Old 06-05-2020, 12:13 PM #1
trifectaus trifectaus is offline
trifectaus is on a distinguished road
Cracked Oil Pressure Sensor Housing
Well, I finally found the cause of the continued leak coming from the oil pressure sensor. One of the mechanics a couple of years ago over-torqued an oil pressure sensor. It's taken me three sensors to figure out why the leak has grown to now be a continuous flow of oil. Turns out, the oil wasn't leaking from the sensor, but from a hairline crack in the housing that holds the sensor (see photos).
Options for repair included (according to the Yota techs in Bozeman):
1) Take it to a machine shop and have them weld it (would have to remove the alternator at a minimum, probably the exhaust manifold and other parts as well)
2) Replace Engine (She's got 350k on her, not the worst idea, but the body isn't in great shape)
3) Due to its location, budget, and size of the crack I went for the old JB Weld trick. I sprayed the heck out of threads and the outside with brake cleaner, used one of the old sensors fully torqued in to spread the crack as much as possible. I then JB welded the outside (pushing into the crack) and inside (threading in and out with the old sensor with the 5-7 hour cure stuff. Let it cure for 24 hours for precautionary measure... and now I'm about to go fire her up. I'm not overly confident as I was hoping to dremmel the crack a bit so the weld could fill in more, but I couldn't get the dremmel up there. That darn sensor is literally in the worst possible spot on the engine to work on it.
Wish me Luck!
Cracked Oil Pressure Sensor Housing-img_1197-jpg
trifectaus is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 01:08 PM #2
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Good luck and worse case have it welded
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 11:05 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh boy. Good luck. Thankfully the blocks are cast. Not super easy to weld but can be done.
Old 07-05-2022, 06:27 PM #4
chadmsmith789 chadmsmith789 is offline
chadmsmith789 is on a distinguished road
How did it go?
chadmsmith789 is offline   Reply With QuoteReply With Quote
Old 07-31-2023, 12:25 AM #5
Deej101 Deej101 is offline
Deej101 is on a distinguished road
Well....how did it go??
Inquiring minds want to know.
[QUsOTE=trifectaus;3500236]Well, I finally found the cause of the continued leak coming from the oil pressure sensor. One of the mechanics a couple of years ago over-torqued an oil pressure sensor. It's taken me three sensors to figure out why the leak has grown to now be a continuous flow of oil. Turns out, the oil wasn't leaking from the sensor, but from a hairline crack in the housing that holds the sensor (see photos).
Wish me Luck![/QUOTE]
Deej101 is offline   Reply With QuoteReply With Quote
crack , oil , pressure , sensor , weld
Can dust from a cracked intake box mess up the MAF Sensor? Mark_BC 3rd gen T4Rs 6 01-08-2020 02:19 PM
oil pressure sensor Scraptrooper Classic T4Rs 5 06-02-2014 12:23 AM
cracked side mirror and housing coletrain09 5th gen T4Rs 2 03-21-2013 04:35 PM
Cracked Side Mirror Housing - suggestions? Btm02144 5th gen T4Rs 9 03-12-2013 11:15 AM
Cracked my front differential housing maclean216 3rd gen T4Rs 18 01-03-2012 11:10 AM
