Old 05-29-2020, 12:15 PM #1
Y2K-4runner Y2K-4runner is offline
Y2K-4runner is on a distinguished road
Need info on proper CATs for 2000 Limited Exhaust
My 4runner has the 2 cat system. I'm guessing it was set up for CA even though it was bought here in PA. Anyways, rust has destroyed the flanges and I've had the code for the front sensor for a while. It is a spare vehicle that's been sitting and needs the safety inspection done. Rockauto appears to have 2 different sets of CATs for it. One set is C. A. R. B. and the other isn't. They lower prices ones are made by Eastern. Since I don't live in CA, do I need to still bolt on the C. A. R. B. units? Will it cause problems if I get the non-CA compliant? They cost quite a bit more. I plan on buying the Denso sensor since the rear worked out good. Thanks!
Y2K-4runner is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 12:30 PM #2
The pipes between the non-CARB and CARB cat systems are mechanically different. Is the non-CARB approved option you are considering meant to bolt in place of the CARB system?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-29-2020, 10:50 PM #3
jjf8's Avatar
jjf8 jjf8 is offline
jjf8 is on a distinguished road
jjf8's Avatar
I did a a-z replacement on my Cali emissions 2000 Sr5
This is the parts list I ordered form Rock Auto,
Def has more power and runs smoother,
Need info on proper CATs for 2000 Limited Exhaust-untitled-copy-jpg
jjf8 is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 05:29 AM #4
Thanks jjf8. Did you have any gasket issues between the Eastern Cat and muffler pipe? That looks just like what I was going to do actually. I am planning on buying the Walker muffler and pipe locally at Advance.
Old 05-30-2020, 08:46 AM #5
Crazy09sage's Avatar
Crazy09sage Crazy09sage is offline
Crazy09sage is on a distinguished road
I bought the walker cats and they bolted right up on my rig. Walker 53616 & 52399. Amazon’s part finder says they don’t fit so you have to use Walker’s part finder. I installed the whole Walker system plus Denso sensors back in 2017 and they’re still going. Be sure to spay the walker parts with some high temp paint. They have a tendency to rust quick.
Edit: looks like the second cat has a different part number on the ‘02 vs the ‘00. Here’s the parts list...
2002 4Runner SR5 4x4 - Stock”ish”, ISR Mod, LED interior, 99 coils, Bilstein 4600’s, Walker exhaust.
Crazy09sage is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 11:45 AM #6
firemanj92 firemanj92 is offline
firemanj92 is on a distinguished road
You do not need the CARB cats unless you are planning to smog your vehicle in CA. You run just about any cat that will fit/weld in place without a CARB certification.
CARB cats do not have different pipes only a CARB Executive order stamped/etched certification on the cat and a (California) premium price that is required by the smog technician to input for smog.
I replaced my cats with Magnaflow CARB certified and verified with MF that there is no difference in build other that the certification. Hope this helps.
firemanj92 is offline   Reply With QuoteReply With Quote
cats , compliant , denso , sensor , set
Looking for used exhaust manifolds/cats for a project Dr. Monkeypants 5th gen T4Rs 5 07-16-2019 11:08 PM
New headers and new exhaust, what to do about cats? hobosapien 4th Gen T4Rs 0 01-28-2016 02:02 PM
2001 T4R exhaust 2 cats? Jaynhunt 3rd gen T4Rs 2 04-10-2014 11:59 AM
08 4.0 Exhaust Manifolds and Cats Tri State Danst165 For Sale: T4R Items 0 04-02-2014 04:52 PM
Proper Tire Pressure Info Whoknows Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-18-2006 07:09 PM
