Old 06-02-2020, 09:25 PM #1
BradyBunches BradyBunches is offline
BradyBunches is on a distinguished road
2000 4runner oil leak
I have a 2wd 2000 4runner that has a pretty bad oil leak. Just had the valve covers and half moons replaced but oil is still dripping onto the concrete. I’m thinking it’s the oil pan gasket or hopefully not, the rear main seal. Help would be appreciated on the cost and what it looks like
Imgur: The magic of the Internet
BradyBunches is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 12:43 AM #2
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
You had a shop do valve cover gaskets and they didn’t bother to inspect and recommend other leaking seals be replaced?
Remove your skid plates, wash your engine, and then inspect for yourself to find where the leak is coming from.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 01:25 AM #3
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Is it common for the oil pan fipg to go bad? I’ve read they last pretty long. Yah wash the bottom and see if the leak is coming from the weep hole by the bell of the tranny. If it’s coming from there then it’s the rear main is my guess. Hopefully not doh.
cashflow50 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 03:47 AM #4
HiLife HiLife is offline
You mentioned you did the half moons. You didn't mentioned you also did the circular cam plugs located on the back on the heads, facing the firewall/bulk head.
Old 06-03-2020, 04:05 AM #5
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Who did the valve cover gaskets for you? They didn't crack a valve cover did they? It wouldn't be the first time...
Oil pan and rear main seal leaks are not commonly mentioned on here. Not to say it couldn't happen though.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 12:40 PM #6
raulb21's Avatar
raulb21 raulb21 is offline
Real Name: Brett
raulb21 is on a distinguished road
raulb21's Avatar
Real Name: Brett
I would also check the oil cooler. Leaked on mine before I did the rebuild. Pretty easy to get to and narrows down the list. The seal basically can become solid depending on how long it's been on there. Just another thought.
raulb21 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 04:41 PM #7
I had it taken to a shop and they said it’s the front crank seal. I’ve having them replace water pump timing belt all belts for $1200
Old 06-04-2020, 12:55 PM #8
anormalflame's Avatar
anormalflame anormalflame is offline
Real Name: Blaine
anormalflame is on a distinguished road
Real Name: Blaine
Have you considered doing it yourself?
It takes a little bit of time, but it's not that difficult, seals included.
It's the difference between $300 and in your case $1200.
1997 Toyota 4Runner SR5 4WD
Birmingham, Alabama - Central Alabama 4Runners
Go Avs Go | Roll Tide
BlainePrickett.com
anormalflame is offline   Reply With QuoteReply With Quote
4runner , leak , main , oil , rear
2000 Limited Trans Fluid Leak - what is this... rzgkane 3rd gen T4Rs 6 02-13-2018 07:18 PM
2000 4Runner Limited 2WD -trans leak near rear of trans rzgkane 3rd gen T4Rs 1 01-05-2018 06:23 PM
2000 4Runner cat-back compared to 2000 Tacoma Prerunner Bailey8756 3rd gen T4Rs 6 01-08-2015 01:43 PM
2000 fourrunner leak codybones General Discussions 5 03-01-2014 12:07 PM
2000 4Runner - Rear Main Seal Leak? *Help!* thrice1825 3rd gen T4Rs 3 02-26-2012 01:17 PM
