Old 06-09-2020, 12:46 PM #16
Originally Posted by cashflow50 View Post
I’m kind of thinking it was replaced once cause it’s at 205k and still going strong. I didn’t buy the kit but buying them one at a time due to limited funds. I have the belt (oem) and water pump (aisin) so far. Need the cam and crank seals, bearings, tensioner and crank bolt. Ok I have the confidence to move forward on this. Let’s go!
Don't replace the seals unless they are leaking. Toyota cam/crank seals last a really long time, generally and you can mess up the job and cause a leak that wasn't there in the first place. I like to have them on hand, but generally don't use them.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-09-2020, 12:56 PM #17
spartacus's Avatar
spartacus's Avatar
Question: just watched Timmys video one more time and came to the part where he stripped the bolt for the tensioner idler pulley. What’s the chances that happens? Have any of you had that issue?
Torque wrenches if not caliberated can be off. If you have a cheap torque wrench and the bolt is tight enough stop wrenching on it or you end up stripping or worse breaking the bolt specially the smaller bolts in the block. I think the tensioner pulley torque is like 20 ftlbs which is not that high. You'll be surprised to learn that shop mechanics don't use torque wrenches that often.
Old 06-09-2020, 02:38 PM #18
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
I've did it myself about a month or two ago. Only ran into one issue which was a result of the crank pulley breaking a tooth. It was my first time attempt a big job like that and it wasn't that bad. Some good tips from Tim in the videos. Check the crank pulley teeth when you get the belt on and be careful taking it off. I listened to the advice of a few people and didn't change the cam seals since they weren't leaking.
Otherwise; good luck, be thorough, and enjoy that victory beer once complete.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 06:43 PM #19
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Timing belt?
Got another question, as for the camshaft gears going off tdc right after belt removal Is it ok to rotate the sprockets counter clock to make the mark or gotta go clock wise to get the marks to line up again? This is when the T belts already off. I understand for the crank it should go clockwise only with belt of without belt.
cashflow50 is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 06:58 PM #20
cashflow50's Avatar
cashflow50's Avatar
Yes beer sounds good after a victory!!!!! Thanks brother for the input
Old 06-09-2020, 06:58 PM #21
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
Got another question, as for the timing gears going off tdc right after belt removal Is it ok to rotate the sprockets counter clock to make the mark or gotta go clock wise to get the marks to line up again? This is when the T belts already off.
I think you're supposed to always go clockwise since that's the way it naturally goes.
Here's a few other links showing you how to do it as other references besides Timmy's video.
AdventureTaco - turbodb's build and adventures | Page 52 | Tacoma World This one has pictures.
Step by Step Toyota Tacoma Timing Belt Replacement for 3.4L V6 5VZFE (also 4runner, Tundra, and T100) – ADVENTURE TACO This one is a step by step guide.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 07:43 PM #22
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by 3bears View Post
well its been 2 years for me, and I did not have any issues...funny about tim stripping the bolt, might have to watch just to see him do it as I dont remeber that...seen everyone of his videos and use them for reference often
It's not that I stripped the bolt, it's the fact threads gave way when i removed the lower idler pulley bolt. When I reviewed the video footage, I could see threads hanging in the hole before I even attempted to get the bolt back in and tightened to spec. I definitely didn't cross thread it. I think it's just an occurrence that can happen when you have a steel bolt tightened into an aluminum housing. After making the video, other guys contacted me and told me the same thing happened to them. I think it's just luck of the draw if it happens but I have a feeling it's fairly rare luckily. I had to drill it out and install a helicoil to make it work. Toyota does use some type of thread-locker on the threads of that bolt. When I do this job again, I think I'm going to heat up the bolt a little to hopefully facilitate breaking the bond of the loctite with the aluminum housing.
Old 06-09-2020, 07:48 PM #23
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yeah, I post our videos on Tacoma World too in the 1st Gen section. These guys used our video as a reference to make a write-up of the job which is nice for those that prefer write-ups.
Old 06-09-2020, 09:46 PM #24
cashflow50's Avatar
cashflow50's Avatar
Thanks Tim for your videos and everything you do. They are awesome and a great reference for weekend warriors like me.
Old 06-09-2020, 11:02 PM #25
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
I did this service by myself last August, it's completely doable, BUT.. if you run into any snags it's helpful to have another set of wheels. The bolts that hold the hydro tensioner had rounded off heads, which meant I had to drop the AC compressor and drop the bracket to get to them. That opened a can of worms because the belt tensioner assembly was rotted together, so that added 4 days to get the parts from Toyota to get those parts, and then one of the compressor bracket bolts broke off ( rusted almost in half) which added more time to dig that out of the block.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 12:42 AM #26
cashflow50's Avatar
cashflow50's Avatar
With that said you think it’s a good idea to PB blast or liquid wrench the nuts and bolts before wrenching, especially the crank bolt?
Old 06-10-2020, 11:04 AM #27
anormalflame's Avatar
anormalflame anormalflame is offline
Real Name: Blaine
anormalflame is on a distinguished road
Real Name: Blaine
You got this. Just did my second TB / WP job on a 3rd gen a little over a month ago.
When you get the water pump off, make sure you get the surface completely cleaned up. Pay attention to the points or the corners.
On my most recent TB job, I missed a spot on one of the corners and the water pump began leaking. I had to take the timing belt off from the top to get to the water pump to clean it up again. Was a huge pita.
1997 Toyota 4Runner SR5 4WD
Birmingham, Alabama - Central Alabama 4Runners
Go Avs Go | Roll Tide
BlainePrickett.com
anormalflame is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 11:16 AM #28
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's a non-interference motor so you aren't going to hurt anything by rotating the cams either direction to line things up again.
Old 06-10-2020, 11:29 AM #29
Jarods7920 Jarods7920 is offline
Jarods7920 is on a distinguished road
Did anyone of my forum TR4 peers did a timing belt alone? My buddies seem to be always busy. Is it doable? There are no stickers or indication that the previous owner did the belt job done. I’ve asked him numerous times and he has no clue. Omg
Very doable alone. There are plenty of youtube walk throughs. Take your time and double check intervening. If you can read and follow instructions you will be fine.
Jarods7920 is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 01:06 PM #30
cashflow50's Avatar
cashflow50's Avatar
Raja thanks for the reply on this. Gotta make sure before I start doing stuff that might mess sh*t up hehehe. This is good to know material.
belt , busy , doable , iphone , timing
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
help pls - timing belt or timing chain? weifert Maintenance/Detailing 2 10-22-2012 07:12 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
