Old 05-30-2020, 12:56 AM #1
Crackership's Avatar
Crackership Crackership is offline
Real Name: Dave
Crackership is on a distinguished road
Real Name: Dave
Hi, I just snagged a 3rd Gen T4R and I have some questions
Hi all,
I've had a 2nd gen T4R for nearly 10 years and have loved it but I just rolled the dice on a 1996 Limited with E-Locker I found for a song. Like, it was CHEAP.
It runs, but has a misfire on cyl2. I pulled the plug and it doesn't look like it's firing at all, so I'm figuring to throw a coil on it. Any suggestions or ones to avoid?
It also has some "mods", most of which involve butt connectors, electrical tape and zip ties. Now, like all good 2nd gen owners, I have a resistor taped into the EGR plug to keep the CEL from going off after the EGR valve crumbled in my hand one day, so I know not all "tape and zip ties" mods are totally janky, but being new to the 3rd gen, I don't know what's been done for a reason and what's just dumb. Hopefully you guys can tell me if there's any reason for any of these things before I go trying to figure out how to fix them.
First up is this guy, spliced into the diagnostic plug harness.
Second is this thingy zip-tied to the MAF harness
And finally, this box.. which I assume is a charcoal canister? Buzzes for a while after I shut the truck off.
Any ideas?
I really appreciate any help!
TIA
-Dave
Crackership is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 01:11 AM #2
Theginger91 Theginger91 is offline
Real Name: Elston
Theginger91 is on a distinguished road
Real Name: Elston
Originally Posted by Crackership View Post
Hi all,
Any ideas?
TIA
-Dave
1st id check compression on #2 cyl.
Theginger91 is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 01:40 AM #3
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
Can you follow those wires and see where they go?
Sent from my SM-N975U using Tapatalk
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 01:44 AM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
The MAF connector thing is normal factory.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 02:13 AM #5
Real Name: Dave
Real Name: Dave
That's the plan for tomorrow. Just thought I'd ask before I go digging.. just in case that's the "unicorn rocket booster mod" and everyone's doing it or something like that.
Awesome! Glad I asked!
Old 05-30-2020, 02:38 AM #6
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
See if the radiator has been replaced and check those LBJ's.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 02:58 AM #7
Real Name: Dave
Real Name: Dave
The radiator has been replaced, and I figured the LBJs are a given.
Old 06-02-2020, 01:39 AM #8
Real Name: Dave
Real Name: Dave
Alright, so I chased those wires and it led me to a janky alarm install. So I pulled all of that out.
Also replaced the coil and the misfire is gone. Hooray!
It does still idle very rough though. It's worse when in gear and when warmed up. From reading this forum, that sounds like the IAC valve needs a good cleaning, you all agree? It's not throwing any codes.
Old 06-02-2020, 08:15 AM #9
HiLife HiLife is offline
Yes I would remove the IAC and do a good and careful cleaning. Careful cause of the electric motor in the IAC.
I would clean the throttle body too while I'm at it.
Old 06-02-2020, 10:16 AM #10
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
The charcoal canister buzzing is how my '96 talks to me and tries to get me to take it for a drive, like a puppy wanting to go on a walk I've had it sitting for multiple months and it will keep doing it.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 02:00 PM #11
Yup, the early charcoal canisters can make a buzzing / resonant sound. There is a TSB on it where they add a small chamber to the front most hose out the top to stop it. Not a problem, just annoying. Later charcoal canisters have at built in to the hose outlet (an extra chamber).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-02-2020, 02:47 PM #12
yeah, gotten use to it, call the 4R Wheezy. It's just like me, a little exercise and it wheezes for hours
Old 06-02-2020, 03:48 PM #13
raulb21's Avatar
raulb21 raulb21 is offline
Real Name: Brett
raulb21 is on a distinguished road
raulb21's Avatar
Real Name: Brett
If cleaning doesn't do it, I'd just replace the IAC Valve. I had a CEL on and off for a while, traced it to that. When cleaning didn't do it, I just replaced the valve. Haven't had a problem since. Just don't strip the 4 screws getting it off, they can be a pain. Use one of those Japanese industrial screw drivers.
raulb21 is offline   Reply With QuoteReply With Quote
gen , mods , plug , tape , zip
2001 4runner tranny questions possible swap questions. Did search samario1984 3rd gen T4Rs 5 06-09-2017 01:27 PM
snagged a manual 98 soupkitchen 3rd gen T4Rs 33 07-07-2016 09:45 PM
few questions kolelt 3rd gen T4Rs 7 09-13-2014 01:47 PM
Just snagged an 01 4runner sr5 with 45k! 01YO New Members 8 05-17-2012 04:35 PM
Garmin iQue voice nav questions and Topo maps questions. Expat Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-11-2005 09:49 PM
