Old 06-07-2020, 02:30 PM #1
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Which Longer Sway Bar End Links
I just lifted my 2001 and I need new sway bar end link. From looking around it seems like using the OEM end links from a second gen works fine. Should I use second gen front end links for my front and second gen rears for my rear? Or should I go with the second gen rears all around? I have around 4.5 inches lift in the rear and around 3 inches lift in the front.
Please don’t tell me to not put end links because I’m gonna ;).
Thanks
ArmArak is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 02:40 PM #2
nobb nobb is offline
nobb is on a distinguished road
I tried running no links up front, and IMO it's not worth it. I prefer the better handling and slightly less wear from limiting travel a bit. I would go with a sealed link as it's just one less thing you have to worry about greasing.
For a 2-3" lifted 3rd gen, you can use:
Front: rear links from a 2nd gen 4Runner
Rear: front links from a 3rd gen 4Runner
nobb is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 03:03 PM #3
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I recently purchased aftermarket BAW #MC BK80380 2nd gen 4R rear anti sway bar links hoping to use them on the front of the 3rd gen.., the rod was way to narrow and didn't fit the bushings or bar properly, maybe i goofed on the order, the front 3rd gen links worked out for the rear though to clear the e-locker barely by a 1/4", got the Sonoran Steel rear bar relocation kit from Steve and will have to revert back to the original links someday when i get around to the relocation.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 11:29 PM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I’m running factory fronts, not sure you’d need longer ones, and 2nd gen rears in the rear.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 11:49 PM #5
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Longer links aren't required for any lift, but adding longer links will help your suspension. You can move your front links to the rear since they're an inch longer, and then add 2nd Gen to the front. These will get you in the range that you want to be in.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 12:05 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
what if only doing a 2 inch lift and on the rear using the relocation kit...do I still need to do something with front links ?
Old 06-08-2020, 12:45 PM #7
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
With a 2" you're most likely OK with stock length links. Once your over the 2" mark you'll want longer links to get your sway bar back to it's intended position. The relocation kit that you get for the e-locker will reposition the sway higher, and should eliminate the need for longer links.
Mike
Old 02-20-2021, 12:04 AM #8
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Toyota part number for 2nd gen rear end links
4883035010
Pj Benn is offline   Reply With QuoteReply With Quote
Old 03-17-2024, 10:54 PM #9
jsmithjr732's Avatar
jsmithjr732 jsmithjr732 is offline
jsmithjr732 is on a distinguished road
Replaced my bad links today with longer ones per earlier posts - wow, what a difference. A lot of my rougher riding and clunks went away. The old stock ones were toast, but I didn’t know how much they could affect the ride.
jsmithjr732 is offline   Reply With QuoteReply With Quote
end , front , gen , inches , links
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Longer sway bar end links with 2.5 lift or not? DPR64 3rd gen T4Rs 2 09-22-2015 02:16 PM
Longer sway bar links? Aelfwine 3rd gen T4Rs 3 04-27-2014 01:45 PM
Longer sway bar links on 96 runner jjamesyj 3rd gen T4Rs 10 02-19-2014 09:32 AM
Longer front sway links? ebg18t 4th Gen T4Rs 8 02-17-2014 10:16 AM
