Old 05-30-2020, 05:21 PM #1
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Help with any knowledge on the RS3000 VIP security system (1998)
Quick situation background - 1998 4runner limited with port/dealer added RS3000. I've done a ton of research just to get a fob programmed and working. I have the TSB on how to program it as well as an RS3000 manual I found online. I have a grey 2 button factory remote as the TSB describes for 1998.
With the key on and the programming button depressed for 3 seconds, the Toyota Security LED doesn't ever illuminate as it should so I can sync the fob. Looking at as much wiring as I can see with the left kick panel off, everything seems intact. The only non-stock item is the radio. Does the RS3000 system interface with the factory radio at all?
Also, what is this for? It has a button on the back that will illuminate the LED. I believe it's connected to the blue glass breakage sensor.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 08:09 AM #2
HunterM HunterM is offline
HunterM is on a distinguished road
I actually have the bottom dash panel out right now in my 98. Have nothing close to looking like that. Back when I bought my truck 5 or so years ago it came with a FOB. Never worked. Tried reprogramming years ago. The light on line never came on either. All that said I put an aftermarket head unit in before I even unloaded it off the trailer when I got it home all those years ago lol. That could certainly be an issue for me. I'll know more in a few hours. Gotta tie up loose ends on my timing belt, water pump, and valve covers before I go crawl back in that floor board
Sent from my moto e6 using Tapatalk
HunterM is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 01:41 PM #3
bdjcl bdjcl is offline
bdjcl is on a distinguished road
I have a 98 Limited and can maybe help. However, I don't recognize that light under your dash at all. My glass break sensor/flashing light is on the front of my center console near the rear window glass switch, beside the parking brake. Can you share a picture of the center console area?
The actual security module is under the driver seat and I didn't have any issue purchasing a 2-button, gray fob from ebay and programming it.
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
bdjcl is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 05:26 PM #4
stuckinthemud stuckinthemud is offline
stuckinthemud will become famous soon enough
I have a 1997, I'm on my second after market head unit. My 2 button remote works fine. So the head unit should not affect it.
It's possible that the memory in your unit is full from previous owners ( I think it only holds 5 remotes). try to erase all previous remotes first. Then try to program your new one. hope this helps.
stuckinthemud is offline   Reply With QuoteReply With Quote
button , factory , led , rs3000 , tsb
Toyo VIP RS3000 Security system Trouble T4RWILL 3rd gen T4Rs 25 04-07-2021 08:12 PM
WTB: RS3000 V.I.P security system ECU seanxgodfrey For Sale: T4R Items 1 03-15-2014 03:30 PM
Installation kit for Toyota VIP RS3000 security system txtroutbum Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-21-2006 05:14 PM
Genuine Toyota RS3000 Plus Security Systems for $59.00 shipped brand new! toyota_speed Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-14-2003 04:26 PM
