Old 06-13-2017, 07:21 PM #1
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Rear sway bar hits locker housing
I put the e locked rear axle in today my 97 and got it bolted back up. When I put the sway bar back in it just hits the elocker housing. Checked it against another sway bar I had and they are both the same, one of them came off the locked axle. I never heard of anyone having this problem and tomorrow I will pull it off and go at the bar with a sledge hammer just to get the clearance I need. Anyone else have to do this?
Rear sway bar hits locker housing-img_2655-jpg
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 06-13-2017, 08:35 PM #2
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
Pretty sure you need the sway bar relocation brackets like SS sells to get the sway bar to clear the locker when lifted.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 06-13-2017, 08:51 PM #3
St Runner's Avatar
St Runner's Avatar
Thanks Unner, running OME 906 with 10mm trim packers so its not sky high but there is no extra weight either. That does give me some ideas to work on
1997 SR5 4x4
2001 SR5 4x4
Old 06-13-2017, 10:05 PM #4
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Or you can just ditch the sway bar
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 06-13-2017, 11:38 PM #5
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
Longer sway bar end links help at all? Trying to remember which way the sway bar swings.
I don't have any clearance issues with my 2000. Elocker rear, factory sway bar but with longer links.
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 06-13-2017, 11:58 PM #6
Nate_GB's Avatar
Nate_GB Nate_GB is offline
Nate_GB is on a distinguished road
Nate_GB's Avatar
It's a pretty common problem from what I've seen. Even stock trucks have the issue. Longer links will help to rotate the bar down towards the pinion. But you can't go too long on the links otherwise they will start to contact the lower control arms on compression of the suspension.
Nate_GB is offline   Reply With QuoteReply With Quote
Old 06-14-2017, 12:55 AM #7
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
the sway bar seems to be misplaced basing on the pic. shouldn't it be located above the locker motor instead of below it?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 06-14-2017, 02:10 AM #8
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
That's super strange. My '97 was +3.75" in the rear- with stock end links- and my RSB never hit the locker.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 06-14-2017, 04:56 AM #9
the sway bar's bend over the pumpkin is such that there is space to clear the locker assy. that's why the center of the bend is not centered over the pumpkin instead is located towards the driver side.
the OP could have reversed the orientation of the sway bar that's why it's hitting the locker assy
Old 06-14-2017, 06:46 AM #10
St Runner's Avatar
St Runner's Avatar
Thanks for the replies. The bar is on correctly, that pic is taken from below on the ground and the bar just clips the top forward corner of the locker housing. No way it will fit any other way. I think i will make a couple spacers to put under the brackets along with some longer bolts. This will bring the whole bar forward and up just a bit. I tried doubling up on the bottom bushing on the sway bar link,(essentially making the link longer) but this actually made the contact worse
1997 SR5 4x4
2001 SR5 4x4
Old 06-14-2017, 07:27 AM #11
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
The SS1.2 kit I installed comes with SB raise brackets. Using steel flat bar 1/4"x 1 1/2"x 4" apprx on the length. Flat bar raises SB 1 1/4", forward slightly due to angle of mounting bracket on axle. All that you need are two pieces of flat bar, a drill and bit, 4 extra bolts & nuts. It is more important to go up than away from axle. Mount the flat bar to existing axle mounts, center the SB bushing over upper existing bolt drill two holes to mount SB in new location. you need to cut hole in rubber bushing so SB bushing sits over upper bolt head. You might do it a different way just splaining how it's done on SS1.2. Then get you end links for 2nd gen runner to compensate for new ride height, they are 1 1/2" longer. A pic would be better I know, but vehicle is 350 miles away.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 06-14-2017, 08:01 AM #12
St Runner's Avatar
St Runner's Avatar
Thanks for the explanation 96RedRunner. Most helpful to figuring out what to do. It will take me a couple hours to make the bracket but at least a week to order anything even if they will ship it here. A theoretical question, If you raise the bar 1 1/2" with this bracket is it even necessary to get extended links as it will be doing the same thing?
1997 SR5 4x4
2001 SR5 4x4
Old 06-14-2017, 08:53 AM #13
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
My sway bar is raised with SS lift brackets. I ended up going 2ng gen links anyways because they were under stress still.
JayRolla is offline   Reply With QuoteReply With Quote
Old 06-14-2017, 09:07 AM #14
Real Name: Mark
Real Name: Mark
Anytime thats what makes the forum what it is.
Use the 4 factory bolts to mount flat bar to axle. Then scrounge junk pile for the 4 bolts, nuts, washers you need that best fit holes in SB bracket. 3/8ths" should fit. does'nt have to be metric, yota, just sound bolts n nuts.
Theoretically speaking, the object of design is to keep the end of swaybar at end link parallel with frame rail, as all auto manufacturers do. So it is lift amount dependent. You don't have to have extended end links if S/B clears Locker when suspension is flexing.
Old 06-14-2017, 09:30 AM #15
Real Name: Mark
Real Name: Mark
JayRolla, Know what you mean. If you wheel on the edge (you in CO for sure you do) best to have things set up right.
e locker axle housing vs non e locker axle housing HiluxSurfGuy 3rd gen T4Rs 11 08-15-2020 11:24 PM
97 Ltd 4wd no e-locker rear diff 3rd Member stuck on axle housing; Broken diff stud. azcat90 3rd gen T4Rs 19 09-08-2016 12:07 PM
3rd gen complete e-locker & housing 4.10, CO, $300 Bfaulken For Sale: T4R Items 8 06-13-2016 08:50 PM
WTB: looking for an E locker rear differential housing or complete 99blackt4rsport For Sale: T4R Items 0 04-12-2015 02:30 AM
WTB: 3rd Gen Rear axle housing(non E-locker) - ALBERTA, CANADA SwainJ Want to Buy/Trade 0 04-27-2014 07:56 PM
