Old 05-24-2020, 02:09 PM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Is a roof rack necessary for a rooftop tent?
I'm looking into the Tepui Hybox which measures 84"L x 55"W. Aftermarket roof racks (like the Sherpa Matterhorn) measure 92"L.
If the the tent pretty much covers all of the length of the rack, would I really need to spend another $1000+ for a rack? Are there brackets that would mount directly to the factory rails to mount the tent instead of mounting on a rack?
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 02:56 PM #2
yota275 yota275 is offline
yota275 is on a distinguished road
You might need to look into weight limits on your factory rails before you consider sleeping on them. I'm not familiar with 09, but i know on my 11 the factory rails are really only designed to handle the weight of one person even when you aren't moving. I went with Rhinoracks pioneer platform rack and their "backbone" rails. That combo supports 700+ lbs static and over 200lbs while driving.
yota275 is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 05:00 PM #3
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
The roofs on our 'runners aren't exactly up to the task of handling much weight. After I pulled a headliner from a junkyard 'runner to grab a few items, I noticed that there is literally just a small "c" shaped piece of metal that works as a doubler for the factory racks mounting hardware ( riv-nuts).
I was ready to get a Sherpa rack system for my Tepui RTT but after seeing how flimsily our roofs are, there's no way I'm climbing my 235# body on top of the stock roof. I honestly wouldn't feel safe hauling the RTT up there, even though some do it. The stock cross bars will barely hold the weight of the tent by itself, no way they're going to support a person inside of the tent. Even with an aftermarket rack system spreading out the weight a bit, it's still only being supported by a thin piece of sheet metal. There needs to be a physical tie-in between the factory rack "doubler" and the side of the roof skin where it curves downwards on the sides of the upper body.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 06:58 PM #4
Whakeen Whakeen is offline
Whakeen is on a distinguished road
@benjamin247
Given what was posted earlier about structural strength maybe I need to revisit my setup but I thought I would post some pics of what I did to mount my RTT.
I didn't want a basket style roof rack so I used square tubing for the small mounts on the roof rails as well as the cross bars. I wanted it as close to the roof top as possible to keep the center of gravity lower.
So far so good. I've been on bumpy forest service roads and highway speeds without any movement of the custom mounts, however, the front end of the RTT catches enough wind which flexes the actual 4Runner roof; this results in a bit of bounce from the front end of the RTT.
I'm in the process of extending the rails to install another mount further up front to spread the load.
To answer your question if you 'need' a roof rack, well, it depends on the mounting system of the RTT. My RTT mounting system requires enough clearance underneath it to get nuts on the bolts that hang down below the cross bars. If your RTT has a mounting system directly over the rails you may be able to skip a rack, basket or cross bars altogether.
Is a roof rack necessary for a rooftop tent?-4run-jpg  Is a roof rack necessary for a rooftop tent?-4run-b-jpg  Is a roof rack necessary for a rooftop tent?-4run-c-jpg
Whakeen is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 11:59 PM #5
Edwin562's Avatar
Edwin562 Edwin562 is offline
Edwin562 is on a distinguished road
Edwin562's Avatar
Legit set up Whakeen!!!
Edwin562 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 03:19 AM #6
@Whakeen I like that! ����
Hmm...I wonder if adding a crossbar with a wind deflector to the front end of the roof would lessen wind from getting under your RTT?
Old 05-25-2020, 12:07 PM #7
Edwin562. Thanks!
@benjamin247 . I've considered adding a windscreen under the front of the RTT but if it didn't work and the RTT was still moving up and down a bit the windscreen could damage the 4Runner roof. I did also look up the Tepui Hybox but can't find an image of the underside so I can't give any perspective on mounting designs.
For me I feel that extending the roof rails is the solution (partially based on cost). Now if I can only find a cheap set!
I did recently see someone post how they used L-Track to replace the roof rails and extend the usable area. Had I known about L-Track years ago I would have gone this route for mounting the RTT.
Let me know if you buy a tent and I'd be happy to give my 2 cents on mounting options as I've spent way too much time thinking about mine.
Old 05-25-2020, 01:22 PM #8
derek rosé derek rosé is offline
derek rosé is on a distinguished road
I'm keen for those 2 cents! Looking to pick up a soft shell tent in the next few weeks and would love to know it's secure up there.
I currently have crossbars on standard rails (not sure of the load rating yet).
derek rosé is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 01:39 PM #9
@derek rosé , so you have OEM rails. Do you also have OEM crossbars? If yes, I wouldn't recommend mounting an RTT on the OEM crossbars. They definitely are not strong enough to support it. FULL DISCLOSURE: i'm not an engineer. I can only speak for what has worked for me so please take that into consideration.
@benjamin247 , I don't want to hijack this thread so let me know if you prefer us to PM or start a new thread.
Old 05-25-2020, 02:13 PM #10
barongan barongan is offline
barongan is on a distinguished road
nice suggest
barongan is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 12:47 PM #11
@Whakeen had a look this morning and pretty sure I'm OEM all round. Time to look into some other options!
Old 05-26-2020, 01:00 PM #12
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
longer channel stock with feet has worked well for some.
I think if you look up cheap roof racks or something on this forum you will see lots of options...
while stock cross bars are only rated at like 160 pounds, I can tell you I have far exceeded that, safe ? but drove form oregon to alaska with a ton of weight in my rack mounted to stock cross bars. Yet I have 3 cross bars on extended factory rails ( you can also see this in the cheap roof rack thread)
the little rubber cross bars that sit directly on the roof can take about as much weight as 3 alaskan mosquitoes each
( our mosquitoes are big and should have tail #'s and landing lights )
Old 05-26-2020, 02:54 PM #13
MStudt's Avatar
MStudt MStudt is online now
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
You don't need an entire rack, but you will most likely need some cross bars that are stronger than OEM. You need some feet like the ones I have below, and they bolt to the factory channels in the roof. Then you can connect some 1x2 extruded aluminum to the feet to act as cross bars. Much like what I have in the second picture, but without the side rails.
MStudt is online now   Reply With QuoteReply With Quote
Old 05-27-2020, 01:00 AM #14
All good continuing discussions here. I’ll take all the info I can get.
Old 05-27-2020, 12:28 PM #15
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by MStudt View Post
You don't need an entire rack, but you will most likely need some cross bars that are strong than OEM. You need some feet like the ones I have below, and they bolt to the factor channels in the roof. Then you can connect some 1x2 extruded aluminum to the feet to act as cross bars. Much like what I have in the second picture, but without the side rails.
nice feet...you buy someplace ? Where
length , mount , rack , roof , tent
Can you put a Roof Top Tent on 4 runner factory roof rack 68GTconvert 4th Gen T4Rs 83 04-13-2024 01:10 AM
Mounting a roof top tent (RTT) on a Whitson Metalworks roof rack? aleks77 3rd gen T4Rs 12 06-06-2014 06:19 AM
Gobi Rack GROUP BUY. Stealth Rooftop Rack. Free ladder or sun roof insert reklov 5th gen T4Rs 300 06-26-2012 07:57 AM
Gobi Rooftop Rack GROUP BUY. FREE ladder or sun roof insert reklov Engines / Suspension / Wheels / Tires / Audio / Accessories 8 07-28-2011 04:22 AM
Roof Top Tent and Rack dwulffusa 4th Gen T4Rs 7 07-11-2006 04:11 PM
