Originally Posted by 3bears
what if only doing a 2 inch lift and on the rear using the relocation kit...do I still need to do something with front links ?
With a 2" you're most likely OK with stock length links. Once your over the 2" mark you'll want longer links to get your sway bar back to it's intended position. The relocation kit that you get for the e-locker will reposition the sway higher, and should eliminate the need for longer links.
Mike
