Old 06-04-2020, 05:34 PM #1
Gull81 Gull81 is offline
Gull81 is on a distinguished road
PSA on Aftermarket Thermostat and Coolant
Hello all,
My car was running a little hot (about 200 on highway and 210 in the city), so I decided to tackle the thermostat and coolant.
I found that they had previously used an aftermarket thermostat. I also found a lot of rust and corrosion in the coolant reservoir. Upon further inspection, I realized the tubing for the coolant reservoir was completely filled with rust, and water could not flow through. The coolant itself wasn't terrible, so I hope most of the rust got 'filtered' and trapped in that reservoir.
I implore you guys to check out / clean your reservoir tank and tubing. I would also avoid non-OEM thermostats. After installing the new thermostat with the jiggly-wiggly valve down, the car idles around 192.
Hope this helps someone.
Gull81 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 02:12 AM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
The Toyota thermostats are nicely made, and worth it.
pluton is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 08:10 AM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Kuzeh makes the best thermostat for these ;)
Old 06-06-2020, 11:41 AM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Rust is from lack of cooling system maintenance, not coolant brand. The Toy stuff is just low silicates.
If your expansion tank line was clogged then probably the heater cores and radiator aren’t much better.
You should probably flush your system a few times. At least until it stays pretty clear. Then re-install the thermostat and fill with a coolant of your liking.
You might consider back flushing the heater cores.
I also put water wetter in my systems. It’s supposed to help with heat transfer and hot spots. It’s cheap and may do as advertised. My rigs run in the high 180’s most of the time.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
coolant , reservoir , rust , thermostat , tubing
Coolant frustration: new thermostat installed wrong way? seabun 3rd gen T4Rs 40 08-08-2017 06:43 PM
Coolant flow through thermostat during flush? Hoye0017 3rd gen T4Rs 4 01-09-2016 04:56 PM
Changed Thermostat, coolant running hot modelstudent101 3rd gen T4Rs 7 10-03-2015 07:50 PM
Uncool Coolant Flush / Thermostat Screwup hour 3rd gen T4Rs 21 06-09-2014 12:01 AM
OEM vs. Aftermarket surprise. Thermostat Ask10 General Discussions 1 04-08-2014 12:24 AM
