Old 06-03-2020, 01:17 PM #1
bigtimeweb bigtimeweb is offline
bigtimeweb is on a distinguished road
water in drivers footwell after hard rain
Truck has been sitting for 1+ years waiting for me to get the water pump fixed. Finally have the time and money, but when I went in to get started the drivers side footwell was squishy with water. We had just had a hard rain.
I have no idea where to even start looking. Hoping someone here may have experienced same and can point me in right direction?
06 Sport v8 4x4
bigtimeweb is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 01:25 PM #2
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Check the drains to the sunroof if you have not already. Also, if you've stuffed wires in through the firewall grommet, that can also leak.
Sunroof Drain Clearing: 3rd Gen T4R DIY Maintenance, Repair and Modification Videos - Page 28 - Toyota 4Runner Forum - Largest 4Runner Forum
weekendclimber is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 01:59 PM #3
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
^^ yeah that i had both happen
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 02:39 PM #4
rickmum's Avatar
rickmum rickmum is offline
rickmum is on a distinguished road
rickmum's Avatar
Adding to the above suggestions:
If you have a roof rack check the bolts going into the top of the roof, that's where my leak was. Same symptoms, it was creeping down behind the panels/pillars on the driver's side.
1998 Desert Dune Limited w/ rear diff locker
300,000 kms
rickmum is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 02:50 PM #5
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
or if you have run cables through the firewall cable harness entrance. Water runs right down over it normally, if it's got cracks or has been opened by adding cables, that would be a good to place to look.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 02:52 PM #6
were your bolts just loose??? is there some sort of rubber grommet seal under the rack that may also need to be looked at?
06 Sport v8 4x4
Old 06-03-2020, 05:33 PM #7
rickmum's Avatar
rickmum's Avatar
All I know was water was somehow coming in through the frontmost hole on the driver's side. There's a little black plastic cover at the front of the rails with the bolt/hole underneath - that was the problem one for me.
I removed the trim from inside the 4runner which would be above your head to the left, above the door. I could see the water trickling down from behind that trim piece and knew which hole was the problem one.
I took all the rails off, squeezed a little glob of silicone in each bolt hole and put it back together.
No leaks since.
300,000 kms
drivers , footwell , hard , rain , water
The truck is leaking water into the driver's footwell... ShooterMcGavin 3rd gen T4Rs 33 05-09-2022 11:59 AM
***UPDATED IN THE COMMENTS*** Looking for help. Wet drivers side floor from rain rpete 4th Gen T4Rs 13 05-24-2019 03:54 PM
Hard to locate clunk in front end, only in the rain sjwelna 3rd gen T4Rs 12 02-04-2016 11:38 PM
vinegar/water mix to remove hard water marks? glocke12 Maintenance/Detailing 12 07-19-2011 07:38 PM
got hard water spots? acid rain spots? 4rnr4me Maintenance/Detailing 16 12-30-2007 12:06 AM
