Old 05-30-2020, 05:55 PM #1
MountainBrew MountainBrew is offline
MountainBrew is on a distinguished road
Need help diagnosing fuel pump issue
Good afternoon all,
I don't want to rehash a worn out topic, but I've been searching the forum for several hours now and haven't come across a solution.
98 4Runner Limited 3.4 300,000mi
Long story short, I've been welding together armor for my new-to-me 4R. It's been up on jacks for the last week or so while I fab the skids and bumpers. Since I got it I've had no starting or running issues at all.
Today I reconnected the battery and tried to start, cranks fine but no start. I noticed no sound at all coming from the fuel pump.
Any thoughts on what might have caused this? I've had absolutely no issues with the fuel pump up to this point so I doubt it is a coincidence that I've done all this work on it
Thanks in advance
MountainBrew is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 07:22 PM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Originally Posted by MountainBrew View Post
Good afternoon all,
Thanks in advance
Fuse, perhaps?
thennen is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 07:40 PM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Fuel pump only pumps when engine is turning. Doesn’t pump up at key on like most rigs.
Were you welding on the rig?
Crank position sensor can give a no start and no engine code when it dies.
You could crack a fuel line fitting and see if there is residual pressure after cranking a bit. These rigs don’t have a Schader valve.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 07:55 PM #4
Well then I’m not sure what the problem is, I read in a bunch of threads that the fuel pump runs at key on before ignition so that’s why I assumed fuel pump issue. If that’s not the case it could be something else.
I was tack welding on the rig
Old 05-30-2020, 07:56 PM #5
Originally Posted by thennen View Post
Fuse, perhaps?
I checked all the fuses but still need to test the relays
Old 05-30-2020, 11:30 PM #6
I checked all the relays, jumped the +b fp, did every test I could find on the forum. Went back to the fuel tank access panel which I had already checked and it turned out the connector had separated in the middle along the horizontal seam. This had been exacerbated by the 1” BL I installed a few weeks ago (don’t judge, kids at the mall we’re making fun of my stocker) which strained the wiring harness and separated the connector. It wasn’t visible at first glance. After fixing it fired right up.
Thanks for the suggestions
Old 05-31-2020, 12:25 PM #7
Another one of those small details you never see mentioned. Wire harness issues due to body lift.
Old 05-31-2020, 02:25 PM #8
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
Check the crank position sensor.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
fuel , issue , pump , running , start
Fuel pump issue? Mudeprived 3rd gen T4Rs 23 11-13-2018 02:35 AM
Fuel pump issue. NWFLBowhunter 3rd gen T4Rs 11 04-26-2017 04:50 PM
Fuel pump issue?? DeclansDaddy Classic T4Rs 2 07-19-2016 08:34 PM
Is this a fuel pump issue? west Classic T4Rs 2 11-12-2012 02:03 PM
Fuel pump issue on 5th gen FunRunr 5th gen T4Rs 3 06-06-2011 09:14 AM
