Old 06-01-2020, 05:47 PM #1
ViaPhoenix ViaPhoenix is offline
ViaPhoenix is on a distinguished road
Manual transmission donor 4runner
Hey all-
I am looking to upgrade my 4WD open diff 4runner to a locked diff. I have had 0 luck in the junk yards here in PHX, but I did just saw a locked 4runner come on the classifieds in my price range, but it is a manual transmission.
I am looking to swap the axles front and rear and harvest the CVs so I can have some spares. Everything else will just be cosmetic upgrades if the seats are better condition and what not.
is there anything to consider with using a MT donor vehicle? Aside from I cannot use anything transmission related.
ViaPhoenix is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 06:03 PM #2
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Originally Posted by ViaPhoenix View Post
Hey all-
The e-locker works the same on all 4Runners, no difference between the MT and AT.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 06:16 PM #3
Thanks for the quick reply!
I figured the lockers worked about the same, but I wanted to make were there wasnt anything to watch out for on the axle for mounting the rear brake lines or ABS or something to that effect.
Aside from that, what else from a donor parts car perspective who I not be able to use? or is the real only difference a MT is subbed in for an AT and most every thing else should be the same between the 2 models.
the donor is a 96 MT and I have a 97 AT.
Old 06-01-2020, 07:05 PM #4
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
The ecu, wiring harnesses, driveshafts, brake pedal, center console trim, are all different. I think the transfer case on the auto has an extra plug that the manual doesn’t have.
That should be everything, all that stuff plus the transmission would be worth some decent money to anyone wanting to do a swap and could cover the cost of your donor vehicle
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 07:28 PM #5
Great info thanks.
I owe you a few cheese burgers, Randy!
Old 06-01-2020, 07:56 PM #6
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Keep in mind the diff ratios. I believe the manual and auto are different. This may be ok for you if you swap both front and rear.
Something to double check anyway.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 08:02 PM #7
I know the locked diff had a different ratio, but not sure about the Manuals w/ locker, but either way I was going to harvest the front and rear diffs and get them geared to 4.88s before transplanting.
Sadly the 4runner sold in under an hour even though I responded within 20 minutes. The hunt continues...
Old 06-01-2020, 11:04 PM #8
HiLife HiLife is offline
Had that happen more than once. Hate it when it does.
Keep your search going GL
Old 06-02-2020, 01:43 AM #9
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Keep in mind what the parts you aren't gonna be using are worth. Should've snapped it up because a good automatic is worth like $200 tops. Complete 5 speed swaps are getting spendy. I've seen up to $800.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 01:11 PM #10
The manual ecu alone often goes for $300+, I tried for the longest time to find an entire donor vehicle for my swap and they were all gone within hours of being posted unless they were way overpriced
4runner , diff , locked , manual , transmission
97 4runner manual transmission ECU 3.4L v6 Oxford NC- $210 Yotaoffroad27 For Sale: T4R Items 4 12-31-2021 06:26 AM
FSM For Manual Transmission 4Runner MDTrailrider 3rd gen T4Rs 12 11-17-2020 04:39 AM
WTB: 3rd Gen 4runner (Manual transmission) sweendogie Want to Buy/Trade 0 08-21-2015 02:01 AM
WTB Gen 3 4Runner w/ Manual Transmission Doctor_evil Classifieds - buy & sell (no commercial ads please) 0 01-27-2011 05:09 PM
