air flow it will make a pretty big difference and it only takes like 20 minutes. If you have torque pro and a Bluetooth scanner you can test and see if the sensors are still operating withing factory spec
2000 4runner sr5, Imperial Jade Mica, bone stock, 191k
Nicknasty is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 09:19 PM #22
vonhughes vonhughes is offline
vonhughes is on a distinguished road
2002 Sport here and I decided to calculate my mileage for the first time today. I've owned the rig for about a month now.
Ended up doing 288.7 miles @ 17.4 MPG...which surprised me after hearing about the terrible mileage I could expect. Not that the number is fantastic mind you, our Honda Odyssey can do nearly 30 MPG if we have good weather and a long stretch to let cruise control do all the work.
So far, most of my driving has been 10-15 mile trips on roads that let me do 40-50 MPH while hitting a stoplight or two, a handful four-way stops and the occasional round-a-bout.
I won't track every tank, but I will try to gauge some highway mileage later this summer.
vonhughes is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 10:03 PM #23
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Armored double cab taco, 4x4, at, 4.10s and 35's. 3.4 supercharged all stock otherwise gets a very consistent 13.
Nearly stock 4x4 2.7 with 3" of lift and multiple tire setups will get between 10-12 mpg depending how I drive.
I don't drive like a jackass, don't speed, just basically cruising back roads at 55ish most of the time. I just don't believe anyone who claims 17+ on a built rig, I've had a lot of these trucks, only one that would do that much was 2wd, 2.7 5 speed, 3.73s and 235/75r15. Hypermiled to 23 mpg once, but typically did around 17.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 09:22 AM #24
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Your welcome Tony. I went through the whole 9 yards of calibrating mine. Calibrating the distance, calibrating the fuel economy over the course of 4 tanks, etc. There is an anomaly that I haven't taken the time to figure out yet. After calibrating for distance traveled it corrected the mph of the gauge to within 1 mph at highway speeds (cluster shows 70 and gauge shows 71) but my trip mileage on the gauge will be about 4% higher than the cluster trip mileage. Kinda strange and probably skewing my mpg's on the gauge slightly higher than reality. If I find time I'll recalibrate the distance and mpg's again. If you decide to calibrate yours it is recommended to calibrate distance before mpg's.
Old 06-04-2020, 09:26 AM #25
Real Name: Patrick
Real Name: Patrick
You're welcome Tony. I went through the whole 9 yards of calibrating mine. Calibrating the distance, calibrating the fuel economy over the course of 4 tanks, etc. There is an anomaly that I haven't taken the time to figure out yet. After calibrating for distance traveled it corrected the mph of the gauge to within 1 mph at highway speeds (cluster shows 70 and gauge shows 71) but my trip mileage on the gauge will be about 4% higher than the cluster trip mileage. Kinda strange and probably skewing my mpg's on the gauge slightly higher than reality. If I find time I'll recalibrate the distance and mpg's again. If you decide to calibrate yours it is recommended to calibrate distance before mpg's.
Edit: I might try using a gps app to calibrate distance traveled which changes the mph on the gauge. The recommended way in the instructions is to use a fairly straight highway, start at a mile marker and then drive to another mile marker x miles down the road and stop at it. It will ask how many miles you went and then adjust accordingly.
Old 06-04-2020, 11:03 AM #26
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
I get about 16 on a normal tank, and 18 if there’s a longer trip mixed in there like 2.5 hours round trip. This is with a 5 speed, 33s, and manual hubs.
I got 20 on an 8 hour trip but that was with the auto trans and no locking hubs
RandyBobandy is offline   Reply With QuoteReply With Quote
average , commute , miles , months , stock
Worst discount ever repo General Discussions 7 04-20-2018 02:32 PM
Best Buy is actually the Worst Buy AntleredRuin Off Topic 28 01-18-2017 11:33 AM
Worst Nightmare jahdai42 3rd gen T4Rs 6 10-11-2014 08:59 PM
Worst Mod? Bigbugberg 5th gen T4Rs 12 05-01-2013 12:05 AM
Worst mod you've ever done? MillerPKA 3rd gen T4Rs 30 04-04-2011 10:03 AM
