Old 05-30-2020, 12:20 AM #1
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
JZiggy's storage/camping/sleeping platform
Hey dudes,
My cargo platform build is coming along and I thought I'd share what I have done so far. First off -- thanks to all the folks that posted up their own builds over the years. I studies dozens of them to collect ideas and it was great to see all these interesting builds to get the ideation going strong.
Goals for this platform:
- Minimize overall weight (my 3RZ will thank me *wheeze*)
- Able to make main platform out of a single 4x8 sheet of plywood
- Able to sleep a 6'4" person facing straight, not diagonally. Can accommodate two sleepers
- Rear area should be able to stay semi-permanently installed and act as a simple cargo platform for day to day use. But must be able to take it back out without much hassle
- No drawers but cargo area sized to accept cheap standard plastic bins that are readily available at Walmart in case they get busted or lost
- Front area designed for sleeping only, to be removed before driving. Not for storage or maybe only light items
- Front area needs to rest on top of rear area when not in use and able to take it out to leave at home when not needed
- Rear seat bottoms to be removed for sleeping but the rear seat backs always stay installed
So here goes! The rear cargo area is made with a single 2x8 as the center support. Lots of stuff attaches here so it needs to be stout. The rest of the box is 1x8 common boards and a 1x4 and 1x8 cross beam for support. Angle brackets are used underneath to stiffen it.
Rear platform on top is contoured on the passenger side to allow access to the wheel well tie down I added. Driver side is contoured more deeply around the higher wheel well. The sides are about an inch from the interior panels so you can still reach down into the cubby from the top. The width is the 48" that the 4x8 plywood is cut to.
Angle brackets are secured underneath and behind the main beam and borrow the holes for the front tie downs. I put a stud in place of the bolt which is really handy. When the box is placed inside you just slide it up and over the studs and it is in position. An M6 flange nut is used to fasten.
The front platform is contoured on the driver side only and rests flat on the rear area. It's 2.5" shorter than the rear area. Later we'll add holes to allow it to be pinned to the rear platform so it doesn't slide around when driving.
Front platform fits when the front seats are moved up a little and angled straight up. Later we'll add a cutout in the front center to allow access to the wonderful BHicks 3D printed cupholder.
Here's how it looks out of the truck.
Now it's time to get jiggy. I wanted the front platform to key positively into the structure since I'm not using a hinge. Cutouts were made and two pieces of aluminum flat stock are installed recessed with a 1/4" through hole that also passes through the plywood.
Two mating pins are installed in the center beam for these 1/4" holes to key into. I sunk two 1/4" lag bolts down into the beam and cut off the heads. The aluminum was used on the front section so that the joint is strong and the plywood doesn't wear with repeated installations.
Here's how the two platforms mate up when the front is dropped onto the pins.
The front section is supported with three removable dowel legs. The legs have little plywood biscuits as feet to spread the load out. I sunk hanger bolts into both ends of the dowel. The feet and the platforms will have tee nuts to let the 5/16" studs screw into them. These can be disassembled for storage. One nice things is that since the dowel is threaded on both ends so the support can be extended a bit if needed to level things out.
I want to be able to store my 7 gal water jug in the back here. I plan to cut part of the passenger side wing off and attach with a piano hinge. This way it can fold up 90 degrees to accommodate the jug and fold down for sleeping.
So that's where I am so far! More pictures to come of course. Next steps:
- Create the hinged side for the water jug
- Paint the undersides so there is no bare wood to give one splinters
- Install some automotive tan carpet with underlayment to soften up the platform
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 12:49 PM #2
diy_overlanders's Avatar
diy_overlanders diy_overlanders is offline
official vendor
diy_overlanders is on a distinguished road
official vendor
Man that’s a really innovative solution to locking that front platform in place. I like the idea of avoiding the use of hinges there. Keep it up looks good man!
... Ask me about DIY Drawer System Kits, or check us out on Instagram
diy_overlanders is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 01:14 PM #3
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
JZ is well-known around here for such. Go through his build thread, if you have not already...
JZ - If I were building a storage platform, I too was sold on the bin approach. Love it, for a few reasons. There are times I think of a construction project that permits access to my storage below. I have some ideas already, just not the perceived need for more storage...
Thanks for sharing.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 05-31-2020, 12:30 AM #4
JZiggy's Avatar
JZiggy's Avatar
More updates:
Close up of the pins that lock the front platform to the rear
The side beams are angled so when the seats are up they sit flush. Cutouts at the bottom allow a socket to access the nut holding the brackets.
More on the 7 gal Reliance water jug. I added a little wing to give a frontal support to the jug and a support to the hinged portion. There's also a little bit of trim added inside to support the hinge and the platform.
Hinged wing trimmed out and fitted with a piano hinge.
I got some carpet and underlayment from yourautotrimstore.com. This is 2.5 yards (72" x 90" nominal). The price was good and shipping turned out to be next day. They we're skimpy either as the final length was more like 96". I ordered the "sand" color which turned out to be a pretty good color match. The carpet is decent quality but not awesome which is OK. Rolled out
Underlayment trimmed and on the front section
It's kind of a pain trimming the carpet and cutting it so that it wraps around the contours. But it turned out OK with some care. I left a 4" flap loose on the back to cover the seam... might trim it up and adjust once its all done
Here's how it fits up against the rear platform
More on the front section support columns. I wanted to use a minimal amount of these to keep things simple and leave room underneath for storing stuff. I found that two columns at the corners and a single in the middle bridging the seat backs was sufficient. Here's how it looks from underneath when its all installed.
Tomorrow I will carpet the rear section. I had to finish up the woodwork and paint the underside and it needs some time to dry. I used some leftover gray exterior house paint.
Old 05-31-2020, 10:19 PM #5
JZiggy's Avatar
JZiggy's Avatar
Carpeting the rear area. Here's the underlayment trimmed for the hinge
All carpeted. Man that's a pain in the butt. I do not want a career in upholstery. Underside has been painted too.
Installed using the flange nuts on studs. I was able to sneak the cargo tie down hooks in there too. With motorcycle straps they can still be reached.
Rear platform installed
Water jug fits great
I got two 52qt Hefty bins from Walmart. These fit perfectly in the slots. They squeeze in a bit and are then slightly captured by the front 1x4 support so they can't slide back and forth.
Recall on the front platform I left a 4" flap of carpet past the seam. This turned out to work great
Front platform installed in "travel mode." The flap is hanging down and actually gets captures by the rear hatch so it cant move around much
Front platform installed in "sleeping mode." Here the flap covers the seam where the front and back sections connect. You can even tuck the little sides down so that its taut.
Another shot of the front support legs
Finished product
I weighed the individual sides:
Rear platform and box: 56 pounds
Front platform with legs: 30 pounds
Total is 86 pounds.
Concluding thoughts... this really turned out good. Better than I originally thought it would. The carpet plus underlayment really makes it comfy to lay on. I think a thin mat or even just a sleeping bag would be sufficient. I'm able to stretch completely out with my head against the hatch. The platform front and back is plenty stiff even with just the three dowel legs up front. I think the positive connection in the center really stiffens up the front platform.
I'm glad I took the time to make the door for the water jug but I realized that I need to also make some kind of flap for the front section. In "travel mode" the wing of the front platform covers this door -- crap! Well, one more little adjustment to make and then it should be done.
Then I just need to test it out!!
Old 06-01-2020, 10:35 AM #6
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Top notch work as always! Clearly designed by a first class engineer ;).
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 07:44 PM #7
JZiggy's Avatar
JZiggy's Avatar
Added a door on the front platform to allow the door on the rear to come up when installed in "driving mode" and make room for the water jug. As a bonus this door lets you access the area under the front platform more easily. Hinge was raised 1/8" to help the door go closer to flat when open.
And now I am officially done which is a relief since I am tired of working on this thing!
Old 06-03-2020, 07:41 AM #8
official vendor
official vendor
Finishing out a project like this is the best!! Looks good man.
I know it was one of your goals to keep it as light as possible, just curious did you ever see how much this storage platform weighed in the end?
Old 06-03-2020, 09:55 AM #9
JZiggy's Avatar
JZiggy's Avatar
I didn't reweigh after adding the second hinge but I doubt that changed it much.
The rear section is 56 pounds. The front, with the removable feet, is 30 pounds.
Old 06-03-2020, 11:02 AM #10
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
I'm wanting to build a rear storage area as well. I like this idea, has to be much lighter than adding drawers.
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 06:21 PM #11
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Clean! Looks really good!
weekendclimber is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 08:25 PM #12
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Currently working on a platform myself with similar requirements. I might still go the drawer route but I like how you handled the front section. Simple is good.
Do the bins rattle around and make noise as you drive?
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 11:09 PM #13
JZiggy's Avatar
JZiggy's Avatar
No, they are pinched in there a little bit so they don't scoot around at all!
Old 06-03-2020, 11:16 PM #14
marcus clarkus's Avatar
marcus clarkus marcus clarkus is offline
marcus clarkus is on a distinguished road
Great job man. I need to build one of these myself. It seems like such a huge time commitment though so it's hard for me to get started. How many hours do you think you have in designing and building this thing? Did you CAD it out first?
1999 Toyota 4Runner SR5 V6 4x4 5spd - 317k miles as of Feb 2024
3D Printed SR5 Mudflaps
FS: 3D Printed Outlet Covers - Convert rear ashtray to 12V/USB outlets
marcus clarkus is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 12:01 PM #15
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Cool design. I like the piano hinge wing & the bins to maximize storage space. Great idea of using compression to secure the bins. I like the finished product of upholstered stuff but doing it sucks if you want it to look right.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
area , front , platform , plywood , rear
Sleeping Platform/Storage MStudt 3rd gen T4Rs 70 11-07-2019 01:06 PM
FS: 4th gen storage platform + fold-out sleeping platform (Boston, MA) xxaarraa For Sale: T4R Items 18 05-15-2019 10:32 AM
Sleeping/storage platform BikeDestroyer 3rd gen T4Rs 7 07-10-2017 06:24 PM
Need help 3rd gen sleeping/storage platform Theone General Discussions 12 08-27-2016 09:30 PM
Tin Man 2.0 storage / sleeping platform sandracer33 3rd gen T4Rs 2 10-05-2014 08:07 PM
