Old 06-04-2020, 01:07 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe has a spectacular aura about Kanoe has a spectacular aura about Kanoe has a spectacular aura about
Kanoe's Avatar
Originally Posted by phattyduck View Post
They must be checked with the front wheels off the ground, using a pry bar and a dial indicator. Since the ball joints are under tension in all other situations, they must be off the ground. Then you pry between the arm and steering knuckle to check for play. I don't have the spec, but basically any movement means the joint is bad.
Totally agree. I just wanted to add that this test is awkward as anything to do. Hard to set up and hard to get repeatable results. The time schedule is going to be a better bet for most, me included.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo (tbd if can be resurrected)
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 01:48 PM #17
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax is on a distinguished road
snydmax's Avatar
Real Name: Matt
Per @mtbtim and his LBJ video, you need some fairly sophisticated equipment to measure the tiny amount Toyota says is too much play.
I decided to do mine at 155k chasing some play in the steering and a wobble. The looked fine with the “jack the truck up” and wiggle method, but one of them felt looser once removed.
Also a good idea to get new bolts and use loctite... heard tell of the bolts failing before the joint itself
T4R noob... '98 4WD Limited, Desert Dune, 167k, Double Locked, Ride-Rites
snydmax is offline   Reply With QuoteReply With Quote
inspection , lbjs , mine , visual , wheel
New LBJS! Amirocassar 3rd gen T4Rs 11 11-17-2014 10:40 AM
To Those of You That Have Replaced Your LBJs xcmtb83 3rd gen T4Rs 20 11-09-2013 04:53 PM
What color are OEM LBJs? Robb235 3rd gen T4Rs 2 11-07-2013 11:11 PM
What LBJs do I need? jaredking733 3rd gen T4Rs 4 10-14-2013 12:35 AM
LBJs? hrt4me 3rd gen T4Rs 2 05-23-2013 10:00 PM
