Old 06-03-2020, 04:18 PM #1
Gary Blake's Avatar
Gary Blake Gary Blake is offline
Real Name: Gary Blake
Gary Blake is on a distinguished road
Gary Blake's Avatar
Replacing rust belt brake lines front end 2000 SR5 4Runner
The front hard brake line just above the flex hose on the driver's side front developed a pin hole due to rust - joys of living in the rust belt.
I am going to be replacing the hard lines from the caliper, flex lines, and the first hard line above the flex hose on both sides. (Passenger side is not quite as badly rusted but I want to put both sides in to the same condition)
Waiting for the hard lines coming from Toyota, went with the stainless steel jacket versions from Toytec for the flex hoses. These were less than half the cost of OEM Toyota ($C150.00 for OEM each side) and also about two inches longer which will work well with my 3" lift. Very nice looking high quality parts (Made in USA ) and very fast shipping, came with the 4 clips as well, thank you Toytec!
Any tips from rust belt driveway mechanics on getting the very rusted connector out of the first junction on the top of the frame would be appreciated.
Also looking for any suggestions on what to block the junction with once the connector is removed?
Gary
Replacing rust belt brake lines front end 2000 SR5 4Runner-06032020151429-jpg  Replacing rust belt brake lines front end 2000 SR5 4Runner-06032020152014-jpg  Replacing rust belt brake lines front end 2000 SR5 4Runner-06032020152144-jpg
2000 SR5 4 Runner, 3.4, 5spd, 4WD
Shrockworks front & rear bumpers & sliders, Warn VR10,000S, Optima Yellow Top, Icon Uniball UCA
Toytec Ultimate Lift Kit (Soon to be replaced by Icon)
Method 305 NV Racing Wheels
Gary Blake is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 04:50 PM #2
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Cool
Gary:
Wow! That's a lot of rust on those brake lines/fittings. I have a 2005 SR5 - 145,000 miles. Had a brake job a few years ago by a mechanic shop with 10 lifts and experienced mechanics (with the tools) and they let me bring them the parts (calipers, etc.). Parts and labor was under $300.
I'd have all the lines looked at on a lift at a brake job place - I wouldn't do those brakes myself.
Good luck.
PS I had a GMC Jimmy, and I've seen brake lines rust away bad - like yours. Had to replace some brake line sections, if I remember.
Got to have brakes for the 4runner.
Captsolo is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 05:19 PM #3
spartacus's Avatar
spartacus's Avatar
Soak it with pb blaster, try to get the pb blaster to seep into the threads and use a wrench put pressure on it but don't brake it free do it a couplee of times with increasing pressure. If that doesn't work use heat on the nut not the line.
Old 06-03-2020, 06:48 PM #4
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I also live in an area that has to deal with treated snowy roads in the winter which results in crusty/rusty hardware.
For something like you have there I would start with a small handheld wire brush to clean up as good as possible and then spray the fittings with Kroil.
I have tried all of the spray rust Penetrants over the years and have had the best success with Kroil.
If possible hit those areas with Kroil several times a day for a few days prior to removal and you should be ok.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 07:22 PM #5
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
Before you even stick a flare wrench on it to try to take it off cut the line as close as you can to the nut. Then use a 6 point 10mm deep socket instead. I’ve had much better luck doing that instead of using a wrench. Soak it in pb blaster or whatever your favorite flavor of rust penetrant is first.
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 07:22 PM #6
Gnfanatic Gnfanatic is offline
Gnfanatic is on a distinguished road
Guys. I had my 2020 4runner on a lift and was surprised to see all my lines are coated in a black plastic or rubber to help against corrosion. Did the earlier generations have this coating as well???
Gnfanatic is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 07:30 PM #7
Gary Blake's Avatar
Gary Blake's Avatar
Originally Posted by Captsolo View Post
Gary:
Good luck.
Yeah, this one has 331,000 miles (US truck bought in Arizona in 2005 with 89,000) so its been around the block a few times.
Trouble is it's not drive-able, sitting on jack stands in the driveway. As long as I can get that one fitting out OK the rest should be easy. Had new calipers put on a while back so the fitting on the caliper is not too rusty and the rest can be cut out.
They have switched to using liquid brine instead of rock salt and that stuff seems even worse....
Old 06-03-2020, 07:33 PM #8
Gary Blake's Avatar
Gary Blake's Avatar
Thanks, been doing that as well as wire brushing, going to scrape the joint between the fitting and the junction as well to try and get the pb blaster in there
Old 06-03-2020, 07:36 PM #9
Gary Blake's Avatar
Gary Blake's Avatar
Thanks, don't have Kroil just pb blaster and wd 40, might be waiting till monday or tuesday for the parts so it should have a good soak in by then....
Old 06-03-2020, 07:40 PM #10
Gary Blake's Avatar
Gary Blake's Avatar
Thanks a lot, that's a great idea, then I can also just crush the end of the cut line at the junction and use the old fitting as a plug while I attach the new lines - don't want the master cylinder to drain....
Old 06-03-2020, 07:42 PM #11
Gary Blake's Avatar
Gary Blake's Avatar
Definitely not on my 2000, come back in 20 years though and let us know how that coating is working
Old 06-03-2020, 09:01 PM #12
Great suggestion to cut the line and use 6 point socket. Will remember that for future if needed.
2002 SR5 Sport 4WD
Old 06-04-2020, 08:33 AM #13
garn79's Avatar
garn79 garn79 is offline
Real Name: Jeff
garn79 is on a distinguished road
garn79's Avatar
Real Name: Jeff
C150? Are u in Cda? I'm doing same job and would like to order parts asap..
Curious if you are, if you ordered from U.S. or Cda for Toytec lines, source/site? Part #s? Also wondering what your hard lines set you back @stealership?
I live in Maritimes and so far I've had best luck as mentioned by Sarki using wire brush to clean up area 1st then several applications before starting work...
But from a thread here on this site I started using a 50/50 mix of Acetone & Tranny fluid with best results..
garn79 is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 10:31 AM #14
Gary Blake's Avatar
Gary Blake's Avatar
Yep, in Ontario C$300.00 for the two flex lines quoted by my local dealership, vs $US62.00 for the pair from Toytec.
web Toyota Suspension Lift Kits, Parts & Accessories - Toytec Lifts
Part no: SS-4RFBL
Ordered mine June 2, received June 3, paid for the expedited Fedex shipping.
Also came with the 4 clips that Toyota wants $4.00 each for....
Hard lines are about c$16.00 each which seems reasonable and saves me buying bending and flaring tools.
Gary
Old 06-04-2020, 10:45 AM #15
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
Sweet thanks Gary I wrongly assumed a long wait coming from us with covid, gonna hop on that link.
cheers, jeff
flex , hard , lines , rust , side
Tacoma soft front brake lines on 3rd gen 4runner? hawkcharmer General Discussions 2 06-03-2020 12:08 AM
Generation 3 front brake calipers/pads/rotors AND New braided front brake lines Capnemo For Sale: T4R Items 0 07-01-2019 01:08 PM
Replacing all brake lines (92 4Runner) Awdtsi42o Classic T4Rs 4 03-24-2017 02:13 PM
Need help with replacing brake lines Adumb 4th Gen T4Rs 2 09-01-2015 07:51 PM
FS: 95-2000 4Runner StopTech FR. & RR. SS Brake Lines Christopher W. For Sale: T4R Items 2 02-13-2012 01:10 PM
