Originally Posted by bigtimeweb
were your bolts just loose??? is there some sort of rubber grommet seal under the rack that may also need to be looked at?
All I know was water was somehow coming in through the frontmost hole on the driver's side. There's a little black plastic cover at the front of the rails with the bolt/hole underneath - that was the problem one for me.
I removed the trim from inside the 4runner which would be above your head to the left, above the door. I could see the water trickling down from behind that trim piece and knew which hole was the problem one.
I took all the rails off, squeezed a little glob of silicone in each bolt hole and put it back together.
No leaks since.
