Old 06-06-2020, 02:21 AM #16
keeperofgoal keeperofgoal is offline
keeperofgoal is on a distinguished road
Originally Posted by plcfcng View Post
A bad torque convert like you describe kind of unusual I would do a bit more checking before pulling the trans and replacing the converter. Maybe do a compression test and look at the plugs and wires. If they are past due change them first.
my plugs and wires are new and I have a receipt from Toyota from my misfires where they checked compression and ratings are good. unless a heavy jolt could brake something inside the motor? a cracked flex plate seems more common than a broken torque converter. I thought FOR SURE motor mounts would be the tonic and I was wrong.
keeperofgoal is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 03:11 AM #17
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Originally Posted by 3bears View Post
moms are not always right (nor are dads)3rd gens are super great. Spending money on it might not be stupid.
hope you get it figured out. let us know what you find out.
you said it was great until you were coming down a hill and had to brake hard several times then the vibration started...to me sounds like a brake issue
but sitting still and there is still a vibration says something else is wrong and not in the brakes or rolling parts. In that case I think there is more to it....more than just hitting brakes coming down hill..
come clean with yo mama...what else where you doing
My 3rd gen has 300k+ miles but it ain't a mythical super vehicle. It is just a machine built in Japan by some very good car people. But if it had a problem like you described why spend the money and time on it? It isn't better then our 4th or 5th gen in any category. Damn if I wanted another 3rd gen because it was my dream vehicle I still would sale it and start over with a 3rd gen with less issues. Maybe one that was taken care of better with more options and looks better too
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 09:52 AM #18
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Just wanted to cover all the bases before pulling the trans out. Good LUCK
plcfcng is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 11:33 AM #19
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
For sure cover the bases before pulling the tranny. That’s a last step. I just think it’s a likely cause. But with no real idea of this “vibration” we’re all just guessing.
I don’t get the sale and start over. I’d guess the rig in current condition to be worth a few grand less than if it was running well.
So selling as is would probably lose the 2k it might take to fix it.
Kind of a wash in my mind.
Unless you find a 5 speed with a locker. Then trade up.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 12:03 PM #20
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Pull the starter. You might see something. Use an inspection camera if necessary. Have a friend rotate the motor by hand while looking. Agree with flexplate or torque converter. I'd lean toward flexplate.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 09:14 PM #21
mechanic80 mechanic80 is offline
mechanic80 is on a distinguished road
New to the forums, here. Does the 4Runner have a harmonic balancer mounted in rubber like an old chevy V8? That might be your problem. The older chevys would sometimes "slip" position and cause a noticeable vibration, in PARK too.
mechanic80 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 10:22 PM #22
to me the 3rd gen is just a special to ride in truck staying true to its roots while being a civil civilian hauler. I've owned 2 4th gens both motors (gave v8 to my mother) and I can't afford a 5th gen. Have considered selling and starting over but I've already spent a lot of dough and was planning to keep it forever. working on this thing has also been good learning, solution or no solution. btw I just moved to Vancouver bc and there are SO MANY 3 gens its stupid all clean and stock like wtf.
mechanic80 welcome to forum I'm a rookie too! after months of looking at other things I am currently working on inspecting the harmonic balancer as this was my only other lead before flex plate tc, and starter suggestions which again are greatly appreciated!
will report back!
Old 06-10-2020, 11:33 AM #23
Jarods7920 Jarods7920 is offline
Jarods7920 is on a distinguished road
It could be you rear U joint. I had similar symptoms to what you describe when mine was failing.
Jarods7920 is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 11:46 AM #24
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's a great suggestion. The 5VZ-FE is internally balanced so our crankshaft pulley doesn't quite act like a true harmonic balancer, although it does have a layer of rubber built into the pulley.
326WHP 347TQ
Old 06-10-2020, 12:16 PM #25
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Friend had a Jeep Grand Cherokee with the V8 that he was chasing a strange vibration on. Ended up being a small crack in the flywheel. He pulled the starter and inspected the flywheel tooth by tooth, until he found a missing one, then a crack extending from there. It's a long shot, but I have seen it before.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 12:43 AM #26
MarkamisPrime's Avatar
MarkamisPrime MarkamisPrime is offline
MarkamisPrime will become famous soon enough MarkamisPrime will become famous soon enough
to me the 3rd gen is just a special to ride in truck staying true to its roots while being a civil civilian hauler. I've owned 2 4th gens both motors (gave v8 to my mother) and I can't afford a 5th gen. Have considered selling and starting over but I've already spent a lot of dough and was planning to keep it forever. !
You just answered your own question
If you plan on keeping it forever than just fix it
I understand it’s frustrating but you could go and buy something else and it have issues as well
I’d rec taking it to a tranny shop and see what they tell you.
If my truck blew a motor or trans I’d still just fix it
Why get rid of it just to get something else and still have to put money into that. I’d rather keep the vehicle I want no matter how old it is. But that’s just me. To each his own.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
MarkamisPrime is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 12:53 AM #27
Take a 3k lose in buying and selling to get a different “better”rig and still take the chance of the same thing or something else happening.
Or keep the truck spend the 3k to fix it and have the peace of mind knowing it’s perfect on top of everything else you have already done to make it a like new vehicle.
In my mind the choice is obvious
But maybe that’s just me.
Grey wire mod
Old 06-11-2020, 06:12 PM #28
nissanh nissanh is offline
Did you check the U joints in drive shafts? A wrapped rotor?
Old 06-11-2020, 08:03 PM #29
KimIsAGuy KimIsAGuy is offline
KimIsAGuy is on a distinguished road
I recently changed my rear u-joint, while you're at it check the other u-joints. But my symptoms are a bit different from
described. My vibration will only happen when I'm at speed and on the gas, but in neutral, coasting, or letting go of the gas at the speed that it vibrates at-- I have no vibration.
I didn't rev my engine to check for the vibration... So, idk if mine vibrates in Park/Neutral.
KimIsAGuy is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 01:05 AM #30
I am following up on my issue I never found the problem my crank pulley/balancer looks good and I have not taken it to a tranny shop yet because im stubborn but have an appointment this week. I have another thread where I posted about my rpms jumping up by itself when decelerating and I was wondering if maybe it was the tc locking unlocking/malfunctioning? so if my vibration is really bad on the freeway at high speeds im probably in od, when I let off the gas rpms drag down and when they get between 1500-2k shoot up with my foot off the gas. it even happens when I brake when it gets down to certain rpms it shoots up. im almost used to the vibration now but im wondering if this all related. I also get a decent thump when I abruptly let off the gas when im close to full throttle like im being sucked into a black hole. all of this crap never used to happen so its gotta be related. going to mechanic school just to figure this out. very frustrated. I will try to post a video.
back , feel , motor , mounts , truck
Chasing a vibration Tatonka 3rd gen T4Rs 0 03-10-2018 06:25 PM
Chasing down vibration? utsikt 3rd gen T4Rs 2 01-15-2017 06:31 PM
How much did you buy/sell your 3rd gen for this year? BoulderT4R 3rd gen T4Rs 33 08-12-2015 07:14 PM
Need Help Chasing a Vibration fdbyrne 4th Gen T4Rs 24 06-04-2015 09:21 PM
Chasing Vibration / Resonance Alabamaguy 3rd gen T4Rs 0 04-13-2015 12:04 PM
