Old 06-09-2020, 08:19 AM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by shadow247 View Post
Totally agree Brillo. I never messed with stuff that went in the tank, as I figured it just wasn't any type of concentration that would actually do anything.
I don't bother with motor flushes either before oil changes, I just change it 1000 miles early every once in a while. There's plenty of detergent in modern oils to fight sludge as long as you change it regularly. If you are REALLY paranoid, you can use the new GM Dexos Spec oils.
The ONLY thing I do is the Seafoam through the Vacuum line. Every time I have done this to a car it has been a massive improvement in the way the vehicle runs. BG is also an excellent product I have used the same way when I had access to it at shops.
Seafoam has been proven to work..
Never used BG..
Old 06-09-2020, 08:24 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by gamefreakgc View Post
And kill our gas mileage . California switched to a 10% ethanol blend 2ish years ago and I went from an average MPG's of 18 solid 21 hwy to 16 mixed and 19 highway... it really doesn't like it.
Oh 100% correct. The 10% ethanol actually hurting our mpg on our rigs. Our systems were designed for 100% gasoline. Granted the engineers at toyota stated that the older engines should run with up to 15% ethonal in the gas without damaging things that's a 5% more loss in mpg.
I honestly think this is the cause for the fuel system issues.. the ethonal is eating the deposits out and clogging the filters and injectors. As this makes the most since with the age of the rigs and why people are having to clean and replace the injectors.
Old 06-09-2020, 08:56 AM #18
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Originally Posted by brillo_76 View Post
I don't think it is as good injector cleaners will clean the fuel system. How many folks on here are pulling their injectors sending them out to be tested or going to a junk yard to pull a set and send them out to be tested and cleaned?
I had many Toyotas over 250k over the years with original injectors in them. Tetanus 1 1998 is at 265k and original injectors still in.
As I said a few times. I would imagine after 30 years with a pile of Toyotas that I would have had a few injectors by now fail if I didnt occasionally run injector cleaner through. However, maybe I just that lucky but I really doubt that I am. As I dont have good luck that way.
Different experiences here. My first fuel injected Toyota was a new 1984 Celica GTS. Aside from two budgetmobiles (1979 Corolla and 1987 Tercel wagon), I've had nothing but fuel injected Toyotas since then. Most of those were driven past 200k miles. I never had a fuel injector problem, and never used any additives. So maybe I'm not the norm here.
thennen is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 08:42 PM #19
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
To add to what's already been said, run some cleaner through, it will be best while the filter is still fresh as can be. My favorites are Red-Line SI-1 and BG44k Platinum. Both are excellent combustion cleaners as well; feller I knew ran SI-1 through constantly for maybe 3-4 tanks, then gave it a good ol italian tune up for a good 10 minutes (and changed oil for good measure). Pistons were nice and bright afterwards. Could've been a thin layer to begin with, but I've been a firm believer ever since. If you can, go out of your way for some ethanol-free gas, you'll be amazed at how much your 4runner likes it. All just my 0.02
Semi-related I also recommend try running some Marvel for the entire duration of your OCI. Rotella T6+MMO is absolute gold.
change , filter , fuel , increased , miles
Fuel Filter change, advice? CookieRoe 4th Gen T4Rs 4 04-25-2016 02:15 PM
How often do you change your fuel filter? Benski 3rd gen T4Rs 47 12-22-2015 02:07 PM
Changed fuel filter and gas mileage dropped SUPMRAJ 3rd gen T4Rs 2 04-07-2015 08:08 PM
bad fuel injector after fuel filter change Drcoffee 3rd gen T4Rs 18 03-30-2012 08:39 AM
Fuel Filter Change CBR Rider Maintenance/Detailing 7 12-27-2011 06:52 PM
