Old 06-02-2020, 10:35 PM #16
psea17 psea17 is offline
psea17 will become famous soon enough
Originally Posted by brillo_76 View Post
+1 for the control arms. If you have a lean you could have a sticking bushing or a frozen bushing that is really bound up causing the suspension to bind especially in the rear. I also believe the driver side is slightly heavier then the passenger side. As the gas tank is there and transfer case is more on the right side if 4WD that is.
apologies, i thought someone mentioned the sway bar. are you talking about the upper or lower control arms? or both?
how would I "reset" them? loosen the upper control arm's thru bolt?
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 12:30 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes the 5 bars that hold your rear end in place. Loosen the bolts up then retighten them its probably not the lateral control arm (panhard). but while you are there I figured it wouldnt hurt. :-)
Those bushing can freeze and not function properly.
Old 06-03-2020, 01:04 PM #18
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
Springs are side dependant. A and B. Also as everyone has already stated, common practice is to torque the suspension (all suspension) bolts with the weight of the vehicle on them. Basically, loosen all the bolts set vehicle on the ground and torque the bolts, the bushings bind if you torque them with the car off the ground.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 01:45 PM #19
2TH,
Yes, I'm aware of that. everything was originally torqued to spec while on the tires as I believe I alluded to in my first post.
just thinking out loud. I mentioned I tightened the pass side UCA past torque specs last week because there was play side to side and was making noise. in theory, that could have forced the UCA to move towards the ground. perhaps that's it. will probably start there.
Manual Transmission
Old 06-03-2020, 03:14 PM #20
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
A few people have now confirmed that the 890s are side specific. Have you confirmed yours are in correctly?
I’d put my energy there First if I were you. And it’s easy to deal with.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 03:28 PM #21
no way for me to confirm other than pulling off the truck. I think I removed all tags/labels when I installed them. this will be my second item after dealing with the passenger UCA.
Manual Transmission
front , ground , rear , side , springs
Leaning bad! Help me out! Russalgolding 4th Gen T4Rs 5 06-18-2015 01:33 PM
Truck leaning 2" to drivers side dereky 4th Gen T4Rs 33 11-04-2014 01:20 PM
leaning to the right uhohh Classic T4Rs 7 07-01-2014 08:49 PM
leaning on the right SMSmitty Classic T4Rs 2 09-26-2013 02:51 PM
Truck leaning to one side Satter 3rd gen T4Rs 2 11-30-2010 01:28 PM
