All excellent tips and ideas on this rusted brake lines.
I always use the cut line with 6 point sockets after soaking in penetrating oil and heating a few times if need be. So +1 on those methods.
I use OEM lines mostly because of their reasonable costs in the United States.
I See are Canadian neighbors dont have these kinds of options as the pricing is insane for some reason.
Stainless can be very hard to with because is extremely stiff and very costly.
If I dont have reasonable pricing of lines available.
I probably make my own out of ni cu tube stock and buy a good flare tool kit. As this would solve having to change them again in the rust belt. To me nothing worse then having to do a job again by using poor quality lines.
Another option is the premade lines of ni cu lines. Just make sure you match the flares on the nuts that you removed.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
