06-03-2020, 09:24 PM
Real Name: Eddie
Real Name: Eddie
How do my LBJs look?
So a recent post about LBJs (thanks
@ Brian
and
@ habanero
) got me to thinking about mine and maybe changing them since my '01 is at 170k miles.
How do mine look? Can you determine function by a visual inspection?
There is no wheel free play when I jack up each wheel and test that way.
Thanks all,
Eddie
2001 T4R SR5 - 180k miles and counting.
06-03-2020, 09:25 PM
170k? Personally I I would change them. My plan is to change them every 40k, as cheap as they are it's worth the peace of mind. Haha
06-03-2020, 09:33 PM
I'd just replace them... Very cheap insurance and they're easy to do. On my '98, I didn't know any better, I let it go until 2018 with 320K miles on the vehicle and they were still tight and neither boot had cracked. I wouldn't do that again, though.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
06-03-2020, 09:37 PM
I changed mine and they were pretty stout no play. I just did for abundance of caution. I drive rolling mountain roads and don't want to have a mishap.
06-03-2020, 10:15 PM
Hm. This is a good idea. Not sure if the PO changed them or not. Peace of mind is always nice. Is there a recommended brand or just Toyota oem?
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
06-03-2020, 10:31 PM
OEM is the way to go. Not worth saving money on such an important part. Make sure you pick up some new bolts at the same time
06-03-2020, 10:46 PM
Virtually a unanimous vote to replace with OEM only. Got mine for $108 each on Amazon.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
06-03-2020, 10:57 PM
Every 40k? That is a bit excessive no? These vehicles are over 20 years old in most cases so yes the issue is coming up often but every 40k isn't necessary. It is more like a combination of years and use that cause failure. I think more like 100k and/or 10 years which is very similar to the schedule on the timing belt.
06-03-2020, 11:23 PM
Real Name: Eddie
Real Name: Eddie
Thank for everyone's replies.
They will be changed over the next couple weeks.
Eddie
06-04-2020, 02:39 AM
Real Name: 3 Bears
Real Name: 3 Bears
easy enough to do. Couple of hours max if no rust and right tools.
You can get the tools for free ( rent) at Orielleys or other. Small pitman arm puller for tie rods, large pitman arm puller for lower ball joint.
You will need a torque wrench that goes to 105 pounds. They have them too.
06-04-2020, 08:36 AM
It's only like $220 for oem I think, worth it to me to never have to worry about it again. Haha
06-04-2020, 08:37 AM
Eddie
Make sure you only use OEM lbj's
06-04-2020, 12:26 PM
The "use" part of the combination is why I swapped mine out after 30k miles.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
06-04-2020, 12:42 PM
@ Brian
and
@ habanero
Thanks all,
Eddie
As others have said, visual inspection is insufficient (torn boots = replace, but they can be bad without any visual problems).
They must be checked with the front wheels off the ground, using a pry bar and a dial indicator. Since the ball joints are under tension in all other situations, they must be off the ground. Then you pry between the arm and steering knuckle to check for play. I don't have the spec, but basically any movement means the joint is bad.
Replace if you have any doubt, OEM only here. It is the one major suspension problem/risk - and it can total your truck if they fail.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-04-2020, 01:04 PM
Real Name: Eddie
Real Name: Eddie
Thanks again all for comments and info. And only OEM for my LBJs.
Eddie
